Old 06-04-2019, 11:06 PM #16
robkh1984 robkh1984 is offline
robkh1984 is on a distinguished road
Originally Posted by DarkPassenger View Post
Is the check engine light also on? If so (and I realize this sounds silly), remove your fuel cap and re-tighten it. A lose fuel cap will trigger an engine warning light. The ECU disables all kinds of things when the EWL is active. Crawl control, Terrain Select, etc, all get disabled and blink on the dash.
Oh yeah, I should add that to the list of things I tried. Tried it a few times. No luck. Thanks for bringing that up though!
robkh1984 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 11:08 PM #17
Originally Posted by Titanpat57 View Post
I basically was in your shoes a few weeks ago...it was the neutral position switch on the shifter in my case...$450 plus, but I had the extended warranty...no problem
Ah, good to add to the list of things to check. Thanks!
Old 06-05-2019, 12:01 PM #18
-E5J-'s Avatar
-E5J- -E5J- is offline
Real Name: J
-E5J- has a spectacular aura about -E5J- has a spectacular aura about
-E5J-'s Avatar
Real Name: J
Originally Posted by robkh1984 View Post
Shoot, it will be in 6 days! Good call, although I have lifted the car. Wonder if they'll cover it.
Do your best to hold the dealer accountable. These dealers thrive on good reviews. They don't want any negative feedback.
Also, My Toyota Experience, 800-331-4331, can be helpful...
If the dealer wont honor the warranty, let them know you'll be in touch with Corporate.
Hope you get it resolved.
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
-E5J- is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 12:20 PM #19
Thanks for the tip! Just dropped it off to the dealership in Sunnyvale, CA. I've had them work on stuff before, so let's see how it goes. Good time for that airbag recall too.
Old 06-06-2019, 01:49 AM #20
Dealer chased down the wiring and signals and found some of the wires for the front differential actuator cut somehow. Wtf?!?!? They're going to solder and reconnect them again and check again.
[Need help] Warning lights? Multi-terrain & Four-wheel drive indicator light flashing-img_1798-01-jpg
Old 06-06-2019, 02:18 AM #21
macscac's Avatar
macscac macscac is offline
macscac has a spectacular aura about macscac has a spectacular aura about macscac has a spectacular aura about
macscac's Avatar
now that's just weird.. doesn't look like rodents..
hate to say it but i hope that's your problem.
pretty easy fix!
i can hope my issue is that simple
macscac is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 04:09 PM #22
Circling back with the group. I'm $600 lighter in the wallet, but the problem seems to be fixed. Here's a summary from the dealer...
[Need help] Warning lights? Multi-terrain & Four-wheel drive indicator light flashing-img_20190607_194015-01-jpg
Old 06-11-2019, 07:16 PM #23
macscac's Avatar
macscac's Avatar
nice update!
well Toyota Surprise just called me
They told me that my issue is actually the front differential actuator and it has gone bad.
The told me that it is also covered under the powertrain warranty.
The part will not be in until Thursday so we will find out more then but if that is the case, then Autonation Toyota did 100% misdiagnose the issue to be the master solenoid and also was going to charge me $2000 to not fix the issue.
fingers crossed!
Old 06-15-2019, 11:20 AM #24
macscac's Avatar
macscac's Avatar
picked up the truck last night.
it was a breath of fresh air (even though it was 112 degrees outside) to have no lights on my dash!!
4 high and low work as well as all my MTS features!
and it didnt cost a dime!! whoooop! toyota of surprise!
so long store, my issue was my front diff actuator had failed.
Old 05-02-2024, 03:10 PM #25
MrGuitarGuy MrGuitarGuy is offline
MrGuitarGuy is on a distinguished road
Sorry to resurrect an old thread but I wanted to chime in since this thread helped me. I have a 11 TE with 90K miles. Putting it into 4x4 High/Lo did not work/would not engage, and the lights flashed on the dash as mentioned in this thread. I wanted to say that it was also my A.D.D (Part # 41400 35032) which had failed.
The mechanic informed me that it is common amongst FJ's but he see's them on T4R's on occasion.
Thank you all for helping.
Its a rare occurrence but it happens.
MrGuitarGuy is offline   Reply With QuoteReply With Quote
drove , flashing , frog , indicator , switch
C1425 Code: ABS, Trac Lights solid, Multi-Terrain Light Flashing Lost27 5th gen T4Rs 3 01-11-2023 02:31 PM
4 Wheel Drive Flashing Lights tthrower1 4th Gen T4Rs 6 02-13-2019 08:48 PM
ABS, Slip indicator and Multi-Terrain Light Tuc4R Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-02-2018 10:11 PM
Multi-Terrain Select & Slip Indicator Lights On mrvandelay 5th gen T4Rs 14 05-27-2018 11:56 PM
4 wheel drive indicator flashing rutledj 3rd gen T4Rs 10 11-30-2011 08:25 PM
