Old 06-04-2019, 12:29 PM #1
robkh1984 robkh1984 is offline
robkh1984 is on a distinguished road
[Need help] Warning lights? Multi-terrain & Four-wheel drive indicator light flashing
To my friends and 4Runnertiers!
I've been going nuts looking up and down this (and other forums), mechanics manuals, and I may have finished the web at this point.
I come to you with humility and a sense of pride that someone on here may have an answer or various answers I can test out.
The Multi-terrain Select Indicator and Four-wheel drive indicator lights are flashing. The first slower than the second, but both flashing.
I have a 2016 4Runner Trail Premium.
Here's what I've tried so far:
  • Put the 4wd mode selector to 4Lo. Drove in Reverse for 100+ ft. Also drove forward for 100+ ft Did the same for 4Hi. Tried this a few times over. No luck.
  • Checked the fuses, both in the car cabin and in the engine bay.
  • Scanned and cleared any and all codes a few times using a BlueDriver Bluetooth OBD2 scan tool.
A few questions:
  1. Could it be a relay? If so, which one?
  2. One of the wires loose on the ABS or other sensors?
  3. Traction control messed up?
  4. Any relation to a parking brake bypass switch I've added to my aftermarket stereo (Pioneer AVIC8200-NEX)? I've had the switch for a while, but fiddled around with the radio and wondering if there's any causation.
  5. Related to the Pedal Commander I use?
Many thanks in advanced!
Rob
[Need help] Warning lights? Multi-terrain & Four-wheel drive indicator light flashing-00009xtr_00009_burst20190604084228-01-jpg
robkh1984 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 12:32 PM #2
-E5J-'s Avatar
-E5J- -E5J- is offline
Real Name: J
-E5J- has a spectacular aura about -E5J- has a spectacular aura about
-E5J-'s Avatar
Real Name: J
Is it out of warranty?
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
-E5J- is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:37 PM #3
Aquabear's Avatar
Aquabear Aquabear is offline
Aquabear is on a distinguished road
Aquabear's Avatar
Did your Scan tool show any codes?
Follow the code n see what it is.
I get an annoying Cat Code (bank 1 I believe) that pops up every 10-20k, hate when the dash lights pop up. I cleared the code by disconnecting battery for 3-4 hours and it resets. I prob need to replace cat but first will try Cat Cleaner in fuel n see if that helps.
Try to do this and see if your code comes back up.
Others will chime in. Good luck.
2016 T4R Trail - Rogue
Nitto TG2 285/70/17, Toytec Ultimate Lift, AFE CAI, Borla CAT BACK, URD MAF Cal, Sprint Booster
Pepe 2008 T4R V6
Aquabear is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 03:33 PM #4
macscac's Avatar
macscac macscac is offline
macscac has a spectacular aura about macscac has a spectacular aura about macscac has a spectacular aura about
macscac's Avatar
just fyi.... this is how my issues started... after a few weeks it went to just a flashing 4x4 light and the MTS light no longer illuminated.
I have tried clearing the codes (they just come back)
i have checked all my speed sensors..
i have done a zero point calibration.
i have removed power to all aftermarket lighting ( to see if there is any result of my wiring jobs)
nothing fixes it.
I have a feeling my master control solenoid is bad.
I am dropping the truck off at the dealer on Tuesday.
macscac is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 03:34 PM #5
macscac's Avatar
macscac's Avatar
forgot to mention that i have zero 4low and at times i cannot get 4high to engage either
Old 06-04-2019, 05:07 PM #6
Shoot, it will be in 6 days! Good call, although I have lifted the car. Wonder if they'll cover it.
Old 06-04-2019, 05:07 PM #7
Try to do this and see if your code comes back up. I'll try the battery disconnect too.
Nope, no codes, which threw me off.
Old 06-04-2019, 05:09 PM #8
Let's definitely keep in touch! I may setup an appt at the dealer the day before my warranty runs out just in case. I have to get the airbags replaced due to the recall anyway.
Old 06-04-2019, 05:24 PM #9
macscac's Avatar
macscac's Avatar
mine is a 2018 but i have no warranty as i have close to 50k on the truck.
hopefully your issue is just a speed sensor or abs harness.
if its the solenoid like i believe my issue is, its like a 1500$ repair
Old 06-04-2019, 05:27 PM #10
Also, if they do end up being the ABS Speed sensor, then think something like the SDHQ guards would help?
SDHQ ABS Speed Sensor Guards - Trail4R.com - 5th Gen 4Runner Mods
Old 06-04-2019, 05:53 PM #11
macscac's Avatar
macscac's Avatar
yes the SDHQ guards will stop damage to your sensors.. if thats what actually happened.
those sensors are kind of out there and vulnerable if you are rolling thru alot of thick debris and such.
Old 06-04-2019, 06:41 PM #12
DarkPassenger's Avatar
DarkPassenger DarkPassenger is offline
DarkPassenger is on a distinguished road
Is the check engine light also on? If so (and I realize this sounds silly), remove your fuel cap and re-tighten it. A lose fuel cap will trigger an engine warning light. The ECU disables all kinds of things when the EWL is active. Crawl control, Terrain Select, etc, all get disabled and blink on the dash.
DarkPassenger is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 10:00 PM #13
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
I basically was in your shoes a few weeks ago...it was the neutral position switch on the shifter in my case...$450 plus, but I had the extended warranty...no problem
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 10:18 PM #14
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
I think powertrain is 60k or 5 years.
Daikon is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 10:21 PM #15
macscac's Avatar
macscac's Avatar
i dont believe a control solenoid is powertrain.
drove , flashing , frog , indicator , switch
C1425 Code: ABS, Trac Lights solid, Multi-Terrain Light Flashing Lost27 5th gen T4Rs 3 01-11-2023 02:31 PM
4 Wheel Drive Flashing Lights tthrower1 4th Gen T4Rs 6 02-13-2019 08:48 PM
ABS, Slip indicator and Multi-Terrain Light Tuc4R Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-02-2018 10:11 PM
Multi-Terrain Select & Slip Indicator Lights On mrvandelay 5th gen T4Rs 14 05-27-2018 11:56 PM
4 wheel drive indicator flashing rutledj 3rd gen T4Rs 10 11-30-2011 08:25 PM
