Old 06-04-2019, 04:31 PM #1
decker1's Avatar
decker1 decker1 is offline
decker1 is on a distinguished road
decker1's Avatar
All Power Windows not working - 2014
Hey there, I was hoping to get some help diagnosing a problem.
All my power windows seemed to have stopped working entirely. The drivers side master switches do not work, nor do the switches on the each door itself. Even the rear lift gate window button does not work, although you can still use the the key to roll it down).
The lights on the switches are NOT illuminated.
I have checked all fuses in the cabin and engine bay.
The stealership wants 150 to diagnose + whatever repairs.
Anyone care to save the day ?
2014 Toyota 4Runner Trail 4WD - Icon Stage 1 at 1.5" Rear, 2" Front, 1.25" Spidertrax, Coverking Ballstic Tactical Seat Covers, WeatherTech Floor Liners, Raingler Cargo Net, Green LED Bulb door mod, Gobi Stealth Rack w/ Ladder, Yaesu FT2900 Ham Radio w/ 4ft Magnetic Antenna
Build Thread
decker1 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 04:41 PM #2
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
id try replacing the window fuse even if the fuse looks ok
tm965 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 04:44 PM #3
The Waco Kid's Avatar
The Waco Kid The Waco Kid is offline
The Waco Kid will become famous soon enough
Yeah that sounds like it's definitely a fuse.
Does your AC and center console screen above Nav work?
2014 Classic Silver TE w/ KDSS - The Waco Kid's Build and Adventure Thread
Wife's Ride: 2017 RX 350
Past Vehicle:2001 Dodge Dakota Sport 4.7L V8 Quad Cab.
The Waco Kid is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 05:52 PM #4
decker1's Avatar
decker1's Avatar
Yea they both work. is it the same fuse?
Build Thread
Old 06-04-2019, 05:52 PM #5
decker1's Avatar
decker1's Avatar
Thanks for the tip!
Which fuse do you think I should replace?
Build Thread
Old 06-04-2019, 06:01 PM #6
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
Just going out on a limb because I didn't see it in your post; however, I may have missed it. Did you try pressing the window control lockout button? It should be just in front of the passenger window control on the drivers door.
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 06:45 PM #7
decker1's Avatar
decker1's Avatar
Yea i should have clarified. I tried the window locking button as well. No dice. All lights are off in the power window controls on the Drivers side. Im thinking either a fuse or the switch controls itself. I did check fuses though and I believe the main fuse would be the 30Amp that also controls a variety of interior functions
Build Thread
Old 06-04-2019, 07:00 PM #8
Ok, just making sure. Is there a possibility the connector on the drivers control has come off? Has anyone ever worked on that door?
Old 06-04-2019, 07:02 PM #9
decker1's Avatar
decker1's Avatar
hehe I did just have the drivers side fender replaced. I wonder if they could have clipped the wire? Any suggestions on where you think I should look?
Build Thread
Old 06-04-2019, 08:15 PM #10
Angelo's Avatar
Angelo Angelo is offline
Angelo will become famous soon enough
Angelo's Avatar
See if this helps... YouTube
Anything done lately that would've messed with the electrical system? Before reading any of the responses I was going to suggest a fuse as some others did. Fixing the front fender shouldn't have been the root of your problem, but maybe they knocked something near the battery and blew a few of your fuses. Fuses are cheap- couldn't hurt to pick a few up and see if that's the issue.
Good luck man, let us know what happens.
Eibach - Dobinsons - Falken - Rigid
Consolidated Lighting Info Thread
Angelo is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 08:32 PM #11
If it worked trouble free for years then started at the time, the fender was replaced, that's where I'd check first. Ideally you'd hope to find a connector knocked loose or simply just not connected back properly after the work. Worst case scenario, a wire or multiple wires has been cut or pinched. I'm not familiar with the exact location of those wires as I have not worked on mine yet. Most likely those wires go from the door to the "A" pillar which is what your fender is tied to. I would inspect the wires in the area and see if you can follow from the boot to the inside of the drivers footwell with your hand to see if anything is out of place. Remove the kick panel and inspect with a flashlight as well.
Old 06-04-2019, 09:03 PM #12
The fender itself shouldn't have caught the wire loom but they were working in the area soooo.....
Old 06-05-2019, 02:23 AM #13
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Originally Posted by decker1 View Post
"Hey there, I was hoping to get some help diagnosing a problem.
I have checked all fuses in the cabin and engine bay..."
Hi decker1
I would change the Power window fuse just to be sure that it is, in fact, good! I would use a multi-meter set to DCV (low volts scale) to check the fuse in question for voltage with the key in the ON position. If it turns out the the fuse isn't the problem, I would do a Master Reset on the Main body ECU Compu Network.
Look in the main Rly/fusebox under the hood, and locate the 'Short-pin' in the top row of the fuses; it looks like a WHITE fuse but it's not. It feeds the dome lights and the MB-ECU and 25 related ECU's! This is there to prevent a battery drain (by a door being left ajar, or the 26 or 27 ECU's drawing current) while the truck is being shipped from the factory to it's dealership destination!
Pull that short-pin out and leave it out for a minimum of four hrs! This will RESET the ecu's to their factory settings! When you reinstall the short-pin, the radio pre-sets will be lost, and the Instrument panel "Compass" will need a "Circle Calibration", confirmed by a Blinking Dot adjacent to/left-side of the direction icon e.g., .N!
Instructions for a compass 'circle calibration' is in the manual (procedure determined by the Trim level)! Let us know how you make out with the master reset and circle calibration when completed! 'Best to you',
rig
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 08-21-2021, 10:16 PM #14
warrengreen warrengreen is offline
warrengreen is on a distinguished road
I'm experiencing exactly this problem. Where the AC and center console screen above Nav don't work as well as the windows. Do you know what the solution could be??
warrengreen is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 02:45 PM #15
I've found the solution. For my 2014 4runner trail, it's the "ECU-IG no.1" fuse in the cabin fuse box under the drivers side dash.
power , switches , windows , work , working
Power windows stopped working jschrumm Problems & Warranty Issues 4 03-23-2016 10:07 PM
Power Windows Stopped Working Herrera4Runner 5th gen T4Rs 4 08-09-2015 08:59 AM
Power windows stopped working achha64 3rd gen T4Rs 5 12-09-2014 10:42 AM
1st gen power windows not working? thatoneguy Classic T4Rs 5 08-19-2014 08:47 PM
power seat and windows not working ivanfj 3rd gen T4Rs 2 11-02-2009 06:17 PM
