Old 06-06-2019, 01:35 PM #16
BCMUSA's Avatar
BCMUSA BCMUSA is offline
BCMUSA is on a distinguished road
BCMUSA's Avatar
Originally Posted by jhguth View Post
they are hub centric, go look at your lug nuts - they are normal flat washer style nuts
the haweka adapter has nothing to do with lug centric or hub centric, a centering cone is still used. the purpose of the haweka adapter is to provide even pressure to the wheel to make sure it is on the cone correctly. it is not a lug-centering tool. if the wheel isn't perfectly centered on the balancing cone your results will be off, the haweka adapter helps make sure it is centered on the cone by providing even pressure all around.
i'm think all toyota alloys are hub centric, but i don't know enough about the various wheels offered to make an absolute statement
Interesting.
Thank you
2019 4X4 T4R OR. Nitto Terra Grappler G2
BCMUSA is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 01:38 PM #17
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Originally Posted by brtnstrns View Post
If I remember correctly, TRD Pro wheels are not.
I could be totally wrong here though.
My Pro Wheels are most certainly hub centric.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 02:33 PM #18
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
All Toyota Truck wheels need the flange plate adapter used on lug-centric wheels.
I see others have a different opinion. I don't want to argue. But Toyota literally says, a flange plate must be used. I guess it doesn't matter if the wheel is actually lug or hub centric. Just use the flange plate and it will eliminate the steering wheel wobble.
Road Force Balance Question-finger-plate-adapter-jpg
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 03:04 PM #19
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
that TSB explains what I am talking about, the wheel is hub centric and uses a centering cone and the purpose of the flange plate is to make sure it is mounted properly. the plate does not center the wheel, the cone does.
As the wing nut is tightened, equal pressure is automatically applied to each stud forcing the wheel to perfectly mount on the balancer
the purpose of the adapter is to evenly sit the wheel on the centering cone.
one of the directions is to verify that the cone sits on the "hub-centric portion of the wheel." the flange plate just makes sure everything sits evenly on the cone.
the technician should also do a centering check which is easy to do on the hunter and i assume other machines
jhguth is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 03:05 PM #20
brtnstrns brtnstrns is offline
brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice
Ah okay, well that's good to know. Can't recall why I thought they weren't but thought it was strange for an OEM wheel.
Voodoo Blue 2020 Tacoma TRD Off Road
brtnstrns is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 03:50 PM #21
Kenstaroni's Avatar
Kenstaroni Kenstaroni is offline
Kenstaroni is on a distinguished road
Kenstaroni's Avatar
One thing that has helped with balancing for me is to get the shop to line up the heavy spot on the tire with the valve stem. If they are marked anyway.
Kenstaroni is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 04:13 PM #22
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
The misconception is that the Haweka adapter is for lug centric wheels. It is actually used to put equal force as if they were mounted to the car.
Toyota aluminum alloy 6 lug trucks wheels are all hub centric.
However the 6 lug steel wheels on base model Tacomas are lug centric (which T4R don't have to be concerned about)
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 04:20 PM #23
That will absolutely make a huge difference sometimes!
I'd say OP issues are with the tires. My original Nittos started getting pretty bad after the 40K mark. Just installed GY 285 Duratracs and they are completely smooth. OP this may sound off, but have you tried balancing them with a non-roadforce machine? A buddy of mine that has been doing tires for a long time told me that sometimes roadforce is not the way to go on larger more aggressive tires.
My best balance on my Duratracs was done on a Hunter non-road force balancing machine from America's Tire. I believe the model was called Quick Match. I still had all sorts vibration problems when the first America's tire kept doing it on the latest and greatest Hunter GSP 9700 Elite road force machine.
TRD Pro wheels
Old 06-06-2019, 07:36 PM #24
Bayou_Pro's Avatar
Bayou_Pro's Avatar
Good to know. Mine were done on a Hunter non-road force machine as well.
Paul
alignment , brand , lower , tires , wobble
Wheel Balance - Acceptable Road Force Limit? alext72888 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-30-2018 09:28 AM
More stealership woes (tire road force balance) ghostridr 4th Gen T4Rs 8 05-03-2013 05:52 PM
Wheel Balance Question Bftfan 4th Gen T4Rs 12 03-21-2011 09:03 PM
Dealer + Road Force = Trouble DSH 4th Gen T4Rs 6 06-15-2010 05:05 PM
Road Force Wheels Balancing TRD04RUNNER Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-15-2005 07:47 AM
