Old 06-09-2019, 04:59 PM #1
I4CUTigers I4CUTigers is offline
I4CUTigers is on a distinguished road
Need guidance with suspected KDSS noise
I have searched the forums for the notorious clunk and that doesn’t appear to be my issue.
I have a 2018 TDRORP with KDSS.
Upon starting and driving down the road, I am occasionally getting a loud pop/clunk that sounds like a rock hit hard in a wheel well. However, the origin of the noise seems to be coming from right under the driver’s side, where the KDSS cylinder is.
Most of the KDSS threads pointed to a problem with turning left, and the noise coming from the front of the vehicle. I just had this happen driving in a straight smooth road at 45mph, about 5 minutes after leaving a restaurant, and the noise definitely came from under the driver’s seat. Is the 3rd or 4th time it’s happened.
Any ideas?
I4CUTigers is offline   Reply With QuoteReply With Quote
Old 02-10-2022, 02:20 AM #2
Overland8754 Overland8754 is offline
Overland8754 is on a distinguished road
I know this is old but did you ever get this issue solved? Thanks!
Overland8754 is offline   Reply With QuoteReply With Quote
Old 02-10-2022, 08:34 AM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
KDSS cylinder in the back tends to be clanky during cold weather. I needlessly replaced rear shocks just to confirm it was KDSS making thump noise.
<<<< is offline   Reply With QuoteReply With Quote
Old 02-10-2022, 09:26 AM #4
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Sway bar link/end bushings have a limited life depending on driving habits and will produce clunks when worn. Went through this on mine, easy check/fix.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-10-2022, 10:20 AM #5
especially with a lift, the front bushings at the LCA's are in a bad position. i replaced ours and it eliminated a knocking sound.
Old 02-11-2022, 08:51 AM #6
<<<<'s Avatar
<<<<'s Avatar
I replaced bushings but occasional clunk is still there because it comes from cylinder itself.
coming , driving , kdss , noise , road
KDSS knocking noise during lateral movement dhatcher 5th gen T4Rs 17 06-20-2019 08:11 PM
A follow-up, and a hint (suspected head gasket) Outrider 3rd gen T4Rs 0 10-06-2016 07:37 PM
Suspected leaking rear diff doubleA 3rd gen T4Rs 8 08-08-2012 09:45 PM
suspected exhaust leak oljedi11950 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-23-2012 07:45 PM
suspected leaked V6 engine, with pictures tcpoob 4th Gen T4Rs 14 06-03-2011 12:39 PM
