Old 06-11-2019, 12:06 PM #16
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Originally Posted by DaddySteve View Post
I ordered from Flithy Motor Sports. Ben and I had a very in-depth talk about compression adjusters. We decided that for my mostly on road use that they were not necessary. Just depends on what your looking for. I ended up with 2" lift up front 550lbs springs and left my 1" spacer in the rear with stock spring. Also went with JBA UCAs. Very happy so far with the results.
I tried to order from Filthy. Their website is garbage and it wouldnt let me put in Canada for shipment. Called them and the voicemail said they would call back in 2 days
Went to Totalautomotive, spoke to Rich, had all the gear ordered asap and was slightly cheaper to. Ive ordered off Total before and last time it worked out ok.
Grug556 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 02:44 PM #17
nimby's Avatar
nimby nimby is offline
nimby is a jewel in the rough nimby is a jewel in the rough nimby is a jewel in the rough
nimby's Avatar
Originally Posted by Grug556 View Post
Hawt!!!
Ok ordered the King coilovers, got the adjustable versions. Went with 550lb springs, stock springs in rear. Be here in about 3-4 weeks. Thanks everybody for help.
Last question for road use what to set the compression adjusters to for front and rear?
If you're trying to maximize on-road comfort, I would put them on the lowest setting and go from there.
nimby is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 07:00 PM #18
MrGainzz's Avatar
MrGainzz MrGainzz is offline
MrGainzz will become famous soon enough MrGainzz will become famous soon enough
MrGainzz's Avatar
Questions on KING coilovers for a LIMITED
You should check out Elka since you are on the east coast(rust concern in winter) and they are made in Quebec to battle against salt and harsh chemicals in winter as they are made of aluminum.
You sound like me,mine is a daily driver (95% of highway),so I only need a mild lift and I’m sticking with 265/70/17.
I bought Elka for my 2017 limited and I didn’t get the adjusters since I figured the difference would be insignificant no matter how I play with it and I’m really lazy.
MrGainzz is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 11:01 AM #19
Grug556's Avatar
Grug556's Avatar
Thanks, so for the fronts set on 1? Do the rears need 1 or do they bump up to say 2 or 3?
Old 06-12-2019, 11:30 AM #20
Deletrd Deletrd is offline
Deletrd is on a distinguished road
For those who have Kings, what other parts did you guys purchase to complete the lift. I’m going this route also, did you guys get new bumpstops, bumpstops extension brackets, uca, etc? I want to get everything at once and slap it all on and have all parts on hand needed to complete the job.
Deletrd is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 11:46 AM #21
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
if you're going to leave the collars alone and level your 4runner, nothing extra is needed. Just a good alignment tech.
If you're planning to lift, you'll want new upper control arms, and rear springs.
The rear reservoir brackets will receive the existing bumpstops. I have seen people use the toytec bumpstop spacer, but I don't run one, and I have 2" icon springs in the rear.
I do not use a front diff drop either.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 12:25 PM #22
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
I did not use a diff drop either. My CV angles look like stock with 2-2.25" of lift.
One thing my Kings was missing from the packaging was two small 3/8 washers used for the front reservoir bracket 'slotted' hole. You can go to your local hardware store and find a 3/8 lock washer and flatten it. I e-mailed KING about it and they said that will work fine.
Edit: Another thing to note that is not mentioned in KING's instruction is that when you relocate the front sway bar w/ the reservoir brackets, you also install spacers for the tubular support arms (1 on each side). When you do that, you cannot "hook" the skid plate back on using the hooks. You will have to bend them with a pair of pliers until they the four mounting points line up on the bottom.
Daikon is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 06:42 PM #23
nimby's Avatar
nimby's Avatar
Fronts at 1
Rears at 1
This will give you the softest ride these shocks have to offer. Probably the best for daily driving on the road.
If you add a bunch of weight to the rear, you could bump up the rear shocks accordingly.......and the front shocks too if it feels like the front end is floating at all.
If you take it off-road, you will probably want to move he adjusters up a few notches as well.
Old 06-12-2019, 10:28 PM #24
TheDozer TheDozer is offline
TheDozer is on a distinguished road
Been running mine for ~2.5 years. Love it and glad I went King. Installed myself, let me know if you have any questions. Taking out XREAS is messy if you manhandle it.
TheDozer is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 10:31 PM #25
275/70/17 w/ TRD wheels
Gobi rack w/ ladder & sunroof insert
40" Black oak LED in front and 2-6" in rear
2000 ARB awning
Full RCI skids
Sliders
Full Kings all around, just had them recharged ~2k miles ago
Total chaos UCAs
ICON 2" springs in rear
Dynamat whole interior (yes...it sucked)
HID low beams
Yellow LED fog bulbs
coilovers , king , make , rear , setup
King Coilovers - Adjustment Questions Bumbo 4th Gen T4Rs 5 12-22-2017 12:43 PM
SoCal 3rg gen limited 4x4 locker king coilovers total chaos. CLEAN trade or offer sponger4life949 For Sale: Vehicles 10 04-13-2017 01:04 PM
Help. King coilovers rebuild questions shootmymime 3rd gen T4Rs 19 08-20-2016 09:21 PM
3rd Gen King Coilovers - Used - ABQ, NM MojaveMadMan For Sale: Suspension/Wheels/Tires 1 09-30-2015 10:07 PM
