Old 08-23-2023, 09:17 PM #1
AustenKorowski AustenKorowski is offline
AustenKorowski is on a distinguished road
Headlamp bulb going in and out intermittently after H9 bulb mod?
Anyone have any advice? Basically the bulb will work for a couple days, then go out, and then as soon as I touch it it starts working again. Don't really want to waste the bulb if it's a simple as crimping or spreading something apart to get a better connection maybe?
AustenKorowski is offline   Reply With QuoteReply With Quote
Old 08-23-2023, 09:37 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I would check the connections in the socket to make sure they are tight and the crimps are good. Also look at the bulb to see if anything looks bad (loose tab or pin and if they are dirty or corroded. Also look at the socket (where it plugs in to the bulb) to see if it looks good. Does it fit tight when plugged in? The fact you can touch it and it works indicated a poor connection somewhere. Also look at the wiring that leads up to the socket to see if there is any damaged insulation, etc. Trace it back as far as you can.
Lots of problems with 4Runner tail and brake light wire crimps. The same could be true for headlamps I guess.
Old 08-24-2023, 12:48 AM #3
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
From what I understand, you shouldn't touch the bulbs. The oils from your fingers can create a hotspot on the bulb and may cause premature burn out.
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 08-24-2023, 08:35 AM #4
osugsxr osugsxr is online now
correct ...thats why you wear gloves. It does sound like a loose connection
osugsxr is online now   Reply With QuoteReply With Quote
bulb , crimping , simple , waste , working
Which Bulb Fit Your Vehicle? |A Compared LED Bulb Guide For 5 Different Series lasfit 5th gen T4Rs 0 08-09-2023 09:15 PM
Best H3 fog bulb CDNsurf 3rd gen T4Rs 19 03-11-2015 02:09 AM
Need headlamp bulb help ASAP medicrn 4th Gen T4Rs 8 02-08-2013 12:58 PM
tail light brake bulb out but bulb is good Rock 3rd gen T4Rs 5 10-20-2012 01:57 PM
Dash computer light bulb out - bulb type? Futrewoods 4th Gen T4Rs 3 01-03-2009 01:12 PM
