Old 06-10-2019, 11:41 PM #1
jamoc jamoc is offline
Real Name: DeLo
jamoc is on a distinguished road
Real Name: DeLo
2019 / 2020 Fox shock SPRING replacement options?
Hello all,
Adding a low profile front bumper and winch, (160 lbs.), to a 2020 trdp very soon after purchase. Sliders, roof rack / RTT will be added as well, however those are more centered weight distribution items.
Any input on a FOX front spring replacement option, (such as Bilstein 6112 Front Springs for 2010-2018), to offset added weight / front end height sag? I do want to keep the fox's for hopefully the near life expectancy - I am aware that a longer spring, with additional spring # weight 'may' deteriorate my shock quicker.
I also plan on adding Dobinsons / Wheelers etc. rear coil springs - to offset possible aft sag, after the front spring install.
But my main focus, are potential direct spring replacements for 2019 - 2020 front FOX shocks.
Cheers,
jamoc is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 12:02 AM #2
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Front combined spring rate is 600lb/in. 160lb added weight will lower the front about 1/4 inch. It's a 2:1 leverage ratio on the front coilovers. So 1/8 inch spacers would get back to level. 1/4 spacers would net a small lift.
If you like the current height, I'd add a small shim spacer on top of the current coilovers. The cost is small. Easy install. Basically no performance change.
Old 06-11-2019, 05:44 PM #3
Real Name: DeLo
Real Name: DeLo
Thank you for your knowledge, and straight forward reply. This is the exact info. I needed. Let's say I do want a very mild lift, roughly 1-2 inches?
Old 06-11-2019, 05:59 PM #4
OCTT4R's Avatar
OCTT4R OCTT4R is offline
OCTT4R is on a distinguished road
OCTT4R's Avatar
Are Fox springs made by BDS?
OCTT4R is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 08:03 PM #5
Real Name: DeLo
Real Name: DeLo
Thread update
I called Eibach a couple days ago. I read somewhere on this forum that they had somethin' brewin' for the Fox suspension setups. Sure glad I called! I spoke with a gentleman who let me in on some exciting news: One of their employees has a '19 trdp. They have been testing a front and rear coil (spring only) direct replacement!
He went into a bit of detail. The front spring is meant to satisfy additional weight from a front bumper / winch assembly. If I remember correctly : roughly 1 inch higher, with a 600 - 650# rating. ALSO -- Here is something new : they are developing an adjustable rear spring replacement! He went on by explaining that the need for adjustability is to 'level out' the rear, when compared to where the front sits, as well as the additional weight load of RTT's, racks, etc.
This spring replacement system will supposedly be released in 'a couple months'.
Kudos to Eibach, and thank you to the gentleman I spoke with on the phone. He was very informative, and knowledgeable.
Old 06-13-2019, 08:27 PM #6
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
Lmk if you want to sell your fox setup
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 01:37 PM #7
Real Name: DeLo
Real Name: DeLo
Mike
You clearly didn't read this post. I will be replacing springs only. I'll sell you the springs, $1200 shipped. I'll let you know.
Old 06-14-2019, 07:46 PM #8
Mudballz's Avatar
Mudballz's Avatar
I did read it right keep it you deserve yourself
Old 06-14-2019, 08:37 PM #9
Real Name: DeLo
Real Name: DeLo
Thanks Mudballz, I appreciate that. Very informative input, keep up the great work
Old 07-01-2019, 12:56 AM #10
thedragonchk thedragonchk is offline
thedragonchk is on a distinguished road
THIS IS GREAT NEWS!!!! After talking to a tech at Toytec and another at RSG here in Denver, I was really fearing I'd have to replace the whole damn suspension from nose dive after installing a new
full width front bumper, winch, & skid plates. Any idea on a timeframe they have for releasing these goodies?!
thedragonchk is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 07:21 AM #11
Conscans Conscans is offline
Conscans is on a distinguished road
Does anyone know the coil spring rate for the OEM 4Runner TRD Pro Fox shocks?
2019 year as 2020 is same
Conscans is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 01:33 PM #12
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
Pretty sure its 600lbs.
MGordo is offline   Reply With QuoteReply With Quote
fox , front , sag , spring , weight
2020 T4R Predictions - 04/08/2019 L8Shift 6th gen T4Rs 34 07-11-2020 07:32 PM
Buy a 2019 or 2020 if the 3.5 will be the power plant for the 6th gen troopa4life 5th gen T4Rs 21 03-04-2019 11:01 PM
xreas replacement - shock vs shock/spring replacement amheck 4th Gen T4Rs 21 11-14-2017 08:21 PM
3rd Gen 4runner Rear Coil Spring Replacement and Rear Shock Bushing Replacement mtbtim 3rd gen T4Rs 7 11-28-2016 11:43 AM
2000 Ltd shock replacement/upgrade options dendrologic 3rd gen T4Rs 1 05-17-2014 07:40 PM
