Old 11-03-2021, 08:32 AM #61
dom42 dom42 is offline
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
Originally Posted by mo_mo View Post
Of note, there is no 'pump' unless you're treating the pistons as pumps.
Simple (2-way, 2 position) solenoid valves come in two flavors, normally open and normally closed (there are exceptions such as latching).
It sounds like pulling the fuse tells the electrical brain box to default the system to command the valves closed. This is probably for 'safety' to ensure body roll/stability is maintained under a simple electrical (fuse) failure case.
Pulling the plug at the solenoid/accumulator box disconnects the solenoids from the brains and they default to their normally open state.
Driving at a 6" square curb at 10 mph might be harsher than hitting that same bump at 60 mph depending upon where you are at in the natural frequency of the system (sometimes it's easier to drive faster and things smooth out than drive slower and things go bumpity bumpity).
It would be great if someone could take their phone (with a good mount), and run some tests over the same courses (whoops, washboards, etc.) to quantify harshness (vibration/shock mostly) along with body roll etch with the system on and off for comparison.
I’m working on some comparison videos for website. But my setup is not fair either.
dom42 is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 05:15 PM #62
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
dom how do i go about getting one of your switches.
thanks
Old 11-03-2021, 06:18 PM #63
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
thanks
DM him on IG @dr_kdss
blksubykid is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 09:12 PM #64
thanks
oy! check the site he launched recently... Dr KDSS - KDSS to the next level
Old 01-18-2022, 11:24 AM #65
I4CUTigers I4CUTigers is offline
I4CUTigers is on a distinguished road
Ordered one Saturday from his site. Supposed to arrive this Thursday. Excited to see it.
I4CUTigers is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 11:59 AM #66
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
If you are not feeling it you are not driving it enough. Or haven’t drove it enough to know what it does or doesn’t feel like. Even if you are heavily modified. I doubt it’s as modified as mine. I have basically a race setup per day and can def feel it. Mayb it’s not working or failed. Especially if it’s the v1 control harness. Might want to check it.
Yeah I just plain cannot feel the difference at all with the BG harness. Let's rip this thing out, I just ordered the harness off of the drkdss.com site and will install it as soon as I can get to it.
NorthPark is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 07:55 PM #67
i ran mine hard friday-sunday thru the az desert. loved it, ripping thru at 50-60, then hitting a stretch of asphalt, flip the switch, back to normal.
Old 01-19-2022, 06:45 PM #68
2NDHOUSE 2NDHOUSE is offline
2NDHOUSE is on a distinguished road
This is a cool fix. Getting a 2022 with KDSS soon and will look into doing this.
2NDHOUSE is offline   Reply With QuoteReply With Quote
control , harness , plug , switch , toggle
Map light toggle switch dakine_999 4th Gen T4Rs 3 06-19-2013 03:20 PM
Power antenna toggle switch zgensler31 3rd gen T4Rs 6 05-19-2013 11:46 PM
Toggle switch on a condenser fan? 4runner86 Classic T4Rs 4 10-22-2012 09:46 PM
Electric Fan question, about toggle switch. slipknoter106 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-14-2012 03:43 PM
Adding toggle switch for DRL Cas5Id4 3rd gen T4Rs 17 07-05-2010 11:46 AM
