Old 06-11-2019, 11:37 PM #1
SnoRnR's Avatar
SnoRnR SnoRnR is offline
SnoRnR will become famous soon enough
SnoRnR's Avatar
Xenon Depot Lighting Issue Help
Hi,
I installed the 9005 LED kit for high beam with the DRL driver. Once complete the driver side works perfect but nothing from the passenger. Also, both DRL lights do not work. I have tried reversing the polarity of the passenger side nothing. I also attempted to refit the OEM bulb nothing. I did find a 10amp fuse blown under the hood but when I replaced it blew again. Can anyone help me?
The HID kit worked perfect on the low beams.
SnoRnR is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 08:19 AM #2
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
Have you contacted xenondepot? their customer service is excellent.
tjnptel1 is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 12:15 PM #3
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Did you try swapping bulbs from side to side? to see where the problem really is?
In other words does the passenger side bulb suddenly start working when attached to the drivers side?
nglayton is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 01:08 PM #4
SnoRnR's Avatar
SnoRnR's Avatar
Ok I will try changing bulbs over. Then drivers try to find the problem.
Old 06-12-2019, 07:22 PM #5
SnoRnR's Avatar
SnoRnR's Avatar
Ok so I managed to get them working. I tried the drivers side bulb and driver module first nothing. Then I tried a higher rated fuse as per xenon depot website. Should be 10 amp i tried 15 amp and it blew. Put a 20 amp fuse in and the light worked fine.
Worried though as I now have a 20amp fuse sitting in the slot for a 10. Will this cause heat issues or any sort of fire hazard? The dirvers side is working fine with a 10 amp fuse.
Old 06-12-2019, 09:23 PM #6
nglayton's Avatar
Real Name: Neal
nglayton's Avatar
Real Name: Neal
I would contact Xenon Depot and see if that lamp is working within design specs. I believe all the wiring to the fuse block is probably all the same gauge. I'm guessing 20amp will be fine as there are most likely other 20a fuses in the block (don't know for sure with out heading out in the 97 degree heat to check)
But I would ask Xenon Depot to make sure you don't have a lemon or one on the outer edge of specs.
Old 06-12-2019, 09:51 PM #7
SnoRnR's Avatar
SnoRnR's Avatar
I think its more of a vehicle wiring system thing. It worked fine connected to the drivers side with a 10 amp fuse. I tried it on the other side with no issues, But I will message them.
Old 06-12-2019, 10:44 PM #8
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
The circuits supplied by the fuse block are all independent of each other. The fact there are other 20A fuses does not mean it's ok to over fuse your lighting circuit with a 20A fuse to make it work. There is something wrong with that circuit; or some part connected to it. I suggest you remove that 20A fuse and not use that circuit until you (or someone else) troubleshoots and finds the problem.
Old 06-12-2019, 11:24 PM #9
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Couldn't agree more!!!! Xenon Depot Lighting Issue Help
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
driver , drl , passenger , perfect , side
Xenon Depot LED Lighting propain 5th gen T4Rs 259 09-08-2021 05:32 PM
FS: Xenon Depot LED H11 sleazy_4runner For Sale: T4R Items 9 12-25-2016 11:22 PM
FS: Xenon Depot 4300K H11 Xenon Headlight Kit Need4spdnb Classifieds - buy & sell (no commercial ads please) 9 07-09-2007 08:37 AM
