Originally Posted by SnoRnR
Ok so I managed to get them working. I tried the drivers side bulb and driver module first nothing. Then I tried a higher rated fuse as per xenon depot website. Should be 10 amp i tried 15 amp and it blew. Put a 20 amp fuse in and the light worked fine.
Worried though as I now have a 20amp fuse sitting in the slot for a 10. Will this cause heat issues or any sort of fire hazard? The dirvers side is working fine with a 10 amp fuse.
I would contact Xenon Depot and see if that lamp is working within design specs. I believe all the wiring to the fuse block is probably all the same gauge. I'm guessing 20amp will be fine as there are most likely other 20a fuses in the block (don't know for sure with out heading out in the 97 degree heat to check)
But I would ask Xenon Depot to make sure you don't have a lemon or one on the outer edge of specs.
