View Poll Results: Who's looking for a rear bumper?
Me, I am 125 85.62%
Me, I am
125 85.62%
No, thank you 21 14.38%
No, thank you
21 14.38%
Voters: 146. You may not vote on this poll
Old 01-11-2020, 10:24 AM #301
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
Im pretty sure they said earlier it should be the same as factory, but it wont be officially rated.
Sent from my SM-G973U using Tapatalk
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 12:56 PM #302
4R4Trout's Avatar
4R4Trout 4R4Trout is offline
4R4Trout will become famous soon enough
4R4Trout's Avatar
That is what I remember hearing. The factory tow receiver is mounted to the frame cross member using 6 large bolts. This gets removed and the bumper is mounted using the same 6 bolt holes plus 10 other bolt location so it should be plenty strong to tow the factory ratings.
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 327/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper, Kenwood TM D710GA Ham Radio, Engel MT-45, Method 701 (Black) UpTop Overland Bravo, 38” Extreme LED lightbar, Dobinson UCA
4R4Trout is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 06:03 PM #303
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of
Official Vendor
Real Name: Cam
Originally Posted by macscac View Post
hey Victory,
This may have been answered above and I missed it but I am curious, with this bumper, are we still able to pull the same weight as a stock runner with a stock tow receiver?
I love this bumper and I am really hoping it does not limit any of the rigs towing ability
thank you
This is correct. It is mounted in the same way as the factory hitch and then some, but it has not been officially tow rated.
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 03:23 PM #304
Off-Camber Off-Camber is offline
Real Name: Brandon
Off-Camber is on a distinguished road
Real Name: Brandon
Does anyone have the Hi lift Jack carrier? I would like to know the overall width measurement as well as the measurement from the left edge of the mount to the start of the bolt slots on the back of the mount (where you bolt it to the swing out).
I'm pondering this idea of drilling 2 holes on the angled edge of the right side swing out just behind the tire and mounting the hi lift there at an angle behind the tire. Basically exactly like the ladder mounts on the opposite side. The jack itself will fit between there and the rear hatch with plenty of room to spare.....it just depends on the two measurements I asked about above as to whether it will work or not.
My goal is to use the left side swing out to mount a set of stacked rotopax and a 5 lb propane mount respectively on either side of the Rotopax/traction board mount. Traction boards will be on the prinsu.
Off-Camber is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 01:44 PM #305
4R4Trout's Avatar
4R4Trout's Avatar
Off-Camber,
Did you every get the highlift mount figured out?
Old 02-16-2020, 01:55 PM #306
Real Name: Brandon
Real Name: Brandon
Off-Camber,
No. I never did as far as mounting it to the bumper. I went to a local metal fab shop and had 1/4" steel plate bent at a 45* angle so I can hang it off the side of the prinsu rack. That way I can still mount up the RTT.
On the left swing out I'm going to use the vertical rotopax mount. Plan on stacking 2 4gal pax on the inside (center) portion of the victory mount and bolting a propane tank mount to the outside of the victory mount. Maxtrax I'll be mounting on the roof rack horizontally in front of the RTT.
I'll attach a couple if pics of the jack mount once I get to better service area.
Brandon
Old 02-17-2020, 08:42 AM #307
TNcaveman's Avatar
TNcaveman TNcaveman is offline
TNcaveman is on a distinguished road
TNcaveman's Avatar
I'm in need of a rear bumper (and a little body work )
Because I messed up part of my bumper cover, I'm looking for a good used bumper to cut up for one of the Victory 4x4 bumpers. I have found a Limited bumper that's Barcelona red. What's the difference in the areas that are left after cutting? Anyone have a Limited with the Victory bumper and could post a pic or two of the interface with the bumper.
Thanks in advance
Stephen
2018 4Runner - TR'aD Off Road - Old Man Emu shocks/springs. OPOR Slider
1989 4Runner (490,000 miles and sadly sold)
2004 4Runner (now at 285,000 mi. and sold)
2000 Celica GTS - the little bro with an attitude - speed limits toooooo loooow
TNcaveman is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 02:52 PM #308
4R4Trout's Avatar
4R4Trout's Avatar
Brandon
Sounds good Brandon. Looking forward to the photos.
David
Old 02-17-2020, 03:12 PM #309
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Thanks in advance
Stephen
Those who have Limiteds can also chime in here, but several have installed them on a Limited! I believe the only real difference is the hard body line we used to measure the cut from in one area. So here is the measurement down from the taillight instead. We have also had someone buy a new rear bumper cover (unfinished) and left it matte black. It looks good! Either way should work fine.
Rear Bumper with Modular Swingouts NOW AVAILABLE! NEW VIDEO-limited_rearbumper-jpg
@victoryrunner
Old 02-18-2020, 01:51 AM #310
dktxt4r's Avatar
dktxt4r dktxt4r is offline
dktxt4r will become famous soon enough dktxt4r will become famous soon enough
dktxt4r's Avatar
Thanks in advance
Stephen
Look at post #291 in this thread. There are shots of my install on a Limited.
dktxt4r is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 07:23 AM #311
TNcaveman's Avatar
TNcaveman's Avatar
That really makes a Limited look better
Thanks,
Stephen
Old 02-18-2020, 09:14 AM #312
Real Name: Brandon
Real Name: Brandon
Thanks in advance
Stephen
Hi Stephen,
I have a limited. Are you asking for pictures around the edges of the vehicle where there is a gap between the bumper and bumper cover or around the back-bottom of the hatch area where the flat top of the bumper meets up with the plastic bumper cover area?
Brandon
Old 02-18-2020, 09:29 AM #313
Real Name: Brandon
Real Name: Brandon
David
Hopefully these all come through. Both mounts are at Zink Primer/Powder Coat now. should have them back in a week. I have 1 more mounts I'm going to have to make when I switch out for a 60" hi lift instead of 48".
Brandon
Rear Bumper with Modular Swingouts NOW AVAILABLE! NEW VIDEO-jack-mount-1-jpg  Rear Bumper with Modular Swingouts NOW AVAILABLE! NEW VIDEO-jack-mount-2-jpg  Rear Bumper with Modular Swingouts NOW AVAILABLE! NEW VIDEO-jack-mount-3-jpg  Rear Bumper with Modular Swingouts NOW AVAILABLE! NEW VIDEO-jack-mount-4-jpg  Rear Bumper with Modular Swingouts NOW AVAILABLE! NEW VIDEO-jack-mount-5-jpg
Old 02-18-2020, 09:30 PM #314
TNcaveman's Avatar
TNcaveman's Avatar
Hi Stephen,
Brandon
I saw what I needed - thanks Just curious if there's a difference if I use a Limited cover after cutting. They look pretty much the same.
Stephen
Old 03-11-2020, 09:12 AM #315
CherokeeTactical CherokeeTactical is offline
Real Name: Chris
CherokeeTactical is on a distinguished road
Real Name: Chris
Are there any current discounts for the rear bumper and swing carrier??? I've got the Victory front bumper on mine, looking to get the rear to match!
"Blessed be the Lord my rock, who trains my hand for war, and my fingers for battle" Psalm 144:1
CherokeeTactical is offline   Reply With QuoteReply With Quote
bumper , hitch , modular , rear , swing
Victory 4x4 New Product Prototyping (Armor & Accessories) victoryrunner 5th gen T4Rs 360 06-29-2023 01:56 PM
New rear bumper coming Frontline 4th Gen T4Rs 8 11-28-2017 08:28 PM
Southern Style Modular Bumper - thoughts? decker1 5th gen T4Rs 2 01-07-2017 05:30 PM
Rear bumper with swingouts question 1da4 3rd gen T4Rs 10 08-31-2015 01:04 PM
Shrockworks Modular Rear Bumper/Tire Carrier TxBxSx 5th gen T4Rs 81 09-17-2013 10:56 PM
