Old 06-12-2019, 05:15 PM #1
3s1kill 3s1kill is offline
3s1kill is on a distinguished road
Full lift kit for Limited 5th gen
I'm thinking of doing a full lift kit on my Limited 5th gen using either of these kits. Does anyone have any input on removing the XREAS for a full kit or experience with either of these kits?
TTHA-CK-RCC - 3" Lift W/ Bilstein 5100 Front Coilovers (FJ/4Runner/GX)
OME-4R210 - Old Man Emu Suspension (2010+ 4Runner)
I'm currently using a Daystar 2.5"/1.5" leveling kit but I wanted to go higher and larger on my tire size.
3s1kill is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 05:25 PM #2
wolfbbg wolfbbg is offline
wolfbbg is on a distinguished road
How much overall lift does the Daystar 2.5/1.5 (F/R) get you -- with stock tires? I'm trying to decide between that and the ~1" (front only) leveling kit. Just can't decide.
How does it ride with the 2.5/1.5? I really like the stock ride with XREAS, although most of my driving is onroad and my off-road tastes are "mild". Still haven't convinced the CFO of the need for new wheels/tires yet either... ;)
thanks!
wolfbbg is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 05:31 PM #3
thanks!
I'm using 265/70/17 Falken Wildpeaks with SCS Ray10's. I was getting a good amount of rubbing. I'll measure from the center of the wheel to the bottom of the fender later today. I don't have any stock measurements.
It reads as good as stock or better. I'm happy with it for the price. I just want to go higher/more aggressive look.
Let me dig up a photo and I'll post it later.
Old 06-12-2019, 05:32 PM #4
Bergz Bergz is offline
Bergz will become famous soon enough
I have a 2014 Limited and looked at both of those options before going with ToyTec, mostly because they are local here in Denver. No matter what I chose, I was told the XREAS delete was the same. They simply disconnect, then un-clip the XREAS lines from the brackets in a few places, and zip tie them up and out of the way. Super easy for those that know what they're doing, and either of those kits should be fine - at least according to ToyTec... Good luck, and chop chop, we need another lifted Limited around here!
__________________________
2014 4Runner LE - XD Grenade OR 17" Gunmetal Wheels - 285/70/17 Ridge Grapplers - XREAS Delete - ToyTec BOSS Suspension Lift w/SPC UCA's - Borla Catback Exhaust - AFE Momentum GT Pro CAI - Sprint Booster (wow!) - Tint Match - AVS Aeroskin - K&N Washable Cabin Air Filter - Black Emblem Kit - Stock Running Board & LE Rocker Trim Delete - Added RSG Flat Sliders w/bump-out & TE Rocker Trim - Full LED Swap - Rola Rack & Fox Wing Awning: Skids, lights and new front end w/Slimline bumper & winch still awaiting clearance from the tower...
Bergz is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 05:42 PM #5
Got any pictures of your setup? Thanks for the tips, I was going to remove the lines also but good idea just tying them up out of the way.
Old 06-12-2019, 05:56 PM #6
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Take a look at the Eibach kit too. Made here in California and rides fantastic.
PRO-TRUCK LIFT SYSTEM (Stage 1)
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 05:58 PM #7
Wagonhenge Wagonhenge is offline
Wagonhenge is on a distinguished road
I have a 2016 limited and i ditched the XREAS for a full set of 5100's. IMHO, the on road ride got a bit softer, with more roll in the corners. However the ride on any unpaved surface of any kind improved enormously.
2016 T4R Limited 3rd row
2015 Holden Commodore SSV
Wagonhenge is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 12:17 PM #8
Nothing recent, but I'll try to get a few new ones posted later today...
Old 06-13-2019, 02:09 PM #9
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
This is expected. XREAS links the front and rear shocks together in a manner that lessens body roll. Get rid of that system and you're increasing body roll.
llDemonll is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 10:13 PM #10
TheDozer TheDozer is offline
TheDozer is on a distinguished road
Go King all the way around on your limited. OME from experience will be much more stiff than your stock ride unless that's what you're going for??
TheDozer is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 07:19 PM #11
I wish I could but that's out of my budget range. I'm just debating on doing it myself or paying the shop to install it. A shop wanted $600 for labor to delete the XREAS, install and align.
Old 06-18-2019, 10:23 PM #12
If you're good with tools and your kit has springs already installed (coil overs) then I'd say do it yourself. Removing XREAS isn't bad but it can get messy if you end up saying screw it and cutting some pieces out. Took me ~6 hours solo to take out XREAS, do fronts with new UCAs, and rears all with remote reservoirs. I'd imagine it would of taken 3-4 hours with someone to help or if I wasn't taking my time.
I do have air tools and barely used them. Goodluck with it!!!
Old 06-19-2019, 03:05 PM #13
soggysailor soggysailor is offline
soggysailor is on a distinguished road
When you remove the Xreas system will you have any dash lights/codes to deal with?
soggysailor is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 03:23 PM #14
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
nope
No lights etc.
Its all hydraulic. I removed my entire xreas lines and all and replaced with Eibach.
I have some wrenching experience but took my time and had it done in weekend working till I was tired of working on it.
NO oil leaks if you take xreas apart at the correct points.
I did have the springs installed on struts prior to starting the install.
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 03:25 PM #15
None at all
full , gen , kit , kits , lift
Spacer lift vs. Full lift kit cowaggon 5th gen T4Rs 73 12-02-2019 01:28 AM
Limited's Full-Time 4WD Like AWD? ThePirate 5th gen T4Rs 14 03-03-2019 08:16 PM
OME Full Suspension Lift - 2884 or 2885 spring for 3'' lift? chon79 5th gen T4Rs 5 04-25-2018 03:06 PM
Front lift, spacer, full lift? jackshanahan11 4th Gen T4Rs 13 04-06-2015 08:37 PM
Full set of take off springs 98 Limited mforce For Sale: Suspension/Wheels/Tires 0 08-06-2014 10:44 AM
