Old 12-15-2019, 11:58 PM #1
Moses_J Moses_J is offline
Moses_J is on a distinguished road
GTR Lighting Ultra 2.0 H11 Reviews
Has anyone recieved these yet to provide feedback?
They're the new hotness all over Headlight Revolution but I've not seen any real reviews yet. They were just released at the beginning of December so I understand they're still fairly new. I bought them to replace my Nineo Gen2s but still waiting for them to ship.
YouTube
Moses_J is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 12:57 AM #2
Matze's Avatar
Matze Matze is offline
Real Name: Matt
Matze will become famous soon enough
Matze's Avatar
Real Name: Matt
Can’t help you with a answer but I hope you put out a review after installation and testing!
2020 black ORP
Matze is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 02:34 AM #3
Chevrolegs Chevrolegs is offline
Chevrolegs is on a distinguished road
Subscribed! Interested in a review!
Chevrolegs is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 09:44 AM #4
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
I actually have these installed for about a week now as I pre-ordered during their Black Friday special. They are a considerable improvement over the Morimoto 2Stroke 2.0 that they replace. But I've only used them for about 15 minutes at night. They appear to be about 60-70% of the total output of my 2019 GX460 OEM LEDs. But the GX does use two LED projectors per headlight. OEM LEDs also have very good CRI (color rendering index) so the biggest test will be in the rain. In terms of brightness the GTR Ultra 2 should perform better in the rain simply because they are brighter than the Morimoto but how well is yet to be seen. The fitment is spot on and everything fits under the dust cap without any issues. The build quality is good and the aluminum construction has a good weight so it doesn't feel cheap. The fans are also more quiet than the Morimoto. But you won't notice the noise with either once the engine is on. I would recommend using OEM halogen O-rings to make it easier to push and twist into position. It seems like halogen O-rings are slightly thinner. You can also adjust the beam pattern to make sure they are in the optimal position. The cables are also flat but I don't think that really provides any benefit from a round cable since they get stuffed under the dust cap. There are also polarity marks on the plug which makes them plug and play. From my limited experience I am happy with them so far.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 12-17-2019, 01:36 AM #5
Awesome to hear! I constantly went back and forth between the Morimoto 2 Strokes and Diode Dynamics SL1. It's reassuring to hear you consider these an upgrade. Mine actually showed up today so I'm hoping to get them installed tomorrow or Wednesday.
Old 12-17-2019, 03:37 AM #6
DRKWNG's Avatar
DRKWNG DRKWNG is offline
DRKWNG is on a distinguished road
DRKWNG's Avatar
I was interested in the DD SL1s as well, but have heard many stories where they will not fit in the vehicle; assuming that means they won't fit under the dust cap. Regardless, I'm interested to hear how these bulbs work for you as I desperately need something more effective.
A man who carries a cat by the tail learns something he can learn in no other way.
DRKWNG is offline   Reply With QuoteReply With Quote
Old 12-17-2019, 10:45 PM #7
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
So I pulled the trigger on these, will post up before after pics. Anyone have photos before/ after or any photos? thanks
ForRun is offline   Reply With QuoteReply With Quote
Old 12-17-2019, 11:52 PM #8
zmilin zmilin is offline
Real Name: just call me "Z"
zmilin is on a distinguished road
I ordered a set for both low beam and high beam last weekend. I had a hell of a time at night recently and started doing some research. Ended up deciding to go with the LED option and was going to pull the trigger on the SV.4 but saw the review for these. They are not cheap but if they do what they say its worth it to me.
I dont have the tools to measure light output but will try and take some before and after shots to share with everyone as well.
2018 Limited | Blizzard Pearl | Redwood leather
zmilin is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 12:05 AM #9
ForRun's Avatar
ForRun's Avatar
Did you go with Ultra 2 for the high beam also?
Old 12-18-2019, 10:42 AM #10
clarksky clarksky is offline
clarksky is on a distinguished road
great lights!
After watching the reviews from Headlight Revolution, I replaced the stock low-beams in my 2019 with these bulbs and have been extremely happy after using them for 2 weeks. The practical visibility is an immense improvement over the stock bulbs. The beam pattern is tight, and there are no blind spots. All the hardware fits nicely inside the stock housing, but the bulbs themselves were very difficult to twist into correct position. To install the bulb on the driver's side, I had to reposition the battery just to gain enough leverage to twist the bulb into place, but that was the only trouble. In all, I'd definitely recommend them.
clarksky is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 10:55 AM #11
You can make it easier by swapping the o-rings and using the ones from your halogen bulb. You will notice halogen o-rings are slightly thinner.
Old 12-18-2019, 09:51 PM #12
I did.
I ordered the PWM module with it. My only concern is that it will sacrifice the DRLs. I keep forgetting to call and find out if the DRL will run at full high beam during the day. If this is the case I might switch the high beam to the Xtreme LED Pro. I saw that it still functions as a DRL in this video https://www.youtube.com/watch?v=OUwp3HkYiqw&feature=youtu.be.
Old 12-18-2019, 10:10 PM #13
ForRun's Avatar
ForRun's Avatar
I did.
I read the GTR ultra works with DRL, not sure about the ultra 2?
Old 12-18-2019, 10:48 PM #14
Black-X Black-X is offline
Black-X is on a distinguished road
Where you all ordering these from, direct? I’m willing to give them a shot if they really are a noticeable improvement over stock and will last
Black-X is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 11:33 PM #15
ForRun's Avatar
ForRun's Avatar
I did.
So this is odd. that youtube video at the 1:30 marker says the GTR ultra bulb won't fit under the 4runner cover. Guy in another thread says it fits great??
Thread post 107----->Headlights suck
Pic
beginning , december , gtr , reviews , understand
Ultra Ever Dry? Myrunr2010 3rd gen T4Rs 6 10-01-2014 02:57 PM
Ultra Crusher or Ultra Bolt? merica Gallery 0 06-22-2014 12:51 PM
Ultra Ever Dry RiFF RaFF Classic T4Rs 7 04-23-2013 07:55 PM
Footwell Accent Lighting/ Ambient Lighting cleger 4th Gen T4Rs 4 02-27-2013 10:02 PM
