View Poll Results: Are you interested in an aluminum front integrated winch bumper?
Yes 96 88.07%
Yes
96 88.07%
No 13 11.93%
No
13 11.93%
Voters: 109. You may not vote on this poll
Old 06-14-2019, 03:49 PM #16
PatrickBateman's Avatar
PatrickBateman PatrickBateman is offline
PatrickBateman is on a distinguished road
just a thought, it would probably sell better without that logo.
2018 TRD Pro
PatrickBateman is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 04:27 PM #17
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
I am interested in the aluminum bumper
As mentioned earlier here, our off-roading is mainly deep sand and dunes. It needs to handle some bash plate duty and be able to pull the ‘other’ trucks when they’re stuck ;)
Bonus: Can it hold lifting the truck with a hi-lift jack?
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 07:05 AM #18
Every Day OutDoors Every Day OutDoors is offline
Every Day OutDoors is on a distinguished road
I would be interested in a bumper with a hitch mount, I want to mount my winch on a hitch so I can move it front to back and don't have the weight of the hitch permanently up front. Or even just a cost effective hidden hitch mount that gets the hitch area up higher in the bumper than what is currently out there.
Every Day OutDoors is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 09:43 AM #19
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Great design. Obviously a 30” light bar will not fit. And I presume you can no longer use a hidden light bar mount like the Rago? Do you think you might offer a bracket to make it work.
Hate to mount my Baja S8 30” on top just due to theft
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 09:45 AM #20
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
I really be interested if that light cutout was for a 20" rigid E-series. but you've already shot that option down when I asked about you doing that for me with a steel bumper.
mr.walleye is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 09:57 AM #21
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
If I ever decide to go that route for some reason, totally aluminum.
I fail to grasp the strength concerns and I wheel in rocks often. If the rocks are so big as to require dragging bumpers as a SoP, then it is Wrangler time. There is nothing substantial one can do about the departure angle anyway. And, as pointed out already, this is a hybrid bumper.
I have 3/16 armor underneath due to said rocks but that's a very different story from the front bumper.
Plus, I am averse to adding weight except where I believe it to be essential (see skids).
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 06-15-2019, 11:43 AM #22
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
Originally Posted by ProfessorP View Post
Aluminum also works for people like me that don’t off road in an environment where you need “armor.” Soft deep sand and mud is very different from rock crawling. I would like to add a hidden winch behind a bumper that allows winch access, but doesn’t weigh a ton. I don’t need a bumper that can withstand repeated bashing into rocks.
This is the same reasoning for me. If i can add a winch and bumper with recovery points with the least amount of weight added up front id be all for it.
Sent from my SM-G930V using Tapatalk
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 12:08 PM #23
jaemz's Avatar
jaemz jaemz is offline
jaemz will become famous soon enough jaemz will become famous soon enough
jaemz's Avatar
strong username to post correlation
jaemz is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 02:15 PM #24
4FL 4FL is offline
4FL will become famous soon enough 4FL will become famous soon enough
4FL 4FL is offline
Yes, interested. Cannot at all this year due to finances (house purchases, upgrades), but the weight aspect is appealing.
-I hardly off-road, and never have actually due to location, so weight adding as a daily driver is something I want to avoid.
-I am not a fan of the logo, completely understand about product brand display, but something more subtle would be better.
-I like the light bar.
-That bull bar thing or whatever it is called, not a fan of.
-Can that thing be coated in a factory color?
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 02:56 PM #25
Woz1976-MT's Avatar
Woz1976-MT Woz1976-MT is offline
Real Name: Steve
Woz1976-MT is on a distinguished road
Woz1976-MT's Avatar
Real Name: Steve
I like the idea of a 1/4-inch aluminum front bumper that is winch-capable.
I would *really* be interested in a full hoop design with stainless mesh screen (all powder coated) to protect from ice chunks, gravel, large flying insects/birds, from getting past the grill.
I would also prefer the the hitch point in the front so that a winch could be easily moved between front and rear, as well as being stowed at home during times when I'm not off-roading. Some kind of nice plate/cover for the front and rear receivers (perhaps put the Victory logo on it) for when the winch is not in use.
- Steve
2016 Trail Edition | Classic Silver | KDSS | Entune with Nav | Factory Remote Start | TRD Pro Matte Black Wheels | Cooper Discoverer A/Tw LT265/70/17 Tires
Woz1976-MT is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 06:58 PM #26
CITYRNR's Avatar
CITYRNR CITYRNR is offline
Real Name: Ben
CITYRNR will become famous soon enough
CITYRNR's Avatar
Real Name: Ben
Definitely into this. Will be purchasing when you release it. Please consider the no logo offer. It just is so much cleaner. Would even pay an extra $50 for it. Let us know if you will have a group buy with discount for the first batch!
2019 TRD ORP w/ KDSS (Silver) - 6112/5160 w/ SPC UCA, Full+Fuel RCI Skids, SSO Sliders, C4 Lo Pro w/ X20
CITYRNR is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 07:25 PM #27
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by Victory 4x4 View Post
We do offer it without the bull bar and have filler panel available for those that don't run a lightbar. Some have also painted the panel black to make it more subtle. We will have the same options if/when we make an aluminum version.
Yes. I like this option.
Old 07-01-2019, 08:20 PM #28
thegreatchangsby thegreatchangsby is offline
thegreatchangsby is on a distinguished road
Any concept art/design for full front bumper?
thegreatchangsby is offline   Reply With QuoteReply With Quote
Old 07-02-2019, 08:02 AM #29
Phil Frames Phil Frames is offline
Phil Frames is on a distinguished road
^^^^^ this please!
Phil Frames is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 01:08 PM #30
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of
Official Vendor
Real Name: Cam
Aluminum Front Blitz prototype! More info/photos coming soon.
Aluminum Front Integrated Winch Bumper | TWO IN STOCK!-aluminumblitz-jpg
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
aluminum , bumper , front , option , winch
4th Gen 03-05 & 06-09 Front Integrated Bumper! 15 Percent Off Intro Pricing! Victory 4x4 4th Gen T4Rs 80 04-21-2023 07:08 AM
New Factory Integrated Front Winch Bumper w/ Video Victory 4x4 5th gen T4Rs 5 02-25-2019 10:18 AM
front bumper with integrated light jharpphoto 5th gen T4Rs 3 10-03-2016 11:53 AM
Interested in a Stock Bumper Winch Mount for your T4R? LWN Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-22-2010 11:10 PM
Integrated bull bar in front bumper???????? ki_soarer 4th Gen T4Rs 6 02-14-2010 05:53 PM
