Old 06-15-2019, 05:24 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Strange Dash Lights
I was driving today and noticed my newly installed ScanGauge II kept turning off by itself. I would turn it back on and after about the 3rd or 4th time this occurred, my speedometer said I was driving approximately 40-50 mph when I was only going about 20-30 mph. I believe the entire gauge cluster flashed while this happened and then my ABS and traction control light stayed on. Car felt like it drove normal so I pulled over and shut off the engine. When I turned it back on, the ABS and traction light turned off and it seems to be normal now. I installed a new battery, ScanGauge and a voltage booster within the past week and a half, but this is the first time it did this.
Chilow is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 09:43 PM #2
Quick update. I thought it was just a one time “glitch”, but it happened 3 more times. Every time, the ScanGauge would not stay powered on and then the ABS and traction light will illuminate.
So far, I’ve checked that the battery connections are nice and tight. Checked ABS wires at all wheels and they appear to be okay. Read that it could be a loose gas gap, but I checked and re tightened it anyway. I can’t replicate the issue. It’s very random. I wiggles the wire harness that connects the ScanGauge to OBD port thinking it was a loose connection there, but it wouldn’t replicate the previous issues.
Old 06-16-2019, 12:16 AM #3
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
Why do you have a voltage booster?
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 12:18 AM #4
I have an AGM battery and they require around 14 volts to keep it charged. The stock alternator only puts out around 13.5 volts.
Old 06-16-2019, 07:34 PM #5
Have you tried removing it and seeing if the lights go away when you clear the code?
Old 06-16-2019, 08:17 PM #6
I should clarify that there are no codes
Old 06-16-2019, 10:02 PM #7
Ok have you taken the voltage booster off to see if it would cure your problem?
Old 06-17-2019, 12:49 PM #8
I reached out to ScanGauge customer support and they responded with:
"Your vehicle runs the CANSF protocol (required in US vehicles after 2008), so we can send you a cable that isolates that protocol."
They're sending me a "custom CAN only cable". Hopefully that solves it.
Old 06-17-2019, 12:53 PM #9
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
interesting, that happened one time to me about 6 months ago but i assumed it was due to low voltage since it happened immediately after i was testing how long my fridge would run before hitting the low voltage shutoff.
jhguth is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 01:29 PM #10
Do you also have a ScanGauge hooked up? Or just the other symptoms?
Old 06-17-2019, 02:00 PM #11
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
interesting I don't even seen that cable you are referring to being sold separately. What mode are you running on the arclights booster, what was your reported V at start and after 30 mins of driving?
Update after I recollected my google search powers: >> X-Gauge Categories >> CANSF
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 02:06 PM #12
yeah, scangauge. started blinking then got a bunch of warnings on the dash board
Old 06-17-2019, 02:07 PM #13
Originally Posted by Akkording View Post
interesting I don't even seen that cable you are referring to being sold separately. What mode are you running on the arclights booster?
Yea - not sure about the cable they're referring to either. I didn't see any threads on this forum mentioning using a different cable. I'm running "boost" on the arclights booster.
Old 06-17-2019, 02:07 PM #14
Did you ever figure it out?
Old 06-17-2019, 02:20 PM #15
Akkording's Avatar
Akkording's Avatar
not boost+?
I would undo the SG ODBII cable for now until your CAN cable comes in.
abs , mph , time , traction , turned
Strange electrical motor noise coming from dash clkcrawford 5th gen T4Rs 23 02-04-2023 04:13 PM
Strange buzzing sound from dash under acceleration..... AlphaQup 4th Gen T4Rs 8 12-28-2020 12:51 AM
Strange noise coming from behind dash? (link with audio) uncleslam23 3rd gen T4Rs 3 02-24-2015 03:27 PM
Very Strange Dash Issue morphious 4th Gen T4Rs 12 12-07-2013 10:34 PM
Strange Noise from DASH!?!? 4x4runner91 Classic T4Rs 5 06-14-2009 03:15 PM
