Originally Posted by Grug556
No regrettably not, its in an old house I moved out of in 2012. My buddy though...scarred for life!
It wasnt subtle , it let go with no warning and flew like a missile!! Impressed with how deep it went. Missed buddies head by maybe 2 inches or so... to hear him tell it you would think I was trying to kill him..
Some people!!!
When I was a teenager my dad and I had this happen to us almost; luckily only one out of two of the clamps let go so the spring was held on one side and bowed out on the other. Freaked us out because it let loose w/o warning also, and if it had come fully loose we might not have survived it.
After that we rigged up a floor jack with a chain attached to a piece of heavy steel. We added a piece of wood to the jack plate, which the bottom mount of the shock sat in, and then the upper shaft of the shock ran through a hole in the metal plate, which was chained to the jack. Raising the jack would then press the top spring mount against the steel plate, which was chained to the bottom of the jack, so as the jack plate was raised it would shorten the distance from top of spring to bottom of shock, compressing the spring.
I'm sure words don't give a good mental image and it probably sounds sketchy. But the whole thing was super simple and I was always surprised how well it worked. Must have changed my springs a dozen times with that setup no drama whatsoever
