Old 06-19-2019, 02:26 PM #1
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
2010 no-start upon first crank. Second try starts
This has become more and more common lately. It’s exactly like when you disconnect the battery, then the first time you try to start it, it dies. The second try it runs fine.
Battery is new. No codes. Runs great.
Do these vehicles suffer from CPS failures ?
Thanks
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 06:47 PM #2
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
On my vehicles this has been a fuel pressure regulator leaking the pressure off into the tank.
83Mule is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 05:19 AM #3
Thanks,
I’ll look into it. So from searching, it seems the 4th gen has CPS problems, but I can’t find much on the 5gen.
Old 06-20-2019, 05:06 PM #4
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I had the same problem with another vehicle. The fix was to replace the fuel pump where a one way valve is located to keep the pressure up until the next start.
We got around this for a long time by moving the key to the run position and waiting a few seconds, then go to start. This ran the fuel pump for 2 seconds before starting. Sometimes we went to off, then back to on to make the pump cycle a few times. Finally replaced the fuel pump to fix it.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 08:25 PM #5
This is definitely a possibility as the vehicle has 186000+ miles on it. I'll look into it.
Thanks
Old 06-20-2019, 09:07 PM #6
BobsTrail's Avatar
Real Name: BobH
BobsTrail's Avatar
Real Name: BobH
Thanks
Not sure if our T4s do it the same way or if there is a regulator or valve upstream from the gas tank and fuel pump.
To troubleshoot mine, I bought a fuel pressure gauge and a T fitting to put in the fuel line between the tank and engine. It showed about 50 psi but slowly bleed off overnight. It was OK to drive during the day.
battery , cps , failures , fine , runs
05 4.7 V8 has intermittent extended crank time on cold/hot starts. Utah_4runner 4th Gen T4Rs 61 11-21-2018 03:57 PM
3RZ Crank, No Start Red October 3rd gen T4Rs 4 08-13-2016 03:51 PM
89 only starts cold if you pull start fxfourever Classic T4Rs 7 06-16-2015 12:58 PM
Turns over but won't start when hot, must sit for 30 min. before it starts Meteoriteman Classic T4Rs 11 06-14-2013 09:02 PM
Remote start issue 2010 SR5-excessive crank time Fixmandan 5th gen T4Rs 2 04-08-2010 03:29 PM
