Old 06-23-2019, 12:36 AM #1
rockwind1 rockwind1 is offline
rockwind1 is on a distinguished road
running different size tires across from each other
so in the old days, your weren't supposed to run different size tires on either side of the axle cause the "spider" gear would spin too fast.
i am running 285/70 coopers on my rig but my spare is still the old original tire size 265/70
does anyone know if i put it on the front or rear in the event of a flat, will it cause any real damage, i do have the trail edition so it has a locker rear end, not sure if that makes any difference.
thanks for any good info.
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
rockwind1 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 12:58 AM #2
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
if you're only in 2wd you can drive with the spare on the front wheel no problem.
on connected axles (i.e. rear axle) you need to run same size tires. 4wd also shouldn't be used with the spare of a different size on
llDemonll is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 01:42 AM #3
Texas_Ranger's Avatar
Texas_Ranger Texas_Ranger is offline
Texas_Ranger will become famous soon enough
I would agree with this
Texas_Ranger is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 08:59 AM #4
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
It's no different than running one of those dumb "space saver" donut spares. Just keep the speed down and get it fixed as soon as possible. And yes, don't use 4wd.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 02:05 PM #5
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Keep it under 50 and get it fixed ASAP and it is no more harmful than driving a twisty road.....the bigger the discrepancy in size the harder it is on the spiders too.
83Mule is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 06:45 PM #6
on either front or rear? or only front in 2wd?
Old 06-24-2019, 10:40 AM #7
only front and only in 2wd.
Old 06-24-2019, 10:53 AM #8
Jeep sold vehicles with donut spares and solid axles for years.
The point is that it gets you to a repair facility, not that it gets you across the country. I don't see an issue using it on the rear just to get you to a shop.
Now if you have a spool in the rear, that's a different issue and not going to work.
Old 06-24-2019, 11:13 AM #9
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
I got a flat a couple of weekends ago up in the mountains, had to put my stock spare on while running 275s. Got me home just fine.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 03:01 PM #10
bigmace bigmace is offline
bigmace is on a distinguished road
As others have said. It would be a pain but put the spare in the front, even if you have to swap out the front to the back and don't put it in 4wd. I just bought a used KO2 on offer up for like $20 and once my current set wears out ill just have the tire shop put the best 285 on the spare and chuck the used KO2. Spare tire is supposed to get you home / shop. Should't use it beyond that.
bigmace is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 06:52 PM #11
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Enlighten me on why not on the rear of a 4wd??? Assuming you are not using 4wd.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 09:02 PM #12
83Mule's Avatar
83Mule's Avatar
No issues on the front in 2 wheel at all..........and the bigger the variance the quicker you need to fix it and the slower you need to drive until doing so on the rear. I would drive it home or to the Tire shop within 20 miles, no sweat. If you need to do 100 miles home on the Freeway, put it on the front.
Old 06-25-2019, 11:14 AM #13
technically it's likely not going to hurt anything as that's what a differential is for, but it's easier to tell someone "run tires the same size on the same axle" than it is to add a bunch of caveats to the mix. personally if the situation allows i'd always put the spare on the front
put , rear , running , size , tires
Battery Size - Anyone running a Group 31? rickashay 4th Gen T4Rs 22 07-18-2023 07:34 PM
Can running different size tires in the rear on 96-2000 wreck the differential? Mark_BC 3rd gen T4Rs 11 01-04-2019 07:42 PM
305/65r17, anyone running this size? gago1101 5th gen T4Rs 0 05-11-2013 09:50 PM
275 70 16 Anybody running this size? jamess 3rd gen T4Rs 1 05-20-2009 01:46 PM
bolt size for 02 running boards? wiferunner 3rd gen T4Rs 0 03-23-2006 10:03 AM
