Old 06-24-2019, 11:23 AM #1
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
Was my fluid changed ?
Was my transfer case fluid changed if they pulled the transfer case?
Arnezie is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 01:11 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
There should be a section of your repair paperwork that states what was done and what materials, parts, fluids, etc. was used. Also in there should be labor hours, charges, for each operation and who did the work. Parts and operations covered by warranty should be documented as well. If you didn't get a comprehensive report; then I'd go ask the service advisor. They should have a record of what was done to your vehicle.
Old 06-24-2019, 01:45 PM #3
Arnezie's Avatar
Arnezie's Avatar
It was done last summer I bought it this spring. I was going to change it but wondering if they changed it when that warranty service was performed. So I guess my question should be can you pull a transfer case and not drain all the fluid?
Old 06-26-2019, 08:29 AM #4
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
It's possible, as the transfer case is sealed independently of the transmission...different fluids in use. I'd remove the fill plug and inspect the fluid color using a white pipe cleaner (bent 45deg).
waypoint is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 03:42 PM #5
Arnezie's Avatar
Arnezie's Avatar
I’ll do just that , good idea.
Old 06-26-2019, 03:52 PM #6
jimmied jimmied is offline
jimmied is on a distinguished road
If you’re going to do all that, just change it. You have to get to it anyway. 2 extra minutes to remove drain bolt and fill with new.
Current - 2016 Mag Gray SR5, 3rows - diode dynamics fogs, tint, FalkenAT3W, blacked out badges, more to come
Old - 2008 Black sr5 v6 - Bilstein 5100s, FJ rears, black counter steers, xenon depot h11 hid kit, Scion Radio upgrade (touchscreen), BHLM, tint, Cooper AT3s.
jimmied is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 10:41 PM #7
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
Beginner Fluid Maintenance
I also think changing it now is the best move. Here's everything you need to know about ALL the fluids!
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
case , changed , fluid , pulled , transfer
Should I have my transmission fluid changed/flushed? JoshuaHufford 4th Gen T4Rs 34 08-18-2018 01:38 PM
Transmission Fluid changed. progress4m Maintenance/Detailing 5 09-12-2011 10:59 PM
What actually happens to transmission fluid to cause it to need to be changed? Metzbower Maintenance/Detailing 6 04-24-2011 02:42 PM
never changed transmission fluid s1moore1s 4th Gen T4Rs 4 08-14-2010 08:12 PM
Who has changed their transmission fluid? nc211 4th Gen T4Rs 13 08-18-2008 10:47 AM
