Originally Posted by Arnezie
It was done last summer I bought it this spring. I was going to change it but wondering if they changed it when that warranty service was performed. So I guess my question should be can you pull a transfer case and not drain all the fluid?
It's possible, as the transfer case is sealed independently of the transmission...different fluids in use. I'd remove the fill plug and inspect the fluid color using a white pipe cleaner (bent 45deg).
