Real Name: Chris
Real Name: Chris
Originally Posted by pacemd
I just added an Accessorides remote start. When you park turn the vehicle off and remove the key. Walk away and hit the lock button three times. That will start the truck and lock the door. When you return push the unlock once, insert the key, turn to position 2, and you're good to go, with the engine still running. Only requires that you push a button two more times over normal exit and lock procedure. Oh, and buying/installing the remote start. But then you have a remote start, so there's that........
Same, I have the Accessorides remote start and will lock the door and then remote start with the air running, doors are locked, and don't need a second key. Then when I return, just hit the unlock button, get in, insert the key and drive off, works great. And installation is 100% plug and play
