Old 06-25-2019, 08:59 PM #1
andrew4r andrew4r is offline
Real Name: Andrew
andrew4r will become famous soon enough andrew4r will become famous soon enough
Real Name: Andrew
Remotely locking running vehicle from the outside
I travel a lot with my dog. There are times when I need to run in a convenience store or something and she has to stay in the 4Runner. It's getting pretty hot, so I've started leaving the vehicle running with the AC on instead of just cracking a few windows.
Using a 2nd key, I can lock the vehicle by physically inserting the key into the keyhole and locking it. Works fine. But it would be nice to be able to hit the remote lock button on the key instead. Toyota doesn't seem to want me to do this.
Thoughts?
@andyadventuring @samadventuring
'18 TRD Off-Road
andrew4r is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 09:14 PM #2
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
If this were a VW product then you could code it in, but I'm not sure if Techstream could help here.
Perhaps someone can chime in here.
But - you also need to make a sign that says "A/C is on, dog is comfy" to keep somebody from playing hero and trying to save your dog by busting a window or calling the cops.
What barrier are you using to keep the pooch in the back? Without a barrier, my GSD always ends up in the driver's seat - never the passenger seat.
cb1111 is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 09:16 PM #3
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
"The dog has the radio tuned to his favorite station, the AC is on, and he has a water bowl on the floor.
Do not break glass, you hysterical hippie shitstain."
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 09:17 PM #4
Real Name: Andrew
Real Name: Andrew
I keep the 2nd row seats folded down with a foam pad on top and she stays there.
A sign is probably a good idea. I'd hope people would hear the engine, but people often aren't bright.
'18 TRD Off-Road
Old 06-26-2019, 02:14 AM #5
pacemd pacemd is offline
pacemd is on a distinguished road
I just added an Accessorides remote start. When you park turn the vehicle off and remove the key. Walk away and hit the lock button three times. That will start the truck and lock the door. When you return push the unlock once, insert the key, turn to position 2, and you're good to go, with the engine still running. Only requires that you push a button two more times over normal exit and lock procedure. Oh, and buying/installing the remote start. But then you have a remote start, so there's that........
pacemd is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 11:42 AM #6
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Same, I have the Accessorides remote start and will lock the door and then remote start with the air running, doors are locked, and don't need a second key. Then when I return, just hit the unlock button, get in, insert the key and drive off, works great. And installation is 100% plug and play
Old 06-26-2019, 02:32 PM #7
jspagna1's Avatar
jspagna1 jspagna1 is offline
Real Name: Joe
jspagna1 is on a distinguished road
jspagna1's Avatar
Real Name: Joe
Originally Posted by KWSRStorm View Post
Its an expensive fix but compustar remote starters have a stand by feature. With the car running initiate the remote start and you can remove the key from the car (all remote key fuctions as normal like lock) then unlock hop back in, insert and turn key and hit the brake to resumse normal use.
It does have a timer though. Think its 15min maybe programable to 30
Sent from my SM-G973U using Tapatalk
This is the route I took for this exact issue.
2012 Nissan Maxima SV Premium/Tech. Package Winter Frost Charcoal Leather
2011 Toyota 4Runner SR5 4x4 Blizzard Pearl Graphite Sport Cloth(4.0 Liter V6)
1966 Mustang Coupe (5.0)
jspagna1 is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 03:06 PM #8
Bill_B's Avatar
Bill_B Bill_B is offline
Bill_B is on a distinguished road
Bill_B's Avatar
Man, I don't have any input as to how to do this... only a story that almost ruined a 2600 mile road trip about 600 miles in.
Back in September we were on our way to Maine and stopped at Lake George near Adirondacks... we were parked in a public parking area. We had our chi with us on this adventure, we take him everywhere! It was a nice cool evening, about 65* if I remember correctly, sun was basically completely set and the car was nice and cool. I left the sunroof open because nobody can see it, and the back window down slightly.. you can't tell because of the spoiler of the 4r. We walked about the equivalent of 2-3 blocks to get ice cream, got our ice cream and literally walked back to the car while eating our ice cream (this was roughly 15 mins TOPS!).
When I arrived back to our 4runner it was surrounded by 3 irate elderly women, one with a giant piece of curb or rock in her hand... and 3 park rangers with the a police officer literally driving up to the scene.
My dog was so worked up because these aholes were standing there screaming the entire time we were gone. Apparently she told the park rangers multiple times she was going to break my windows to free my dog.
At first the cop gave me a hard time until he realized my sunroof was wide open and the back window was cracked by about 3", and my dog was left with a full water dish... quickly diffused the situation.
Always a hero out there.. and I realize that in some situations it applies, this however was not one of them and would have ruined our entire vacation had this idiot busted our window.
Bill_B is offline   Reply With QuoteReply With Quote
Old 07-06-2019, 02:26 AM #9
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Thoughts?
I was hoping someone would have a solution for locking the door for when my dog is inside the 4R and I have to run in somewhere. Thanks for your post!
pointman is offline   Reply With QuoteReply With Quote
key , lock , locking , running , vehicle
Vehicle capacity weight reduced with locking rear differential? Richmond Dan 5th gen T4Rs 5 08-19-2018 01:08 PM
Proximity key + locking doors while running -JD- 5th gen T4Rs 9 03-09-2016 09:43 PM
Want to control your interior lights remotely? I have the mod for you!!! chetJ 5th gen T4Rs 4 01-24-2012 11:19 PM
Anyone/anything remotely near Spruce Pine, NC vthokie General Discussions 7 12-28-2010 03:18 PM
Doors won't unlock remotely!!! probwhite Problems & Warranty Issues 3 11-13-2007 12:20 AM
