06-25-2019, 11:32 PM
#1
Senior Member
Senior Member
When to replace spare tire?
How long can an unused spare be kept before it needs to be replaced? I know they don't last forever, and I don't want to find myself in the position of needing the spare only to discover it's no good.
Right now my spare is the stock tire that came with the vehicle. When I do replace it, I'm thinking I'll upgrade it to match the tires I'm currently running (KO2 265/70/17). As long as it's the same size it should still fit on the spare tire mount, right?
__________________
Ghost towns, mines, and more: www.raydunakin.com
2016 silver Trail Edition w/KDSS; BudBuilt sliders w/full tread plate; upgraded rear hatch lift struts;
BFG KO2 265/70/17; Gobi "no-rise" Stealth rack w/ladder; MetalTech front bumper;
King coil overs, upgraded springs, ~1.5" lift; RCI skid plates.
Megaweapon's build/adventure thread
06-25-2019, 11:39 PM
#2
Junior Member
Junior Member
Quote:
Used to be 7 years if I remember correctly. 10 Years is the new expiration date I do believe.
Yup. You can even go larger.
06-26-2019, 02:08 AM
#3
Senior Member
Real Name: Greg
Senior Member
Real Name: Greg
Quote:
Originally Posted by whtout
"Used to be 7 years if I remember correctly. 10 Years is the new expiration date I do believe... Yup. You can even go larger."
Hi whtout,
My 2012 Limited OEM, spare tire was 245/60 R20 (Geolander). I swapped those to 275/55 R20 as soon as I bought the truck. But the oem spare just barely fits in the tire well. 245=mm width.
The 55 = the carcus (sidewall height from bead to tread outer diameter) @55% of the width. and (of course); the R20 = the rim diameter "in inches"! Do you know if the FULL diameter (Height), 70% of 265 of the width will squeeze into the spare tire well; just curious?
Here's a photo of my 275/55 R20 next to the 245/60 R20; the NEW Goodyear Eagles are just off the shelf with NO RIMS on the Right. The original tires on the left ARE still inflated to 35 psi:
"...Big difference" 'Best to you',
rig
__________________
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
06-26-2019, 02:40 AM
#4
Member
Member
I was taught that I shouldn't run a smaller or larger tire on the other side of the drive wheels for more than short distances but I don't know if the 3rd gen TR4 has a limited slip with clutches to wear out on the back.
__________________
2001 2wd - Daily Driver
06-26-2019, 08:26 AM
#5
Member
Real Name: Ted A Hamilton
Member
I recall 6 and as you say, I recall an extension.
Btw there is a dot number on the sidewall that gives the week and year of mfg.
One thing I always do is check that number on new tires to make sure I’m not getting some that have sat on the shelf for years before purchase.
__________________
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
06-26-2019, 08:30 AM
#6
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Quote:
Originally Posted by rigtec
Hi whtout,
rig
I thought the same thing, but fit my 285/70R17, fully inflated without any problems. It just hangs down a little lower.
__________________
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
06-26-2019, 09:31 AM
#7
Member
Member
There is no regulatory timeframe, but several manufacturers have bulletins on the matter. In addition, Tirerack has a couple of tech bulleting on this. They can be found on the right side of the link I posted.
Remember that an underbody spare is exposed to far harsher conditions than a tire on your car. It isn't regularly exercised but while it isn't exposed to UV, it is often covered in mud and standing water will often sit on top of the tire. The wheel also takes more abuse.
06-26-2019, 09:53 AM
#8
Senior Member
Real Name: Neal
Senior Member
Real Name: Neal
From the bulletins.......
"If your customer has a matching full-size spare tire (same size and type as other in-service tires) it is recommended that it should be rotated into service as part of the regular rotation."
I think the key here is "matching size" - most of us don't buy that 5th tire when we upgrade
BFG says basically 5 years, with regular inspections for up to 5 years after that.
Goodyear (Dunlops) is very careful to say "Since service and storage conditions vary widely, accurately predicting the serviceable life of any individual tire in terms of years and/or months is not possible. "
06-26-2019, 10:26 AM
#9
Member
Real Name: Mike
Member
Real Name: Mike
I’ve read and heard that the spare tire is good for 10 years. I’m sure the quality of the tire, location of the spare and where you live (like the south west) would play a big role on the life of the spare tire.
__________________
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
06-26-2019, 10:52 AM
#10
Member
Member
Does the clock start when the tire is manufactured? Check your sidewall date on the spare.
__________________
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
06-26-2019, 11:14 AM
#11
Member
Member
I know Discount Tire won't touch a tire with a born on date olde than 10 years, so I am assuming that's the new standard, but depending on exposure and the particular tire, a lot of tires will dry rot long before then.
I have a 275/70/17 KO2 in the stock spare location on mine with no fitment issues, but I don't think you could squeeze anything larger in there. Even if you could it would likely hang too low imho.
06-26-2019, 01:39 PM
#12
Member
Real Name: Tom
Member
Real Name: Tom
I had a blowout on the front tire of my ‘01 Tundra recently, used original spare(yes 18 year old tire) to drive it home and into the shop the following AM. I drove slow and took my time. Replaced all tires, including the spare with new Nitto Terra Grapplers like what I have on my Pro. 18 year old tire, geez!
__________________
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
06-27-2019, 10:55 PM
#13
Junior Member
Junior Member
It appears a 275/55R20 tire is 31.9" tall.
My post was based on learning people are clearing 285/70R17... which is 32.7" tall.
You should have no issues mounting that size to the spare well!
I'm new to this truck but before I buy a full size spare my plan is to just take a wheel off and swap it with the spare to see if it fits. Won't take much effort and a non-emergency is a good time to practice... even if it doesn't fit.
Reason: grammar
06-29-2019, 02:19 PM
#14
Member
Real Name: Nick
Member
Real Name: Nick
I in fact just put a 285/70/17 in the spare spot. Fit with no issues. Better safe than sorry
06-29-2019, 08:09 PM
#15
Member
Member
Ray, Ten years is at the limit in a perfect world.
Judging from your photos you spend a lot of time in the desert.
Drop the spare and check the "Born on Date" along with the air pressure. If I was going where you go I would like to know my spare is in good shape. Tires have a tendency to decompose in a static state. More so in adverse climates and road conditions. They may look great but under a load they will suffer tread separation. I know this from experience.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
