Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 10-05-2019, 01:57 PM #181
Lifeline's Avatar
Lifeline Lifeline is offline
Lifeline is on a distinguished road
Lifeline's Avatar
I installed it in my 2019 ORP, and it doesn’t do a single thing. No changes at all? Any settings to change or play with?
Lifeline is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 02:20 PM #182
92westshady 92westshady is offline
92westshady is on a distinguished road
Sweet little convenience mod for so cheap!!
92westshady is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 02:41 PM #183
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
Yeah you have to leave the dimmer on the highest setting before it "clicks" into super bright setting. It adjusts the dimming automatically when your lights are on. You can test it by turning your lights on and taking your hand on and off the sensor.
CharlesNellis is offline   Reply With QuoteReply With Quote
Old 10-05-2019, 02:51 PM #184
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
Make sure your lighting control dial isn’t turned all the way to max, I suppose that would make it seem like it didn’t do anything
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 01:58 AM #185
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
to test it, do what others have mentioned with the dimmer switch set before the highest setting (before it clicks, otherwise your cluster will stay at the highest setting). turn on your headlights (or at least to the parking light setting) while sitting in your garage, and test it using a flashlight.
When it senses light from your flashlight, your cluster should go to the highest setting u set, and when you cover the sensor with your hand, it should dim down.
Old 10-06-2019, 05:43 PM #186
Lifeline's Avatar
Lifeline's Avatar
Thanks everyone, checked my dimmer and that’s what it was. Works perfectly now. Great mod for the $$
Old 10-06-2019, 08:20 PM #187
NWsuperwhiterunner NWsuperwhiterunner is offline
NWsuperwhiterunner is on a distinguished road
So will this work on a 19 TRD Off Road ?
NWsuperwhiterunner is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 08:25 AM #188
Yes.
Old 10-07-2019, 08:42 AM #189
jahdai42's Avatar
jahdai42 jahdai42 is offline
jahdai42 is on a distinguished road
jahdai42's Avatar
Thanks again fot this thread, got min and installed in 15 seconds on a 2016 Trail. Works brilliantly.
2016 Trail,
jahdai42 is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 02:20 PM #190
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Anyone with a SR5P lucky enough to get it to work?
It seems like everyone with SR5P reported of failure so far.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 04:33 PM #191
Packr12's Avatar
Packr12 Packr12 is offline
Packr12 is on a distinguished road
Packr12's Avatar
Worked in my '16 trail as well!
Sent from my SM-G960U using Tapatalk
2016 TE KDSS
Instagram @upstateoverland
Packr12 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 08:37 PM #192
snowpeak snowpeak is offline
snowpeak has a spectacular aura about snowpeak has a spectacular aura about
2020 TRD Off Road Premium. This mod does NOT work. The wiring harness in the 2020 is attached to a blank which easily pops out, but the connector is a 4 pin connector. The sensor that I received has 6 pins.
After popping out the blank, already visually different from photos posted in this thread.
Sensor, part # 89121-50020
The wiring connector to the dash
Oh well not much wasted on a $5 part. Everything snapped back in quicker than it came out.
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
snowpeak is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 10:49 AM #193
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
Damn, that sucks. I am sure someone on here will buy it from you.
tjnptel1 is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 04:21 PM #194
replica9000's Avatar
replica9000 replica9000 is offline
replica9000 is on a distinguished road
Got mine in and installed today. Works great on my 19 ORP.
2019 T4R ORP
replica9000 is offline   Reply With QuoteReply With Quote
Old 10-12-2019, 10:09 PM #195
ant the ninja ant the ninja is offline
ant the ninja is on a distinguished road
Good to know! I wonder if we just need the part number that’s on the 2020 Limited for this to work?
ant the ninja is offline   Reply With QuoteReply With Quote
change , item , light , sensor , toyota
Leaking coolant from reservoir after driving more than 15 mins jman11788 3rd gen T4Rs 17 05-11-2017 01:21 AM
Get a cheap Toyota LC emblem... 10 mins left Yoderguy 5th gen T4Rs 0 11-20-2016 01:54 PM
41 mins of pure subie rallying p0rn NoDak Off Topic 3 01-16-2015 02:31 PM
95 Ac stops working after 20 mins driving Chickenman Classic T4Rs 1 07-30-2009 10:39 PM
