Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 11-18-2019, 04:45 PM #211
pableaux's Avatar
pableaux pableaux is offline
pableaux will become famous soon enough
pableaux's Avatar
Originally Posted by Hans Moleman View Post
Anyone with a SR5P lucky enough to get it to work?
It seems like everyone with SR5P reported of failure so far.
Dang, didn't know only SR5P owners were the ones having trouble. Guess it's just us.
pableaux is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 08:42 PM #212
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
Originally Posted by jerad View Post
Well shit, I received a defective light sensor and when I tried to remote it the top popped off with ZERO pressure and the plug has now fallen back down inside the dash. I have no idea how I'm goin to get it out short of removing the window or the dash. Removing the stereo just exposes the vents...
This sucks... my Baja designs fogs aren't working, they haven't since I installed the sensor. Fuses are still all good. don't know how this is related, but it must be.
Originally Posted by KarrotJuice View Post
Feel for you dude. I have a 2018 SR5 Premium. Just installed the new sensor. Doesn't work. Didn't think to try it before putting it in the hole. No way I'm going to try and dig it out now. With a smile on my face I'm going to try and enjoy my $10 piece of plastic upgrade.
Hey everyone so I had this same problem, but I have a solution. First, Find a sturdy paper clip and bend it like a small fish hook. Next you want to fish out the wires that connect to the back of your broken plastic. Then slowly guide the clip out in reverse (you may want to tape a mirror to your windshield to see plus a little led light). The clip gives less resistance in reverse. Continue using the paper clip until you are sure it's angled properly then use gentle force to pull it out with the paper clip hook.
Next, for those that didn't use electrical tape. The trick to remove this cheap sensor is to pull it up straight up. Pushing up at one angle will replicate my problem I and others have had on this thread (making you loose your head, literally). So use floss and wrap it around then whip it up like a noose. Good luck guys
osideplayer is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 10:29 PM #213
Moltenburn Moltenburn is offline
Moltenburn is on a distinguished road
My ebay china came in yesterday works like a champ on my 19 ORP. Set light dial right below max click. Turn on head lights. Shine light on sensor, dash lights get brighter. Remove the light dash darkens up.
Moltenburn is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 11:20 PM #214
pableaux's Avatar
pableaux's Avatar
Originally Posted by osideplayer View Post
Next, for those that didn't use electrical tape. The trick to remove this cheap sensor is to pull it up straight up. Pushing up at one angle will replicate my problem and others on this thread making you loose your head. So use floss and wrap it around then whip it up like a noose. Good luck guys
Were you able to get that to work or is this just a theory? Honest question
Old 11-19-2019, 12:06 AM #215
pableaux's Avatar
pableaux's Avatar
Originally Posted by replica9000 View Post
Does anyone know if changing the sensitivity settings with Carista has any affect on non-Limited models?
Didn't work with my SR5P
Old 11-19-2019, 04:34 PM #216
2020FourRunner 2020FourRunner is offline
2020FourRunner is on a distinguished road
I bought this part for my 2020 ORP and the plug shape is completely different. I assume they changed the plug for 2020 or else I was sent the wrong part.
2020FourRunner is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 07:33 PM #217
replica9000's Avatar
replica9000 replica9000 is offline
replica9000 is on a distinguished road
Originally Posted by ElectroBoy View Post
Through Carista I can change the sensitivity settings on my 18 ORP. The changes are kind of subtle. I wanted to make the sensor less sensitive when going dark, like when temporarily driving under a dark overpass. I played around with it for a while and decided upon:
Instrument lights dimming sensitivity = Darkest
Instrument lights restoring sensitivity = Normal
Does work with my 19 ORP. I settled with dimming = darkest, restoring = darker. I think it works really well for cloudy days, but wish there was a setting beyond darkest for dusk on sunny days.
2019 T4R ORP
replica9000 is offline   Reply With QuoteReply With Quote
Old 11-20-2019, 10:43 AM #218
pableaux's Avatar
pableaux's Avatar
They changed it for 2020. Someone earlier in this thread advised of the same thing.
Old 12-13-2019, 09:23 PM #219
offshorebear's Avatar
offshorebear offshorebear is offline
offshorebear is on a distinguished road
Originally Posted by LcogRunner View Post
Found an Ebay link for a 2020 that appears to have the correct 4 pin plug with 3/4 pins active.
? 2016 - 2018 LEXUS RX350 RX450H DASHBOARD AUTOMATIC LIGHT CONTROL SENSOR OEM | eBay
I bought that one for my 2020 ORP and it works. I can leave my headlights on all the time and the infotainment system goes into day mode when its bright outside, night mode when its dark.
offshorebear is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 11:08 PM #220
Black-X Black-X is offline
Black-X is on a distinguished road
The further I venture into this T4R world, the more it makes me think Toyota is the car version of HK (firearms); “Because you suck. And we hate you”.
Black-X is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 10:17 PM #221
SKT_07 SKT_07 is offline
SKT_07 will become famous soon enough
Originally Posted by snowpeak View Post
2020 TRD Off Road Premium. This mod does NOT work. The wiring harness in the 2020 is attached to a blank which easily pops out, but the connector is a 4 pin connector. The sensor that I received has 6 pins.
After popping out the blank, already visually different from photos posted in this thread.
Sensor, part # 89121-50020
The wiring connector to the dash
Oh well not much wasted on a $5 part. Everything snapped back in quicker than it came out.
Very helpful info - thanks for sharing!
Anyone discover a knock-off sensor that works yet? The OEM price is crazy.
SKT_07 is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 01:30 PM #222
plefasu's Avatar
plefasu plefasu is offline
plefasu is on a distinguished road
plefasu's Avatar
For reference, my 2014 TEP does not have the harness attached to the dummy plug. The 2014 had some other electronic differences(e.g. clock display showing compass and range/mpg) so that may be why.
'14 Trail Premium, KDSS, ICON 3.5" Stage 3, Camburg UCA, Borla Exhaust, K&N CAI, MB Wheels, BFG KO 285/70/17, N Fab Steps
plefasu is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 01:05 AM #223
escapen escapen is offline
escapen is on a distinguished road
Thanks for this. Did this on my 2018 ORP the other day. Pulled the existing piece using the suggested credit card method, then slipped a loop of electrical tape in between the wires to ensure they didn’t fall back inside and popped on the new sensor, everything just worked.
My  mod in 5 mins.My  mod in 5 mins.
escapen is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 02:11 PM #224
LakeRunr's Avatar
LakeRunr LakeRunr is offline
LakeRunr has a spectacular aura about LakeRunr has a spectacular aura about
LakeRunr's Avatar
Can you post (or send me) a link or info about which sensor you bought? I bought one of the Tennessee ones, but it doesn't work on my 2018 SR5.
2018 Toyota 4Runner SR5 4WD, Black, 3rd row seating
Valentine 1 Gen 2/Savvy/concealed display hardwired, with custom power button. DRLs disabled. H9 / 9011 bulbs. Automatic locks disabled. Center console and glove box organized. Custom garage door opener button. Nav wire mod hack (with custom button). CarTrimHome motorized folding mirrors. Anytime backup camera with front parking camera & custom OEM-matching backlight LED.
LakeRunr is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 11:00 AM #225
tffrost's Avatar
tffrost tffrost is offline
tffrost is on a distinguished road
tffrost's Avatar
would love to do this for my 2020 ORP. Is there a known factory part# that works and will fit the 4pin set up that snowpeak posted?
tffrost is offline   Reply With QuoteReply With Quote
change , item , light , sensor , toyota
Leaking coolant from reservoir after driving more than 15 mins jman11788 3rd gen T4Rs 17 05-11-2017 01:21 AM
Get a cheap Toyota LC emblem... 10 mins left Yoderguy 5th gen T4Rs 0 11-20-2016 01:54 PM
41 mins of pure subie rallying p0rn NoDak Off Topic 3 01-16-2015 02:31 PM
95 Ac stops working after 20 mins driving Chickenman Classic T4Rs 1 07-30-2009 10:39 PM
