Originally Posted by LakeRunr
Great info! Thanks for posting this.
Do you have the part # for these "repair terminals"? Are they the typical "repair wire" that Toyota sells, with the terminal and 6 inches of wire already attached?
I might be able to find the Japanese OEM plain terminals for these if I have the repair wire part #.
And can someone post a picture of where the F9 connector is?
So are you saying that, of the 6 pins on the light sensor, only 3 are used total?
I didn't get the repair terminal part number, but they did have it in the system at the Toyota parts counter. When the parts lady said they were $20 each and special order, I started evaluating other options. It did sound like the standard repair with 6" of wire lead though.
I looked for quite a while trying to find the terminal part numbers with no success - I don't think anyone has figured them out. If your able to find the correct, I would be quite interested.
My suspicion is that the connector is so tiny, fragile and finicky ( I tried taking it apart to inspect the terminal locking mechanism), that Toyota doesn't want you messing with it.
Two more of the pins on the light sensor (1 and 2) if i recal, go to the automatic HVAC if you have it. The last connector is not used.
