Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 12-21-2020, 12:33 AM #406
Espresso_OI Espresso_OI is offline
Espresso_OI is on a distinguished road
Originally Posted by Saker View Post
So after reading post #55 @ElectroBoy I decide to order a 89121-30020.
Will see if this will work or not!
Out of curiosity, any luck in finding this sensor for cheap?
*regarding the tabs, I think earlier in this thread the recommendation was to use electrical tape so they don't lock. But if it works, not sure you would ever have to remove the thing ever again.
Espresso_OI is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 01:14 AM #407
gakattack gakattack is offline
gakattack is on a distinguished road
Got mine from fleabay and works great on my 2018 ORP
Gen 5.5 ORP, B5 S4 Tial605, Gen 5 Maxima
gakattack is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 02:55 AM #408
ElectroBoy's Avatar
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
ElectroBoy's Avatar
Real Name: Mark
Yes, the sensors are very low tech, if they work from the start thereís not much that can go wrong.
The tape method seems like a good idea to pull back those tabs a little. Or maybe twist a wire around them, in case the tape softens up on the hot dash and the tabs break through and latch tight. Or trim the tabs in a way that they only grip a little. Or trim all of the tab contact area away and rely on a small dab of a low strength adhesive to hold the sensor in place.
@Saker , please let us know what you discover. I wish Iíd done something to the tabs to make future removal possible. I just tested it then snapped it into place.
1st Gen 1987 T4R, sold at 180K miles
3rd Gen 2000 SR5, sold at 239K miles
5th Gen 2018 ORP, just interior mods
Old 12-21-2020, 11:46 AM #409
Saker's Avatar
Saker Saker is offline
Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold
Saker's Avatar
@ElectroBoy
I took photos of the connection yesterday and it was the white 8 pin connector. When I get the sensor in, test it, Iíll report my findings.
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 12-27-2020, 03:14 PM #410
rlporter507 rlporter507 is offline
rlporter507 is on a distinguished road
dont work on mine??
i put the sensor in a 18 sr5p and it works no different than without it. When i turn on the nav and then the lights, it dims with or without the sensor. i was hoping it would dim the rear camera, i put led backup lights in and now the dash is to bright at night backing up. it made no difference in the radio panel also. i dont usually drive with the nav screen.
rlporter507 is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 04:48 PM #411
Saker's Avatar
Saker's Avatar
You should have a brightness adjustment for both of those screens aside from the sensor.
Best Regards,
Saker
Old 12-28-2020, 03:23 PM #412
Saker's Avatar
Saker's Avatar
@ElectroBoy
So here are my findings:
The sensor only has 3 pins.
I tested it and it works as you describe in post #55!
Confirm my part # with photos.
Best Regards,
Saker
Old 12-28-2020, 03:58 PM #413
Nice - and thank you for the confirmation! Any luck finding it below $50? Even on Ebay that part # isn't cheap
Old 12-28-2020, 04:14 PM #414
Saker's Avatar
Saker's Avatar
No, I think it was 80+.
Best Regards,
Saker
Old 12-28-2020, 04:18 PM #415
Saker's Avatar
Saker's Avatar
BTW, I cut the upper part of the retaining clips that locks the sensor in.
So, it is held in by the clip pressure only.
If I wanted to remove it, Iím sure I could just pry it up and out!
Best Regards,
Saker
Old 12-28-2020, 06:02 PM #416
ElectroBoy's Avatar
Real Name: Mark
ElectroBoy's Avatar
Real Name: Mark
Good job, mon. So it looks like itís a 4-pin connector but only 3 pins are populated.
Old 12-28-2020, 06:40 PM #417
ElectroBoy's Avatar
Real Name: Mark
ElectroBoy's Avatar
Real Name: Mark
In a previous post by @xyzzy he posted a summary chart of which models will work with the light detectors. It doesn’t work in your 18SRP. Most likely because the harness wires are not connected.
https://www.toyota-4runner.org/3566171-post383.html
In an early post of this thread it was discovered that some models have the wires in the connector plug but they actually don’t terminate anywhere on the other end. For these models there was a solution described and designed by @Old Red where wires were added to connect to the MPX Body ECU and enable the light sensing/dash dimming function. Unfortunately a lot of his posts got deleted from this forum and I can’t find them. Maybe someone who has done this repair can chime in if they still have the instructions.
Old 04-02-2021, 05:13 PM #418
j-dub j-dub is offline
j-dub is on a distinguished road
Quick update,
I ordered a used 89121-30020 on eBay for $52 and installed it on my 2021 SR5 and it is working just like I understand that it should. I will test it more over the next few days as I try different driving scenarios such as driving at night and driving into dim parking structures but so far I can get the nav screen to dim by simply putting my hand over the light sensor.
I have not made any Entune menu settings like described in post #55 by @ElectroBoy yet, it seems that my menu is a bit different.
Thanks to all that have contributed to this thread, no more blinding nav screen when I start the vehicle at night.
j-dub is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 07:14 PM #419
ttime4four ttime4four is offline
ttime4four is on a distinguished road
Apparently, I failed and didn't read enough of the tread to learn that I needed a different part for my '21 ORP.
So - I have the pre-2020 fitment purchased from eBay if someone wants one. HMU if you want the 89121-50020 for $15 shipped.
2021 SuperWhite ORP
ttime4four is offline   Reply With QuoteReply With Quote
change , item , light , sensor , toyota
Leaking coolant from reservoir after driving more than 15 mins jman11788 3rd gen T4Rs 17 05-11-2017 01:21 AM
Get a cheap Toyota LC emblem... 10 mins left Yoderguy 5th gen T4Rs 0 11-20-2016 01:54 PM
41 mins of pure subie rallying p0rn NoDak Off Topic 3 01-16-2015 02:31 PM
95 Ac stops working after 20 mins driving Chickenman Classic T4Rs 1 07-30-2009 10:39 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
