Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 07-17-2019, 02:06 PM #91
DreamsOfDirt's Avatar
DreamsOfDirt DreamsOfDirt is offline
DreamsOfDirt will become famous soon enough DreamsOfDirt will become famous soon enough
Tabs
Originally Posted by ElectroBoy View Post
Yeah. I was worried about that too. The clip-in tabs for the dummy plug are totally different than the light sensor tabs. It will require dash disassembly to remove a failed unit. Better test it with a flashlight before snapping it into place.
Is there a reason one couldn't just break or cut the tabs off the new sensor and set it back in the hole. I get it wouldn't be 100% secure but based on the pic I'm guessing it will vibrate a little but it seems like it would take a lot of bouncing to get it to pop out of the dash. Am I missing anything with this logic?
2018 TRDORP w/KDSS, Cooper AT/3s, Rago cross bars, TRDP Black wheels, front grille, black valances, Kenwood Excelon DNX996, working on the rest...
DreamsOfDirt is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 02:09 PM #92
mc1986 mc1986 is offline
mc1986 is on a distinguished road
I just ran some electrical tape around the tab to keep it from getting locked in by the tab.
mc1986 is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 03:39 PM #93
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Just got my sensor and unfortunately I do not have the necessary wiring under the steering for this sensor to work.
2015 SR5 PREMIUM
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 04:59 PM #94
jsun_2k's Avatar
jsun_2k jsun_2k is offline
jsun_2k is on a distinguished road
jsun_2k's Avatar
Originally Posted by emmantik View Post
I found it easier to use a credit card and pry from the window side of the dummy cap. There seems to be a bit of a lip exposed enough to insert a credit card and lift up.
it was a 1-minute job, thanks for the tips
2015 SR5 PREMIUM
Just got my sensor and fortunately I do have the wiring harness but not sure if it is working yet.
2017 sr5p
That's exactly what I did
jsun_2k is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 05:00 PM #95
IndyFastlane's Avatar
IndyFastlane IndyFastlane is offline
IndyFastlane is on a distinguished road
Thanks to the OP for posting about this. I ordered the cheapest sensor I could find and it took a couple of weeks to arrive. Works like a charm! I recently changed out all of my signal bulbs to LED with the fronts being switchbacks.
I now have three lighting options without having to worry about adjusting dash lights day/night.....
1. DRL only
2. Parking lights (my DRL is now disabled when parking lights are on through the use of a 5pin relay). I can leave the parking lights on all the time and rely on the switchbacks for DRL.
3. Headlights on.
Thanks again OP!
2018 TRD Off Road Prem
Indianapolis
IndyFastlane is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 11:46 PM #96
jerad jerad is offline
jerad will become famous soon enough
Well shit, I received a defective light sensor and when I tried to remote it the top popped off with ZERO pressure and the plug has now fallen back down inside the dash. I have no idea how I'm goin to get it out short of removing the window or the dash. Removing the stereo just exposes the vents...
This sucks... my Baja designs fogs aren't working, they haven't since I installed the sensor. Fuses are still all good. don't know how this is related, but it must be.
16 TEP Mag Grey
jerad is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 04:51 PM #97
KarrotJuice KarrotJuice is offline
KarrotJuice is on a distinguished road
Feel for you dude. I have a 2018 SR5 Premium. Just installed the new sensor. Doesn't work. Didn't think to try it before putting it in the hole. No way I'm going to try and dig it out now. With a smile on my face I'm going to try and enjoy my $10 piece of plastic upgrade.
KarrotJuice is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 06:20 PM #98
Welp, I did get it out today, since the top popped off, I was able to fish the wires out of the dash using a bent coat hanger. I unplugged the blue factory harness and the light sensor base just fell down in the dash. I put the factory cap back on.
The fog light/running light issue was a blown fuse under the dash. I just installed a redarc trailer brake the same time I did the light sensor and must have popped it then. So it seems to be a compound problem.
16 TEP Mag Grey
Old 07-21-2019, 06:41 PM #99
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Originally Posted by Beach5150 View Post
When I first installed my sensor, I tested it with a LED flashlight in the garage, and nothing, it didn’t seem to work (thumbwheel not clicked up).
A few days later, I changed the brightness setting in Carista, and now it works great. I had originally posted that it didn’t work.
Just wanted to say thanks. Didn't know what "Carista" was in your post and then found out. Amazing stuff. Glad I don't need to make a trip to the dealer and can do all the customization on my own.
pointman is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 07:17 PM #100
I can confirm on my 18 SR5 Premium that it doesn't have the MPX Body ECU wired for it. Lazy me didn't check it before installing the new sensor. That being said, is there going to be an issue just leaving it wired up in the dash? It's going to be a ***** trying to dig it out without breaking and scratching.
Old 07-22-2019, 10:12 AM #101
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
Don't see how that is an issue, leave that sucker in there. Sorry it didn't work out.
tjnptel1 is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 12:30 PM #102
ravens_wood ravens_wood is offline
ravens_wood will become famous soon enough ravens_wood will become famous soon enough
damn, i wish i read this thread before popping mine in. smart idea. at least the sensor works...for now
ravens_wood is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 12:55 PM #103
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
1. DRL only
3. Headlights on.
Thanks again OP!
Can you explain this please? Especially #2
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 02:42 PM #104
aabottom aabottom is offline
aabottom is on a distinguished road
PRO Tip: Put a pipe cleaner or a string in-between the wires of the connector BEFORE you take the dummy sensor off. Then if you drop the connector, it won't fall down the hole.
I ordered the $6.83 (free shipping) light sensor from China on July 5 and received it in the US mail on July 17, that's 12 days. I'm still testing to see if it works as expected.
I'll leave the light sensor out of the hole until I see it working properly. Likely, I'll put some electrical tape on the clips of the light sensor before I put it back in.
My  mod in 5 mins.-litesensort4r16a-jpg
2016 Toyota 4Runner SR5 Premium 4WD Sliver
R.I.P.: 1999 Toyota 4Runner SR5 4WD V6 5Speed_Manual Red
aabottom is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 09:27 AM #105
Zmartin19 Zmartin19 is offline
Zmartin19 is on a distinguished road
Originally Posted by SwayzeExpress View Post
Thank you for this!
Ebay for 89121-50020 works perfect on a 2016 TEP
So this model number works even though the 4Runner model number is -06020?
2016 White TEP w/o KDSS, 15% tint on front windows, 35% on all others including windshield (all ceramic), temporary Daystar lift, Gobi rack with 40" E series light bar and two 6"srq lights out back, RCI sliders without tread plate, and Bussmann aux fuseblock custom built to power all accessories
Zmartin19 is offline   Reply With QuoteReply With Quote
change , item , light , sensor , toyota
Leaking coolant from reservoir after driving more than 15 mins jman11788 3rd gen T4Rs 17 05-11-2017 01:21 AM
Get a cheap Toyota LC emblem... 10 mins left Yoderguy 5th gen T4Rs 0 11-20-2016 01:54 PM
41 mins of pure subie rallying p0rn NoDak Off Topic 3 01-16-2015 02:31 PM
95 Ac stops working after 20 mins driving Chickenman Classic T4Rs 1 07-30-2009 10:39 PM
