06-27-2019, 04:40 PM
#31
Originally Posted by 97BlackAckCL
I believe the SR5 Premium and Off Road Premium are the only ones wired for it
I have an SR5 PREM, will check when I have a chance and report back.
Don't really care much about having my dash lights dim or not but would like to give this a shot just cause it's cheap and easy to do.
2015 Magnetic Gray SR5P
06-27-2019, 06:01 PM
#32
How exactly does this work? It's a sensor that will detect ambient light to automatically turn on the headlights? If so, what position do you put the headlight stalk on?
06-27-2019, 08:01 PM
#33
It has nothing to do with the headlights, only the interior lighting.
06-27-2019, 09:00 PM
#34
It will automatically dim or brighten dash lights based on daytime/night time. I work shift work and have darkened windows. I have to roll my windows down to back in the drive when coming home before daylight because the head unit screen nightblinds me. Im looking forward to this! Like really looking forward to it!
And yes, I could also make use of better reverse lights!
06-28-2019, 03:46 AM
#35
this mod is good during dusk and dawn driving, and if you have to go through tunnels or parking garages, since it adjusts your instrument cluster to ambient light when you have your headlights on.
As I mentioned in another thread, toyota was being really cheap by not including it, but went through the trouble of having wiring harness already installed (for most years) and a fake plug made for it.
06-28-2019, 05:56 AM
#36
We were commenting the other day that a $40k truck ought to come with this.
Tagging this thread to see if this mod works as "plug and play" in a '19 Off Road (non-premium).
Had to do some searching but just figured out how to change the GPS Navigation screen to Night mode.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
06-28-2019, 06:02 AM
#37
would you mind sharing how to change the GPS Navigation screen to Night mode?
It has bothered me the most, thanks!
06-28-2019, 06:10 AM
#38
Link:
Navigation Screen Night Mode?
I still need to go out and mess with it but that thread will give you step by step.
Edited add: turning the dial, located on the dash to left of the steering wheel, off high did the trick. Now with the headlights on I have night mode on the Nav screen.
Also set my door locks up so the doors stay locked (from the outside) when the vehicle is placed into park.
06-29-2019, 01:02 AM
#39
I got the sensor after seeing this post, but when i took out the plug i couldnt see any wires, i have a 2014 sr5 premium, is it hidden? Did you had to fish it out?
Sent from my ONEPLUS A3000 using Tapatalk
06-29-2019, 01:05 AM
#40
Also, on a similar issue, what is your truck wired to but doesn't have the end piece/hardware?
06-29-2019, 09:42 AM
#42
Originally Posted by tjnptel1
T4R.org has helped me in so many ways, I am really thankful for this board. I had recently made a thread about things I wish Toyota would change in the 4Runner and one of the take aways is an automatic way to change the ambient lighting by adding a light sensor to the non-TRD Pro/Limited trucks. A user on here posted a link to the ebay sale that had the sensor for $5 vs. $100 at the dealer. The item took 5 weeks to come in and granted it doesn't have at Toyota stamp on it, it is identical.
does this sensor work when the headlight is on or off or both? thanks!
06-29-2019, 02:16 PM
#43
Real Name: Justin
Real Name: Justin
so does this switches the navigation / Buttons from light to dark mode ???
cuz I think my 2014 Trail Premium has this
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
06-30-2019, 09:45 PM
#44
Worked on my 2019 off-road premium. Surprised that Toyota went through the trouble of connecting the harness to a dummy.
07-01-2019, 09:19 AM
#45
Real Name: Chris
Real Name: Chris
Installed my $8 sensor from Kentucky yesterday, install literally took 30 seconds. I spent the most time ensuring that I had the connector pins lined up correctly and then snap. Do you have to enable night mode on the GPS? Any other settings I need to enable?
