Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 01-11-2020, 10:57 PM #241
Biigg50's Avatar
Biigg50 Biigg50 is offline
Biigg50 is on a distinguished road
Biigg50's Avatar
My $5 mod in 5 mins.
I did mine today. Easiest mod yet! ‘16 trail and the wire was in the back of the dummy cover, plugged into my eBay sensor and now my dash lights and nav screen auto adjust. Awesome!
Sent from my iPhone using Tapatalk Pro
Biigg50 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 06:30 PM #242
clintg clintg is offline
clintg is on a distinguished road
I don’t have the stock harness (nor the wires that go into the main body ecu) so I’m going to add a direct patch. To do this I’ll need the stock connector, some wire, and the terminal pins (I already have the sensor).
The connector and wires aren’t a problem, but I’m having trouble locating the correct part number for the terminal which need to be added to the main body ECU. The pins need to be added to connector F9 (part number 90980-12753).
Unfortunately, I can’t (nor can the dealer) find the correct part number for the replacement or repair terminals. The dealer was able to find a terminal that “might be” the correct one, but at $40 each (x4), this is a cost prohibitive hunch.
Does anyone have the correct Toyota part number and/or manufacturers name and part number?
Thanks
clintg is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 09:56 AM #243
Jlpskydive Jlpskydive is offline
Jlpskydive is on a distinguished road
One more SR5P confirmed not to work. 2017
Jlpskydive is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 10:37 AM #244
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Checked mine. Wires connected to a blank plug.
Ebay photosensor ($7) inbound.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 05:11 PM #245
wps72701 wps72701 is offline
wps72701 is on a distinguished road
Thumbs down
Mine did not work 2018 SR5P, but wire was there.
wps72701 is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 05:13 PM #246
Whippersnapper02's Avatar
Dimmer set to under the maximum brightness click?
Old 01-22-2020, 02:14 PM #247
4RDoc 4RDoc is offline
4RDoc is on a distinguished road
Thumbs up
Wow-this worked for me and pretty nice addition to my 4R.
Thank you all for sharing this mod.
4RDoc is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 06:07 PM #248
Finally got around to adding the missing wiring harness today. Since both the BCM and light sensor wiring harnesses were missing, I used a Remote Start T-Harness to add the pins to the BCM connector. The harness I used was iDatalink ADS-THR-TL7, which is meant for the Push-To-Start model (even though my vehicle uses the G Key), but the F9 T-Harness can be recycled from this kit.
Good news is that adding the sensor and wiring to a SR5 does function as expected; dash lights and navigation react to light changes.
So, anyone who's install didn't work, you might want to look and see if pins 20,21 and 22 are populated on the middle BCM plug (F9).
Next up... trying to add auto headlights.
Old 01-25-2020, 06:27 PM #249
Yep, wire was there, but turn on the lights and it goes dim in broad daylight.
Old 01-25-2020, 07:18 PM #250
SKT_07 SKT_07 is offline
SKT_07 will become famous soon enough
Still hoping they begin selling a 2020 sensor at this price point.
SKT_07 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 07:23 PM #251
Chvscks319 Chvscks319 is offline
Chvscks319 is on a distinguished road
Would love to get auto headlights. My wife's biggest complaint I'd say.
Chvscks319 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 07:29 PM #252
Did you check for both wires?
The connector that plugs into the sensor is only half of the harness. the other half plugs into the BCM.
Old 01-30-2020, 10:33 AM #253
4rCOLA1 4rCOLA1 is offline
4rCOLA1 is on a distinguished road
2020 Limited Light Sensor
The dash sensor in my 2020 Limited is a real sensor.
When I was trying to remove it, the top cover came off. It has a couple of small chips and some clear gel in it.
I could not get the sensor out using the credit card tricks and such - it is just too tight.
What is this sensors function?
4rCOLA1 is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 11:20 AM #254
Why are you trying to remove it? The entire plug should pop out, not just the ‘cover’.
Sensors function has been discussed in great length...
Old 01-30-2020, 11:31 AM #255
The consensus was that the sensor was a blank plug and could be replaced with the aftermarket sensor as discussed in this thread. It is not a blank plug and I can not tell if it is controlling anything?
Hit it with a light or cover it up and my nav screen lighting does not change?
change , item , light , sensor , toyota
Leaking coolant from reservoir after driving more than 15 mins jman11788 3rd gen T4Rs 17 05-11-2017 01:21 AM
Get a cheap Toyota LC emblem... 10 mins left Yoderguy 5th gen T4Rs 0 11-20-2016 01:54 PM
41 mins of pure subie rallying p0rn NoDak Off Topic 3 01-16-2015 02:31 PM
95 Ac stops working after 20 mins driving Chickenman Classic T4Rs 1 07-30-2009 10:39 PM
