Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 02-13-2020, 11:54 PM #286
jedraz's Avatar
jedraz jedraz is offline
jedraz is on a distinguished road
jedraz's Avatar
Did this in my 2019 TRD OR, worked great, thanks!
jedraz is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 02:18 AM #287
BWFBezerk's Avatar
BWFBezerk BWFBezerk is offline
BWFBezerk is on a distinguished road
BWFBezerk's Avatar
Did it to my 2017 OR non premium. Works awesome!
Sent from my SM-G975U using Tapatalk
BWFBezerk is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 09:20 AM #288
SKT_07 SKT_07 is offline
SKT_07 will become famous soon enough
Originally Posted by Skikodiak View Post
I did a ski trip to Whistler, BC in January and had snow in Vancouver. I had my headlights on in daylight due to the road conditions. It was very hard to see my GPS due to it was too dim. This mod fixes that....
You also could have simply reached over w/ your left hand, at any time, and rotated the dash light dimmer switch until it ‘clicks’ at the brightest setting...
SKT_07 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 12:43 PM #289
trickinit trickinit is offline
trickinit is on a distinguished road
Originally Posted by calimattSR5 View Post
2020 SR5 Premium here.
I popped the plug and found the wire below. The connector was the flat 4 prong version. I ordered the Lexus part # 89121-30020 from a seller on Ebay that took it out of a car. The price was $85 w/ tax & shipping.
I installed it on Monday and it fit correctly and snapped into place. Highly recommend this mod since the Carplay screen is too bright at night when the interior lights are set to max.
After adjusting the interior light setting to just under Max setting, the sensor works dimming the radio during the day and increasing brightness at night.
Such a simple fix, smh Toyota for not including it...
I also have a 2020 SR5 Premium and it's great to know that this mod will actually work on it. I just wish the price wasn't so steep.
trickinit is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 05:28 PM #290
frasc frasc is offline
frasc is on a distinguished road
Yeah, it sucks that it isn't $5. But I leave my headlights on all the time so it was worth it. Adjusting the dial every time was a real PITA. Made an offer on ebay for $65 shipped and the guy accepted it.
frasc is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 04:27 PM #291
4xColt 4xColt is offline
4xColt will become famous soon enough
I just installed the light sensor in my 2020 TRD ORP and so far so good.
I did have a question:
The old sensor had only two wires and the new one has four. Is there any chance it has four to potentially control the auto on/off headlight function?
Here is the link to the one I purchased.
Colt
2020 Runner TRD Offroad Premium w/KDSS and Moonroof | RSG Sliders | TRD Pro Rims | BFG KO2s | Hikari Ultra (Low and High) | Toyota OEM Black LED Fogs | Focal IS 690 with EOM audio tweeters | Focal IC 165 | OEM Audio Plus System 500 with Dedicated Sub Amp
4xColt is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 01:47 PM #292
LakeRunr's Avatar
LakeRunr LakeRunr is offline
LakeRunr has a spectacular aura about LakeRunr has a spectacular aura about
LakeRunr's Avatar
Originally Posted by clintg View Post
Attached is a picture of the connectors going into the BCM (the F9 connector is the middle connector of the row of three connectors). The second picture is of the F9 connector removed. The front most corner with an empty terminal is pin 19, with four more empty terminals (20, 21, 22 and 23) beside it.
If you have the sensor on the dash, but are missing the pins in the BCM, then you would need to either fill on the connections on the FG1 connector (not previously mentioned, but appears to be buried behind the dash against the firewall), or splice the wires from the sensor and patch them directly into the BCM.
This is exactly the situation in my 2018 SR5. F9 connector is missing wires in positions 20-22. I'll have to get my eyes on the FG1 connector to see how I want to handle this.
2018 Toyota 4Runner SR5 4WD, Black, 3rd row seating
Valentine 1 Gen 2/Savvy/concealed display hardwired, with custom power button. DRLs disabled. H9 / 9011 bulbs. Automatic locks disabled. Center console and glove box organized. Custom garage door opener button. Nav wire mod hack (with custom button). CarTrimHome motorized folding mirrors. Anytime backup camera with front parking camera & custom OEM-matching backlight LED.
LakeRunr is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 07:10 PM #293
clintg clintg is offline
clintg is on a distinguished road
A simple solution for adding the terminals is to fold over the end of a new solid wire (opposed to stranded). The folded end supposedly locks into the connector cavity similar to a terminal. I wouldn’t consider this a permanent solution, but perhaps is sufficient to prove that you bcm will react to the sensor as expected.
The iDatalink t-harness is the only “proper” solution I know of.
clintg is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 08:06 PM #294
LakeRunr's Avatar
LakeRunr's Avatar
The folded wire thing is a kludge. Never gonna happen in one of my vehicles.
I've already ordered the iDatalink t-harness from Best Buy. Thanks for the tip on that! And it seems that I already have the wires to the light sensor itself, but I haven't looked for the FG1 connector yet. My guess is that it's a dead end. I'll probably just end up tapping into the light sensor's wire harness (between the sensor and FG1) and running a jumper over to the new T-harness.
Old 02-26-2020, 03:57 PM #295
numbay numbay is offline
numbay will become famous soon enough
Originally Posted by KAPSIG1 View Post
Calling 2 dealers with a PRO Vin
The 2020 part
Ambient light sensor
New number 89121-0E060
89121-30020 succeeds to this new number
I wonder if 89121-12010 will fit 2020 ORP. It has 3 pins and my ORP has 3 wires just like pictured.
numbay is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 04:00 PM #296
Pictures here
My  mod in 5 mins.-20200225_220833-small-jpg  My  mod in 5 mins.-20200225_220903-small-jpg
Old 02-26-2020, 08:59 PM #297
LakeRunr's Avatar
LakeRunr's Avatar
I looked for quite a while trying to find the terminal part numbers with no success - I don't think anyone has figured them out. If your able to find the correct, I would be quite interested.
Well, this is odd. The F9 connector lacks the tiny 5-digit number that (up until now I thought) every Toyota connector has on it. I checked mine this past weekend. So no joy on the terminals
Old 02-26-2020, 11:22 PM #298
SICKwidIT SICKwidIT is offline
SICKwidIT is on a distinguished road
Is this a successful mod for a 2015 SR5 Prem? I remember reading that SR5 owners had issues.
15 SR5 4WD
SICKwidIT is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 12:31 AM #299
pableaux's Avatar
pableaux pableaux is offline
pableaux will become famous soon enough
pableaux's Avatar
Haven't seen a successful SR5 yet.
pableaux is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 11:57 AM #300
KAPSIG1 KAPSIG1 is offline
KAPSIG1 is on a distinguished road
How long did it take to arrive?
KAPSIG1 is offline   Reply With QuoteReply With Quote
change , item , light , sensor , toyota
Leaking coolant from reservoir after driving more than 15 mins jman11788 3rd gen T4Rs 17 05-11-2017 01:21 AM
Get a cheap Toyota LC emblem... 10 mins left Yoderguy 5th gen T4Rs 0 11-20-2016 01:54 PM
41 mins of pure subie rallying p0rn NoDak Off Topic 3 01-16-2015 02:31 PM
95 Ac stops working after 20 mins driving Chickenman Classic T4Rs 1 07-30-2009 10:39 PM
