10-10-2020, 12:10 PM
#361
Originally Posted by blschaefer1
Interesting website
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
10-15-2020, 04:44 PM
#362
Finally installed this, a year later. Found a Swiss Army Knife Can Opener worked better than a credit card.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
10-16-2020, 12:16 AM
#363
That is a neat little mod you got yourself!
10-27-2020, 05:47 PM
#364
Auto off headlights.
I swear before installing this sensor my 4Runner would buz / ring at me to turn off my headlights.
Now that ring is gone and the headlights turn off on their own.
Anyone else notice this or have I always had auto off head lights.
10-28-2020, 06:40 AM
#365
Interesting if it provided headlight Auto Off. I read a bunch on this mod but I have not heard anyone mention it. I would do the mod if it did.
If I use DRL’s they do shut off by themselves when I turn off the vehicle.
Sunroof
10-28-2020, 07:51 AM
#366
If you have your headlights on and turn off your Runner does a buzzer go off?
I would swear only my DRL's were auto off previously.
10-28-2020, 09:36 AM
#367
Real Name: Todi
Real Name: Todi
Or a paint can opener Hyde Tools 46455 Paint Can Opener - Hyde Tools . Bought mine from Home Depot
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
10-28-2020, 02:30 PM
#368
The headlights already go off automatically either after 2 pushes of the key fob door lock or 30 seconds after the key fob door lock is pressed once.
I guess I can quit turning them off myself when I turn off the car.
There is no chime/warning unless you try to lock the doors with the key fob and one is open.
Sunroof
10-28-2020, 11:48 PM
#369
Did this in my 19 ORP and it took about 2 minutes with one of those plastic panel removal tools. Didn’t scrape any of the plastic and popped the new one in. Works well. Thanks for the post OP!
10-29-2020, 07:58 AM
#370
Real Name: Todi
Real Name: Todi
So your premium did not have the sensor either??? I thought only the non-premium models are missing it...
2018 TRD OR
10-29-2020, 08:52 AM
#371
mine is a premium and it was missing it.
10-29-2020, 11:19 AM
#372
Real Name: Chris
Real Name: Chris
So after installing my Alpine head unit, I figured that I didn't need this sensor anymore, but turns out that the gauges still dim when you flip on the headlights during the day which it never did before, I thought this was all tied through the head unit, so I learned something new
11-06-2020, 07:55 PM
#373
Real Name: Jeff
Real Name: Jeff
Originally Posted by clintg
Finally got around to adding the missing wiring harness today. Since both the BCM and light sensor wiring harnesses were missing, I used a Remote Start T-Harness to add the pins to the BCM connector. The harness I used was iDatalink ADS-THR-TL7, which is meant for the Push-To-Start model (even though my vehicle uses the G Key), but the F9 T-Harness can be recycled from this kit.
Good news is that adding the sensor and wiring to a SR5 does function as expected; dash lights and navigation react to light changes.
So, anyone who's install didn't work, you might want to look and see if pins 20,21 and 22 are populated on the middle BCM plug (F9).
Next up... trying to add auto headlights.
I have a 2018 SR5P. The sensor had the wiring but it doesn't work so I need to do the harness.
How much did you get the harness for?
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
11-06-2020, 11:52 PM
#374
I got mine for $32 from BestBuy.
2018 Toyota 4Runner SR5 4WD, Black, 3rd row seating
Valentine 1 Gen 2/Savvy/concealed display hardwired, with custom power button. DRLs disabled. H9 / 9011 bulbs. Automatic locks disabled. Center console and glove box organized. Custom garage door opener button. Nav wire mod hack (with custom button). CarTrimHome motorized folding mirrors. Anytime backup camera with front parking camera & custom OEM-matching backlight LED.
11-08-2020, 04:41 PM
#375
Sunroof
