Old 06-27-2019, 09:23 PM #1
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Webasto Parking Heater
Does anyone here on the forum have one of these installed?
For those of you who don't know about these things, they are far better than a remote start.
It is a small gasoline (or diesel) powered engine/heater that is plumbed into your cooling system. They are controlled either by a timer, by a fob (with up to a half mile range) or via an app on your phone.
The little motor fires up and warms up your coolant. Once warm, it turns on your defroster to clear your windows and warm up the interior.
Your car engine never starts, immobilizer stays on and the thing uses about a gallon of gas in 24 hours of operation.
I had these in two of my cars in Europe and they were fantastic. Back then there were no fobs or apps, but the timer was great - you set the time that you wanted the car to be warm and it would figure out when to start the thing based on the outside temps - and that was in the 80's.
Yes, they cost about double of what a remote start costs, but the gas savings, the environmental impact and the ability to run this in areas where there are "no idling" laws makes up for some of the cost. The reduced wear and tear on the engine - both for the long idling during remote start and later starting a cold engine makes up for the rest. With this device, your car is effectively "pre-warmed)
cb1111 is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 10:26 PM #2
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I'm sure these are both illegal here in CA and known to cause cancer.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 10:38 PM #3
cb1111's Avatar
cb1111's Avatar
Isn't everything illegal in California? I've yet to see anything I've bought that doesn't have a prop 65 warning.
Old 06-27-2019, 10:58 PM #4
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
California sucks, it needs to break away from the US and sink.
GripT4R is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 11:49 PM #5
epjfsa epjfsa is offline
epjfsa will become famous soon enough epjfsa will become famous soon enough
If you are really in the DC area, it just doesn't get cold enough to benefit from this. I use my remote starter maybe two dozen times a year, and even then I could really go without it. Remote start has a whole other benefit which is operating the AC during the summer. I use that to keep the dogs cool if I have to run into a store quickly.
'16 TEP
'21 Model 3 LR
epjfsa is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 10:00 AM #6
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
I have a Webasto in my diesel 80 Series Land Cruiser, and it's amazing! Idling a diesel just doesn't generate enough heat for it to ever warm up, I could cold start it at -15 or colder, and let it idle for an hour and the needle would never budge from full cold. The webasto I can trigger from my command start remote, or use the timer, let it run for 45 min and when I go out to the truck and start it, the needle come about half way to operating temp, it blows heat, it doesn't run the glow plugs which means there's enough power for the windows to roll down and up properly in the cold, it's great. I can also continue to run the heater while starting my drive home until it gets up to full temp, as getting out of the downtown after work is just more idling.
That being said, they are way more than 2X the cost of a command start, more like 4-6X depending on what you pay for a command start.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 10:23 AM #7
cb1111's Avatar
cb1111's Avatar
Good point about the AC, but DC gets plenty cold to use a pre-heater/remote start. I have to park my car out in the middle of nowhere at one of my sites and the last thing I want to do is stand out there and scrape windows.
Yes, I forgot that prices here in North America are far more - and nobody knows how to install them. A thousand Euros will get one installed in Germany. In Germany, you can even order one installed from the factory that has it integrated with your climate control controls from VW, Audi and MB.
Old 06-28-2019, 10:32 AM #8
IanB's Avatar
IanB's Avatar
In North America they seem to be used mostly for highway tractors and heavy equipment. I bought mine from a semi service shop when they had a sale on, it still ran me about $1400CAN after shipping. I don't think I'd bother with it for a gas engine as the command start will warm the engine up just fine, and a good command start is around $350 installed (2-way) unless you've got any security systems that need to be worked around. You can idle away a lot of gas for the price difference.
car , engine , remote , start , warm
Webasto Heater Discovery 5th gen T4Rs 28 01-29-2020 09:05 PM
Help in Denver? Creaky Webasto Hollandia 700 sunroof. Powder_Hound Maintenance/Detailing 1 05-14-2016 09:01 PM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Parking break/e-Parking issue kakarot 3rd gen T4Rs 11 03-25-2012 05:16 PM
Maybe OT: Parking at JFK airport long term parking ok? RaysMD 4th Gen T4Rs 6 02-25-2005 11:08 AM
