06-28-2019, 10:04 AM
Custom Subwoofer Box
I wanted to get subwoofers for my 4Runner without taking away from the usable space in the back and boxes that fit where I am putting mine can end up costing a ton of money so I have decided to make my own that go over the wheel wells in the back. If anyone has done this before or has any good advice I would love to hear it. I am at work right now but i will post pictures of what I have gotten done when I get home.
06-28-2019, 10:58 AM
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
07-01-2019, 04:10 PM
Real Name: Chris
Real Name: Chris
Originally Posted by Narat_524
haha my custom 4th gen enclosure shows up in that search
07-05-2019, 03:13 PM
If you some handywork skills and basic tools, building a fiberglass enclosure yourself is "relatively" easy albeit a little bit time consuming. Blue painters tape the rear area where youd like the sub (right pocket area in particular). Cover completely with plenty of buffer tape. Lay down some fiberglass MAT not cloth from home depot, dab with fiberglass resin. Lather, rinse repeat, until you have a few layers covering the desired area. Let it cure overnight. LEAVE CAR OUTSIDE! Resin smell will permeate garage and house and significant other will likely threaten to murder you if you dont. Remove shell. Add additional layers until content with thickness. Buy or cut 10" MDF speaker ring and glue to thick dowels and glue into position in shell. Resin pegs in for further support. Drape enclosure in felt from fabric store and glue taught to the shell. Paint resin onto the felt and let harden. Trim excess fabric from shell and lay fiberglass on hardened felt until desired thickness. Once all is cured, sand, bodyfill if needed/desired, sand some more and cut out resined cloth speaker ring inner and cut a hole for the wiring post block. Then just glue down speaker carpet to your new enclosure.
I know it sounds involved but honestly its pretty easy and WAAAAAYYY cheaper than any premade mass built phantom box you'd likely find out there.
10-24-2020, 09:59 AM
Sub boxes for 2021?
Originally Posted by halflife78
Does anyone know any shops building custom enclosures for a 2021
10-24-2020, 12:05 PM
There's nothing different back there for a 2021
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
10-24-2020, 06:09 PM
Real Name: Chris
Real Name: Chris
Which back do you have? The shelves or third row pocket?
10-27-2020, 08:28 AM
It’s a two row
10-27-2020, 09:35 AM
Real Name: Don
Real Name: Don
Here is another way to go. I have good connections with my audio place where I live. They have done numerous installs for me. I recently had them add a powered Rockford Fosgate 8inch sub box to my 19Z06. It has the sub knob to control the sub. If I need to remove it out of my trunk on the Vette it’s easy to do. It don’t take up a lot of room and you could add this I the back of the 4runner. This sub kicks ass. Don’t let it fool you because of 8inch sub. They have added a lot of these subs to full size trucks. Just a little info. My 2020 Pro already has the JBL system with the sub. I could add this if I needed more base. Not sure if there available because of the COVID going on. My audio place told me there having issues getting Rockford audio stuff. I was lucky to get one from them before they sold them out.
10-27-2020, 07:45 PM
Custom fiberglass and mdf with jl audio 10w6
2019 sr5 .eibach protruck lift with 1" top spacers in the front and 1" and 1.5" cornfeds In the rear. Jba ucas. 17x9 -12 raceline addicts 285/70/17 firestone at2. Artec full bellypan tank a-arm skids Magnaflow catback dd tail as turn lasfit switchbacks front oem led fogs morimoto 2stroke h11 9005 Blackout kit. 35% tint. Eclipse 725e jl audio c5-653 front c5-650x rear powered by 300/4 jl audio 10w6 powered by 500/2. Led bulbs in every hole.
10-28-2020, 09:41 PM
This is on my list of upgrades... Thank for the info!
10-29-2020, 03:33 PM
10-29-2020, 05:25 PM
Originally Posted by Moreno
Man, that looks great. Assume you cut out the plastic trim piece to open it up?
Wanna make another....?
10-29-2020, 06:35 PM
Real Name: Ted A Hamilton
Could not resist😉
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
