Old 01-14-2021, 04:07 PM #1
jharpphoto jharpphoto is offline
jharpphoto is on a distinguished road
Staying warm while sleeping in T4R
I’ll be taking the maiden voyage with my sleep platform soon. I’m getting a3” foam mattress for the back. I’m curious how you stay warm overnight while sleeping in your T4R. I’ve got a good sleeping bag and expect temperatures in the mid 30’s. Do you have any auxiliary heating that you use while camping?
jharpphoto is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:25 PM #2
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Foil blanket.
Wool Blankets. "Moving blankets".
Electric blanket.
I made it thru a ~-20° night with the truck off except starting once.
Used my dogs wool blankets and the moving blankets I use for the rear floor (freshly cleaned) to hang with bungees wherever I could hook them across to make "walls" to isolate windows and trap a 2nd heat layer. Picture hanging a shirt or jacket on the hooks in the rear.
They also have the portable propane heaters people use in tents, but I don't trust that whole idea. At least the cold will be more likely to wake you up.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:30 PM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
get a dog...
Old 01-14-2021, 04:32 PM #4
Forgot to mention, but there is a LOT of aftermarket sound damping, foam and "wool" in that 4R. 200 st ft of butyl/foil, doors, floor, ceiling...
Not sure it makes a difference or not, but the foil backing *should* reflect heat back in, but I also did have the blankets hung.
Old 01-14-2021, 04:33 PM #5
Originally Posted by mrblah View Post
get a dog...
Better yet, 2 or 3!
Old 01-14-2021, 04:45 PM #6
get a dog...
Or, He can go THIS route
(and sleep on the ground)
Old 01-14-2021, 04:47 PM #7
cccolin cccolin is offline
cccolin is on a distinguished road
I’ve slept in mine down to -5. You want a pad or mattress that isn’t an air pad, or is very insulated. I sleep with a 20 degree sleeping pad, and blankets, and wear thermals if it’s cold. I also have a 90 pound dog. I sleep cozy. Be careful with adding a heater. If it’s not a webasto, it can add moisture to the air, which will make you less warm.
cccolin is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:56 PM #8
AgentKooper AgentKooper is offline
AgentKooper will become famous soon enough
You indicated you have a good sleeping bag. If it's rated to 32 degrees at least, you should be fine. The main concern when camping out is getting yourself off the ground, and in your truck that won't be an issue. Bring a warm hat to put on if your head gets cold. Overnight temperature in the 30s is not too bad.
I would not use an external heat source in an enclosed space.
AgentKooper is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:58 PM #9
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Sleeping in a 4R is similar to sleeping in a tent. Besides your good sleeping bag you need a good pad system. You can lose a lot of heat by conduction to the cold ground or truck floor.
Winter campers use two pads, a closed cell foam pad on the bottom and an inflatable pad on top for comfort.
Searching the forum you will find lots of recommendations.
Try the REI site for ideas. Be aware that good gear costs big $ but you’ll get many years of service from it. I use an Exped mat over a closed cell rollup mat.
https://www.rei.com/search?q=Sleeping+pads&t=articles
Good advice in the posts above.
Plus, you should crack some windows for ventilation, and maybe run a battery operated fan. Otherwise you’ll have a foggy drippy interior by morning.
Old 01-14-2021, 06:04 PM #10
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
You can get a 2nd battery or a battery pack for an electric blanket.
You can get a chinese amazon webasto-type heater and fab some ducting to your window.
Or you can get a big, heavy, 0-rated sleeping bag.
New bag is cheapest.
I slept in freezing temps on the Mojave Road, just started it up once when the cold woke me up. I should have had a better bag.
delloro is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 06:08 PM #11
Hand warmers do go a long way...
You can buy them in bulk, cheap, or make your own.
Don't ask why I know, but if you have enough hand warmers, and your blower fan stops working, and "fresh mode" doesn't work well to push the heat thru to the windshield because of low speed, stacking hand warmers on the dash can keep you seeing enough by heating wipers and the lower windshield. (Before the heated wiper rests)
Old 01-14-2021, 07:20 PM #12
3kushn's Avatar
3kushn 3kushn is offline
3kushn is on a distinguished road
3kushn's Avatar
I have a n older version of this. Then I put a thinsolate sleeve over it. This one might not need the cover. Then a 20deg bag with cotton liner inside.
Camped with the Scouts for about 10 years and the Troop always did a "Freeze Out" campout in January.
My only problem was my face, but that's just me. I don't like face coverings or having my head inside of the bag. Other than that I never got cold. Actually would get down to skivvies cause it was too warm with other body layers.
Talking around 0-15 degrees F for this setup.
Oops, forgot the link
NeoAir(R) XTherm™ | Lightweight Air Sleeping Pad | Therm-a-Rest(R)
3kushn is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 07:26 PM #13
I am the same way with my face, and I like the cold, but too cold and that is why I used blankets to wall-off the windows and front seats.
It traps some heat in.
Old 01-14-2021, 08:06 PM #14
ruff4runner's Avatar
ruff4runner ruff4runner is offline
ruff4runner will become famous soon enough ruff4runner will become famous soon enough
In snow country a lot of people carry a coffee can heater in their car in case they get stuck. It's just a tea light or candle to burn in a coffee can to keep the flame safely contained. They put out just enough heat to keep it above freezing without producing carbon monoxide. Uco Gear sells a candle, the "CANDLELIER" that they claim puts out 5000 BTU.( Candlelier - Candle Lantern - Aluminum )Then of course there is the Mr heater buddy which many people swear by.
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
ruff4runner is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 08:30 PM #15
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
I like to use a foam pad I bought from Walmart. I fold it in half then I throw a cheap blanket on top of that. I then roll my 0 degree down REI bag out on top of that and finish it off with a wool blanket on top if needed. Costco sells these cheep down or synthetic down throws I have one in my drawers just in case. If that’s not enough the dog goes into the bag with me and I steal his wool blanket covering his kennel. Good luck and stay warm!!
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
i’m , i’ve , sleeping , t4r , warm
ECT/PWR not staying on. murderface 3rd gen T4Rs 2 08-04-2020 10:34 AM
Staying Warm Overnight in my 4Runner bhest 4th Gen T4Rs 113 11-12-2018 03:18 PM
Ignition Staying On CXS 4th Gen T4Rs 6 03-01-2014 10:16 PM
clock staying on Sanj72 Classic T4Rs 3 08-01-2012 10:20 AM
