03-13-2021, 10:51 PM
Lift advice needed
I'm about to begin a build on a 2017 Trail Premium with KDSS. I have everything nailed down that I want to do to it. The only place I get overwhelmed is the choices for the suspension lift. I want a 3" lift and I want it leveled. I'm looking for a complete kit to include UCAs.
I want to maitain daily drivability and do lots of mild off roading with the occasional moderate severity off roading. Weight wise, I only plan to add a bully bar and winch and some aluminum skid plates.
Can anyone recommend a complete kit - inluding UCAs - that's $2500 or under?
Thanks in advance!
Current 4Runner:
2016 Trail Premium, Grey
Previous 4Runners:
2005 4WD Sport Edition, Natural White - 2007 4WD Limited, Titanium Metallic
03-13-2021, 11:56 PM
What you want is a leveling kit; that raises the front and the rear, the front more.
For only 2-3" front lift (1" rear), you don't need UCAs, rather a leveling kit that uses spaces is all; far less cost than $2500. I used the Rough Country leveling kit on my SR5: 2in Suspension Lift Kit for 2010-2019 Toyota 4-Runner 4wd | Rough Country(R). Even though it says it is 2" front, I ended up with more like 2.5".
It does not change the ride quality.
03-14-2021, 01:25 AM
I've been happy with my Toytec Boss lift, paired with SPC UCA,
Solves the front end nose dive on braking that stock suspension exhibits, ride is much improved on and off road, can run 285/70/17 tires, doesn't break the bank.
Currently have 70,000 miles on mine, I would buy it again.
03-14-2021, 02:51 AM
Toyota 4Runner 2010+/Lexus GX460 Foam Cell Pro Suspension Kit - Stage 2
Ironman lists this kit at $2399 with free shipping, and they give you some free recovery mats (worth about $100). These have adjustable front coil seat heights. A lot of people report they get more than 2" actual rear lift with their 2" performance coils.
You could also look at Dobinsons through Exit Offroad (Crikey Mike is a member here). This is the route I went. I got their IMS shocks front and back, which is comparable to the ironman in the link (adjustable height front coil seats). Dobinsons has more options available to dial-in your desired lift height with their coils. Mike is a great guy, VERY helpful with questions. Those were two big selling points for me.
The Dobinsons UCAs were out of stock and not available for backorder, so I ordered Ironman UCAs. My whole setup with UCAs, diff drop, pre-assembled fronts was just under $2400 shipped.
Dobinsons IMS Suspension Kit Toyota 4Runner 2010-21 | Exit Offroad
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
03-14-2021, 03:16 AM
Just fyi if you're lifting 3" up front be prepared to deal with kdss lean. There are different paths you can choose to compensate for it. Adjustable height coil seats is one way.
You could look into kdss spacers from Treaty Oak Off Road.
They supposedly get the sway bars back closer to their original geometry prior to installing a lift. This may also help with the clearance issue in the rear with the kdss sway bar bracket hitting the panhard bar at full droop. You could also look into eimkeith's panhard correction kit to get the panhard bar back to horizontal after installing your lift.
03-14-2021, 08:57 AM
I just did a toytec boss kit with SPC UCA and like it on my 21 TRD Off-road. Did 285 nitro MT tires and yes my mileage dropped considerably. I’d post pics but don’t have the minimum posts yet. But I am happy with the end product for sure.
03-14-2021, 10:28 AM
Thanks but as I said, I'm looking for a complete kit including UCAs.
Current 4Runner:
Previous 4Runners:
03-14-2021, 10:44 AM
+1 on IMS. I’m also now running them with 302/505 springs and JBA UCAs. Get the fronts preassembled and diy is easy. Exit off-road also sells dirt king UCAs FYI. No KDSS here. Ride is more controlled and very smooth, even more than Dobinson twin tubes which I had before. And the twin tubes were a vast improvement over OEM.
03-14-2021, 10:54 AM
Thanks guys. I like the options y'all have outlined and am looking into them.
I mentioned that the build will be on a 2017 w/KDSS however I'm actually in the process of purchasing a truck. I just came across a great deal on a 2017 Trail Premium without KDSS. Given the issues some of you mentioned with doing a 3" lift w/KDSS, am I better off without it?
I'm pulling the trigger on one of the 4Runners tomorrow.
Current 4Runner:
Previous 4Runners:
03-14-2021, 01:28 PM
With your budget, get yourself a set of bilstein 5100's, ome springs, and anything other than spc uca's.
Unless you actually plan to use your truck to its full potential, then go save up about $6k and come back to ask the question again.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
03-14-2021, 01:34 PM
Please enlighten me on why u say not to get spc ucas....I was thinking about pairing some with eibach lift springs on my 20 pro. Are there issues with them?
03-14-2021, 01:44 PM
Ask Google. There are literally hundreds of reports of broken welds and other failures with spc uca's across their entire product line.
In my experience, eibach springs are also junk. My old Radflo coilovers came with eibachs, they bagged out after about 18 months, at which time I swapped them out for a set of springs from King, which were as great as you'd expect.
Tbh, I didn't have an awesome experience with ome either, but they're cheap and a lot of guys seem to have good luck with them. Springs are inexpensive (even kings), get the best ones you can from a reputable brand. My preference personally is to go with something race-proven, rather than just whatever the current fad is (*coughcoughdobinsoncough*)
03-14-2021, 02:37 PM
Appreciate the info....I will do some more digging. The solution of the eibach springs is more or less a temp one as I want to get some use out of the fox units before I ditch them. That being said, the ucas will be more of a longterm purchase that I would expect to work with whatever upgraded (king, icon ome or whatever) setup in the next year or so. This vehicle is more of a daily driver than not. What is your suggestion on a solid, serviceable uca...something quiet too.
03-14-2021, 02:55 PM
I run a lot of Total Chaos parts (again, racing pedigree). I've had their uca's on for about 8 years now, but I'd recommend you swap out the spherical bearings for an emf sealed uniball which will last a long longer than an open bearing, and are a direct replacement for the f&k rod ends bearings that Total Chaos uses
Camburg would be my second choice.
I have no experience with the jba uca's personally, but these would be something I would take a close look at as well. A lot of guys local to me really seem to like them, but jba does seem to have a habit of sending out some Jesusy crap with their truck parts for some reason.
Icon makes an ok uca too, but there is nothing special about them to justify the premium price.
Dirt King seem to be pretty popular with the domestic truck market - which in my opinion is enough reason to avoid them - but their uca's seem to be a fine product.
If money is no object, then go with Marlin Crawler's LT ifs setup.
03-14-2021, 03:17 PM
Ironman UCA has 4 degrees caster built-in, allows 33" tires easily, and uses the same kind of bushings and sealed ball joints as oem, which last a long time and are quiet and maintenance free. They're also fully rebuildable using oem parts that can be sourced at any Toyota dealer. You can always wait for their next sale or use a 5% off code for forum members: TLCA5OFF
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
