Old 07-03-2019, 03:00 PM #16
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Originally Posted by Jono.ful View Post
8 months away, and I'm already starting to remember why I left.
Well........ BYE!
It's super easy to spend someone else's money
No one said he had to buy UCAs. Everyone advised him not to buy cheap ones and save up until he could get good ones, if he wanted UCAs.
this site is awash with experts who don't even turn their own wrenches or understand what basic components do....
I turn all of my own wrenches. I have built and raced drag cars, and built our own suspension components, so I know this doesn't apply to me. LOL
If you want a very good alignment with anywhere close to 3-4 degrees of caster then you WILL need UCAs period. If you want an okay alignment then by all means run the stockers. I still have my stocks on as well, but my cams are maxed out and I'm still out on camber and can't even get 2 degrees of caster.
Don't go getting all butt hurt and start threatening to take your ball and go home just because someone doesn't agree with you. OP is an adult and can take all of this information and make his own decisions.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 03:04 PM #17
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Sounds like you have a bent control arm/alignment tabs. Maybe you should go build a new one.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 03:04 PM #18
91324's Avatar
91324 91324 is offline
91324 will become famous soon enough 91324 will become famous soon enough
91324's Avatar
If you had a lazy or unknowledgeable tech last time you went in for an alignment, he may have only adjusted caster and camber and given up. It happens more often than you think.
The alignment printout you receive shows the pre/post results. If the tech only adjusted caster and camber and that was it, it would be obvious since the other numbers didn't change. At that point, it's on the customer to question what was done or why the toe and steer didn't change IMHO.
CT TRD Pro Replica (Heritage) Grill
DM me for 5% off any 4R item on the CarTrim website.
91324 is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 03:19 PM #19
Bayou_Pro's Avatar
Bayou_Pro's Avatar
Sure whatever. I'm done dealing with stupidity.
Paul
Old 04-28-2020, 01:39 PM #20
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I'll go against the crowd here - I couldn't justify the $500+ for SPC's. I figured why not try the Freedom Offroads, worst case is I sell them and a take a slight loss.
I've had them on for a few hundred miles now and my initial review is I'm impressed. The alignment I got pulled a 3.6 caster (all other specs in the green) on a 2.5" (sitting closer to 2.7") lift.
No noise, build quality and fit are great, just seems to always be get the most expensive item or it's junk.
Long term, we'll see how the ball joints hold up. OEM style bushings are a big plus in my book, and grease-able OEM style ball joints are a second plus. You can get replacement ball joints for under $40 a side, so not bad if they did need replacement.
YMMV - be a bit different than the masses. These things have great reviews on Tacoma World - that was the real selling feature for me.
UCA's info-img_20200417_202735-jpg  UCA's info-img_20200417_193958-jpg  UCA's info-img_20200417_193954-jpg  UCA's info-img_20200417_192606-jpg
Sundy is offline   Reply With QuoteReply With Quote
alot , highway , offroad , ucas , work
SAS info TDI runner 4th Gen T4Rs 1 03-17-2016 07:53 PM
im new ,need info scottputty 4th Gen T4Rs 16 10-04-2006 06:17 AM
Need info from someone who has this.... MattS822 4th Gen T4Rs 0 09-25-2006 10:41 AM
Need Info Gh0st Classic T4Rs 0 09-15-2006 03:08 PM
Buyer Info-2ndGen-22Re. Any info greatly appreciated Joel 4th Gen T4Rs 8 02-12-2005 05:17 AM
