Originally Posted by t4rlol
Dustin included OEM silver TRD center caps with mine and I'm almost certain they're from an FJ TRD wheel as they're the only ones that fit.
I know I'm not directly answering the question but if you can find dimensions for those silver FJ TRD caps it should get you going in the right direction.
t4rlol is correct in that the size is the exact same as the FJ TRD wheel cap. You can find those by Toyota part #
PTR18-35092. Dustin does provide a cap with any wheel order specifically the FN Pro's and those are 4" diameter. See below:
