Old 07-03-2019, 12:47 PM #1
Hoop Hoop is offline
Hoop is on a distinguished road
Trailer lights not working
I picked up a used 2017 SR5 a month or so ago, and when I tried to hook up a small boat trailer none of the lights work. When I hooked up a different trailer the turn signals/brake lights work but not the tail lights.
It appears I have two issues. The boat trailer has its own issue that I will need to sort out, but the 4Runner has an issue with the tail light circuit. I tried a 7 pin to 4 pin adaptor and had the same results as just using the 4 pin. Is there a fuse for the trailer lights that I should check? I am stumped...
Hoop is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 01:16 PM #2
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Get a test light or they have a plug in tester and make sure you're not trying to fix something that isn't broke. I've had this problem in the past and it's always been a trailer issue. Not sure if there is a fuse or not but it'll be on the lid if there is. Good luck.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 01:50 PM #3
Thanks, and I did plug in a tester and it lights up with the brakes and turn signals but not with the tail lights.
Old 07-03-2019, 01:55 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I suggest you first get a pin-out of the 4Runner connector. If you can't find one - then get a meter and make your own by operating brake, tail & turn signal lights while probing the connector. Once you have that, you can compare the trailer wiring to the 4Runners connector. Keep in mind that some connectors share wires for some functions. Chances are the trailer wiring doesn't match the 4Runners connector and or the trailer has a problem.
Old 07-03-2019, 02:31 PM #5
There is one pin on the tester that never lights, but the other two will light with the brakes and turn signals. When I hooked up a different trailer I had the same results: brakes and turn signals but no running lights.
There is a large relay in the fuse box that the lid says "towing tail" on. Could the relay go bad and allow turn signals and brake lights but not running lights?
Old 07-03-2019, 03:29 PM #6
Whelp, used a little Google Fu and found the exact problem being discussed on this forum a few years ago. I found a blown 30 amp fuse, which I am sure is the
issue with the 4Runner.
Now I can start trouble shooting the trailer...
Old 07-03-2019, 05:13 PM #7
CavPro's Avatar
CavPro CavPro is online now
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
Start with the ground wire. Good luck!
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is online now   Reply With QuoteReply With Quote
Old 05-10-2021, 01:03 PM #8
BillyBoost BillyBoost is offline
BillyBoost is on a distinguished road
I have this exact problem, which 30 amp fuse is blown? I checked the trailer with another car and all the lights work. So it is the 4Runner that is the problem.
Thank you,
Bill
2016 TRD PRO 4Runner
2012 RZR 900XP
2016 Polaris Pro RMK 163
BillyBoost is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 10:01 PM #9
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Thank you,
Bill
Time to grab your manual and find the trailer fuse.
Maybe in the drivers side fuse box left of the steering wheel.
Best Regards,
Saker
Old 05-11-2021, 08:15 AM #10
It is the fuse number 9 the 30 amp one marked TOWING TAIL Trailer tail light. Everything is good to go now.
2012 RZR 900XP
Old 05-11-2021, 11:22 AM #11
Saker's Avatar
Saker's Avatar
Couldn’t remember TOWING TAIL, glad you found it!
Best Regards,
Saker
issue , lights , pin , tail , trailer
Trailer lights not working Kimba2 General Discussions 11 05-22-2021 05:22 PM
Trailer blinkers not working benjamin247 3rd gen T4Rs 20 01-23-2019 04:06 PM
Trailer running lights not working abw73 3rd gen T4Rs 1 09-24-2015 04:26 PM
Trailer wiring not working Natter 4th Gen T4Rs 4 08-21-2015 08:10 AM
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
