Old 07-03-2019, 02:00 PM #1
bSigg0607 bSigg0607 is offline
bSigg0607 is on a distinguished road
Suspension
Is it worth piecing together a suspension or just buying a kit? Y’all have some ideas? Experience/recommendations?
TIA
bSigg0607 is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 02:19 PM #2
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Honestly, you can go either way. It really depends on what you are doing with your rig.
Our Eibach stage 1 kit would get the job done for most and rides great.
Reviews:
Eibach Pro-truck lift
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 02:27 PM #3
macscac's Avatar
macscac macscac is offline
macscac has a spectacular aura about macscac has a spectacular aura about macscac has a spectacular aura about
macscac's Avatar
its situational..
i pieced mine together but that's because i had specific towing and weight needs.
macscac is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 02:34 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I think it depends on how much you really want to get into it… maybe you want to hit the easy button, maybe what you are trying to accomplish isn’t available in a kit.
I took the piecing it together route. My front loading is pretty standard, but I wanted a larger diameter shock without the price tag of the typical 2.5 so I went with the 6112. The rears I have heavy load OME springs to deal with the added weight I typically carry but I kept the rear budget with a 5100 with the intention of upgrading later if I saw the need. The rest of it is pretty standard stuff. I added Wheelers super bumps front and rear to improve on the factory bump stops.
Some kits I was looking at were really just a collection of parts someone else put together. Some kits from people like ICON looked pretty good but ultimately decided it wasn’t for me.
I don’t really think there is a wrong answer, but the piecing it together route took more time to research, but I also got something that may have worked better for me than a turn-key solution.
Edit:
I also wanted to maintain some factory rake, and didn’t want it to sit level unloaded. When its fully loaded the truck sits pretty level and that’s what I set out to do.
Old 07-03-2019, 02:56 PM #5
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
TIA
Think long and hard and be honest with yourself about what your needs are. It's possible to spend $10k+ on suspension without breaking a sweat, but all that expensive gear may not perform as well as a <$1000 set up depending on your use.
There will be a hundred fanboys who post up here about how their system is the best, but no one knows your needs better than you. Take it from me though so you don't end up buying twice, figure out your needs, and buy the best thing you can afford that meets those needs.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 03:27 PM #6
cortney76 cortney76 is offline
cortney76 is on a distinguished road
Go with Ryan's post. Get set up for the money!
cortney76 is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 04:32 PM #7
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
I was cheap and pieced mine together. I got a friend at a dealership to snag me some Bilstein 5100s + toytech superflex at their cost which set me back like $520. Then I had a red seal mechanic friend do the install for $400. So, all-in, I paid $920. I called around and the floating average to pay for the install was around $1800 + tax + shop fees + etc. I kept the stock springs up front.
I don't off road at all and just wanted the lift for look. I also wanted to do it half-assed properly so went with a suspension lift instead of a spacer lift. You can have a 1.5" lift for way, way cheaper if you go with spacers instead of a suspension lift.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 04:50 PM #8
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
You can kinda do both with Dobinsons. They have a ton of options and if you call them they'll put together a "kit" of everything you need, but customized out of all their options. I paid....I think $850? That's just parts - I installed it myself.
As others have said, you probably don't need a setup that costs multiple thousands of dollars. I love my $850 Dobinsons setup.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 05:43 PM #9
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
I pieced together a OME lift. I was trying to choose between the Bilsteins, Eibach and the OME kits and found and read a ton of threads. Then I found free shipping and started adding things to the cart. If you know what you want your end goal to be build it, if unsure buy a kit so you have everything needed. If you can wait Eibach is doing something with a new rear setup, might be worth waiting for. OME is a 3 inch lift and that is what I was looking for most seem to be under 3 inches. and I don't want an adjustable lift just 3 inches
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 06:15 PM #10
MossJenks's Avatar
Real Name: KE0OIC
MossJenks's Avatar
Real Name: KE0OIC
Yeah, I did 2. Sometimes I wish I'd done 3 but sometimes not. Really I wish I'd done 3 but my whole family is short. Even with two I carry a little collapsible stool for my 4'10 mother (c'mon - she's 85! She used to be 5'1!) and my 5'0 mother in law. It's too high for my 5'2 father-in-law as well, but he refuses to use the stool and instead pulls himself up by the oh-shit handle.
Past:
Old 07-03-2019, 06:31 PM #11
Isn’t dobinson outside the US?
Old 07-03-2019, 06:35 PM #12
There is nothing wrong with that and there is nothing wrong with little people. ( if we can call them that) . ARB has been in the 4x4 game for a long time, Eibach has been there just as long if not longer. I see eibach as more of a dunerunner and baja set up.
The Build
Old 07-03-2019, 06:41 PM #13
Racehoss's Avatar
Racehoss Racehoss is offline
Racehoss is on a distinguished road
Racehoss's Avatar
HaHaHa
16' TEP OME suspension, ARB bumper and rack, Budbuilt Sliders
SOLD 85' 4runner Built SOLD 03 FJ100 SOLD 92' FJ80
Sold 14' trd crewmax tundra
Racehoss is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 06:49 PM #14
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
They are but they have a distributer here. The general manager is a member here. You can message him with what youre looking for and he can piece together a kit for you. Thats what i did for my 2 lift with kdss with certain weight / comfort expectations. Also just ordered a set of UCAs from them and boy are they fast at shipping!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 07:50 PM #15
Mike is the Dobinsons guy. He is on vacation this week. Ryan is the eibach guy, and I don't know who the OME guy is I used Total Automotive Performance. They are having a great sale until Saturday I think.
The Build
buying , ideas , kit , suspension , y’all
FJ TRD suspension vs FJ TT suspension vs 5100 & FJ coils andreylights 4th Gen T4Rs 4 11-16-2018 12:48 PM
FS 18 Pro suspension 5th gen pro suspension $800(Las Vegas) HKSJoo For Sale: Suspension/Wheels/Tires 6 08-17-2018 12:19 PM
TRD Suspension vs. Dobinson suspension inscarguy 4th Gen T4Rs 0 04-04-2018 07:30 PM
FJ suspension Vs 4Runner suspension Presta24 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-31-2011 10:47 AM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
