Old 07-09-2019, 05:36 PM #16
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by Dizzerin View Post
Sorry I didn't make this clearer, I was referring to the rear locker. I think I've heard that it automatically disengages if you go over 7 mph, but now that I think about it I'm not sure if it was 4lo or the locker that disengages then...
You must be mistaken. Neither 4Lo or the rear locker would disengage at any speed. It's completely determined by the user.
Old 07-09-2019, 05:38 PM #17
Bumbo's Avatar
Bumbo's Avatar
Alright I'll check that out, haven't looked into electric lockers much before , thanks so much for the info!
Btw, why do you recommend and elocker over an air locker?
Not having to deal with air infrastructure, plumbing air, or leaks would probably be the first advantage of going electric.
Complexity of install would probably be second.
I personally think the ARB is a good strong unit, but the install is critical. I would be happy with either.
Old 07-09-2019, 05:43 PM #18
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
E-locker is electrical so it is an easier install and won't fail if you get a hole in your air lines like with an ARB air locker. It also doesn't have to have the air pump which could also fail (pump also takes up space in your engine compartment). The only disadvantage of an E-locker is that it takes half a revolution of your wheel to engage. But of course that is the same with the stock E-locker on a 4Runner (I think). Unless you are really doing some tough 4wheeling the E-locker should be sufficient.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 07-09-2019, 06:05 PM #19
Bumbo's Avatar
Bumbo's Avatar
To be fair... e-lockers can have an actuator failure, and while it's rate, it could happen.
Old 07-09-2019, 07:09 PM #20
teotwaki's Avatar
teotwaki teotwaki is offline
teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice
teotwaki's Avatar
I agree it is rare and is one of the reasons I went for the factory E-locker instead of dealing with the regularly occurring issues with an air locker.
Jim _ My Adventure Blog:http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
teotwaki is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 07:17 PM #21
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Some E-lockers fail to the LOCKED position so you will still have traction if it does.
83Mule is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 12:57 AM #22
madmikes8901 madmikes8901 is offline
madmikes8901 is on a distinguished road
Sure would like to see your sliding tray.Also since you said you hunt do you have a hiding place for your long guns & handgun.
madmikes8901 is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 01:33 AM #23
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Just throwing it out there, but mind as well cross shop a limited; gives you full-time 4wd, dual climate, real leather, ventilated seats, accent lighting, etc.
Really comes down to how much you plan on wheeling and modding it. Only reason not to go kdss is if you’re looking at long travel setups, otherwise it comes down to amenities and the cost of a locker and/or suspension.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 12:32 PM #24
mteolus's Avatar
mteolus's Avatar
Limited comes with part time 4wd, not full time. It has full time AWD. There is a difference.
The limited in 4WD mode does not have a rear locker as well.
Old 07-10-2019, 01:03 PM #25
Tejas Tejas is offline
Tejas is a jewel in the rough Tejas is a jewel in the rough Tejas is a jewel in the rough
WRONG! It is a full-time 4WD system, the same as the manual FJC and GX, and same in function as the LC/LX. It has 4Hi and 4Lo with a center locking differential.
I owned a 2016 Limited 4x4. It suffers in power delivery (energy is robbed from the drivetrain due to the full-time 4WD), turning radius, and fuel economy, when compared to the part-time 4WD models like the SR5, TRD OR, and Pro. We did not care for our Limited and it was a short lived purchase due to those reasons.
Tejas is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 01:05 PM #26
Bumbo's Avatar
Bumbo's Avatar
Perhaps this is just a nomenclature issue, but the Limited does everything others can do, it just does not have is 2WD.
Rear locker aside, I still consider the Limited a full time 4WD, as it can lock the center differential, which operates no different than a trail, pro, or any other 4WD model Toyota makes.
The Limited is the only trim level that still uses the Torsen transfer-case, which was used in previous generations, GX, and Land Cruiser. As far as the center diff is concerns, it's a premium option, one I like very much as it adds versatility for on-road use, without giving up anything off-road.
Old 07-10-2019, 01:14 PM #27
themaestro's Avatar
themaestro themaestro is offline
themaestro will become famous soon enough
themaestro's Avatar
I have a 2010 TE.
In my experience, you may be limited to what you can find on the market. You can find SR5s all day, but 10-13 trails are really rare, especially in good shape, low miles, un modded, etc.
If it were me, I would hold out for a TE. I get compliments on mine all the time . I think the combo of the 10-13 TE roof rack, hood scoop, and black accents make it really pop. And they will possibly hold their value a little better.
themaestro is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 02:32 PM #28
Originally Posted by themaestro View Post
I have a 2010 TE.
Agreed, 100%!
Old 07-10-2019, 03:50 PM #29
Dizzerin Dizzerin is offline
Dizzerin is on a distinguished road
Ah alright, good to know! Thanks!
Dizzerin is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 04:21 PM #30
Originally Posted by progress4m View Post
4) 2010-13 TE has black plastic trim is more practical in long run and especially if you use the truck off road, black trim is a lot more resilient and forgiving when it comes to scratches from small brush, mud, small rocks and just from everyday use on the field
5) Cargo Sliding tray in TE- I wanted to have a flat cargo area (second row is folded) so I can sleep in the truck during my hunting trips
6) TE also comes with better quality seats, better dash and audio system
Sure you can mod SR5 and converted to TE (some people have done it here), but you will spend a lot more $ then the difference between the price of used TE vs. SR5… and if you ever decide to sell it I would say most if not all $ spend will not be recoverable… as now you still have SR5 that was “modded” and only specific buyer will appreciate it.
Great info, thanks so much for your thoughts. I didn't realize the trail also had better quality seats, dash, and audio in addition to the known off roading features. Btw does anyone know if the backup camera is stock on the TE for these years (2010-2013)?
2010-2011 , cost , locker , mileage , sr5
Thinking about the Rubicon Trail... How modded do I need to be? theoutbackdream Nor Cal 5 08-01-2017 01:26 AM
Satoshi Mod...Modded whodat 5th gen T4Rs 29 03-27-2014 09:57 PM
My new Modded T4R!!! WS4Runner 3rd gen T4Rs 31 04-22-2012 01:44 PM
Anyone Modded Exhaust cgill00 5th gen T4Rs 26 04-01-2011 12:27 PM
Has anyone modded a 2nd Gen 94yotarunner Classic T4Rs 13 09-08-2004 07:02 PM
