07-10-2019, 04:33 PM
#31
Yes the backup camera on the TE is stock.
2012 TE ~ Shoreline Blue ~ KDSS ~ NAV, Stock for now
07-10-2019, 04:55 PM
#32
Originally Posted by Dizzerin
Sorry I didn't make this clearer, I was referring to the rear locker. I think I've heard that it automatically disengages if you go over 7 mph, but now that I think about it I'm not sure if it was 4lo or the locker that disengages then...
No, that is incorrect, I know that for the fact (based on my personal experience).
Once engaged (preferably at a low speed), e-locker will stay locked regardless of the speed.
FYI: In the 5th gen 4runner, to engage e-locker you have to be in 4Lo, so he "max" speed would be obviously limited LOL
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
07-10-2019, 05:09 PM
#33
I've had a 2001 SR5 4WD (I gave it to my daughter and she still drives it 183k miles), 2004 Sports edition 4WD (gave it to my son and he still drives it 125k miles), and now a 2016 Trail Edition with KDSS. The 2016 is by far my favorite. You're not going to win any races but it will last you forever. which ever one you decide on you'll be happy with. The KDSS will make lifting it a little tougher but if I can do it ANYBODY can...I've never researched the difference in 2010-2013 TE vs 2016 TE.
2016 4Runner Trail w/KDSS / Dobinsons 3/2" / Camburg UCAs/ KO2 275/7017 / Light Bar / Raptor Lights / Rockford Fosgate amp/ Rockford Fosgate P3 subwoofer / Thule 60" Aerobars
07-10-2019, 05:31 PM
#34
Originally Posted by Tejas
WRONG! It is a full-time 4WD system, the same as the manual FJC and GX, and same in function as the LC/LX. It has 4Hi and 4Lo with a center locking differential.
"Full-time 4WD" is just marketing. The Limited is not a "full-time 4WD vehicle". That doesn't mean you can't put it in 4WD though, but you don't want to run it that way full time otherwise you will damage your vehicle on dry pavement. Watch this video for an explanation
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
07-10-2019, 05:50 PM
#35
With that definition, none of them would be considered full-time 4WD, because the end result of scrubbing on high traction surfaces would end up with the same result on every trim. The trail and pro should be called full time 2WD with 4WD off-road capability.
I agree that their marketing and terminology is kinda stupid, but fact of the matter is, the Limited is by function a full time 4WD/AWD truck. Its always working in 4WD. You either have the center transfer case unlocked for use on-road, or locked for use off-road.
07-10-2019, 06:03 PM
#36
Exactly, none of them are full-time 4WD, some are full-time AWD like the Limited. Just because they say it is full-time 4WD doesn't mean that it is. I suppose they took the liberty to call it 4WD because of the Torsen differential but the fact is even with the Torsen differential it is not the same as the Trail in 4WD mode. Only when you lock the differential is it true 4x4.
07-10-2019, 06:23 PM
#37
It appears we are all on the same page, and just kicking around Toyota nomenclature causing problems for ourselves for no reason.
It really creates confusion for people who don't truly understand how these system function from a mechanical standpoint. The Limited generally gets the short end of the stick because people don't hold it as an equal off-road, when in fact it's the same used in their flagship SUV with off-road pedigree.
At the end of the day, they all rock off-road, it's just the on-road drive modes where the differences are found. Now if they would just include both front and rear lockers as an option on all trims, I would be a very happy person.
07-10-2019, 06:42 PM
#38
Real Name: Micah
Real Name: Micah
It suffers in power delivery (energy is robbed from the drivetrain due to the full-time 4WD), turning radius, and fuel economy, when compared to the part-time 4WD models like the SR5, TRD OR, and Pro. We did not care for our Limited and it was a short lived purchase due to those reasons.
Please explain how the LE is robbed of power and suffers worse fuel economy
07-10-2019, 06:44 PM
#39
Real Name: Micah
Real Name: Micah
This seems most correct, the LE has three modes: AWD, 4H, 4L
07-10-2019, 07:32 PM
#40
Limited comes with part time 4wd, not full time. It has full time AWD. There is a difference.
The limited in 4WD mode does not have a rear locker as well.
I believe you’re misinformed on the transfer case, as others have noted.
I suggested cross shopping a limited with respect to an sr5, not the trail. I’m not sure what the used market is like for limiteds, but it may be possible to price one close to an sr5, and you’d gain the added amenities. The cost to upgrade to better suspension or a rear locker would be a wash between the two.
07-10-2019, 08:53 PM
#41
For starters it shows a lower fuel economy rating on the window sticker than the part time models. I have owned a 2015 SR5P 4x4, 2016 Limited 4x4, and now a 2018 TRD Pro 4x4 and with all of them in stock form it got the worst fuel economy of the bunch. In fact it got worse fuel economy than our Pro on heavy 275's. It was noticeably the worst of the bunch when towing the same load as well (3,000 lbs). AWD robs the drivetrain of power, this is common knowledge and it is noticeable when driving a Limited 4x4 in comparison to other models.
07-10-2019, 08:59 PM
#42
I don’t recall saying anything about a transfer case and no I am not “misinformed”. But if it makes you feel better to claim that the Limited is “full time 4WD” then fine.
07-10-2019, 09:13 PM
#43
Great to know, thank you!
07-10-2019, 09:14 PM
#44
Awesome, thanks for the info!
07-10-2019, 11:23 PM
#45
Originally Posted by themaestro
I have a 2010 TE.
In my experience, you may be limited to what you can find on the market. You can find SR5s all day, but 10-13 trails are really rare, especially in good shape, low miles, un modded, etc.
If it were me, I would hold out for a TE. I get compliments on mine all the time . I think the combo of the 10-13 TE roof rack, hood scoop, and black accents make it really pop. And they will possibly hold their value a little better.
I love my '13 Trail! I bought it back in Feb, I had thought I specifically wanted a 14+ model, but once I saw this Trail I was in love. I like it for all the reasons you mentioned, and they do seem to be rare...until I saw this one, I don't think I had ever seen one in person before.
