Old 07-08-2019, 10:11 PM #1
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
CBI Ditch Light Bracket Help
No instructions cone with these, so i watched a video of someone doing it, but it was an old 3rd gen model. I installed one, (1st bolt, then 2nd bolt) but my hood wont line up. It seems there is a plastic part that gets in the way, can someone confirm if this needs to be cut to install them?
Part of the issue is the ones they sent me look very different than the ones they show on the website, so I have no idea if they sent the correct ones.
rob_dixon is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 10:21 PM #2
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
Yes you either need to cut or melt that plastic piece to make them fit. I used a heat gun to melt the plastic then shut the hood, I think I had to do it twice.
There are pictures on this site for a 5th gen somewhere. I don’t think I bothered since it had already been documented.
Edit: found this, compare pictures to make sure you got the right one.
Ditch Light Bracket Comparison
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 11:39 PM #3
kelkins kelkins is offline
kelkins will become famous soon enough
Here’s what I did. 1: close the hood firmly, this will leave a witness mark on the cowling. 2: hit the area with a heat gun, be careful not to go overboard. Seeing a ‘shiny’ look means that you have heated the area enough. 3: slam the hood. You should find that the hood now sits flush. You may have to repeat the process though. Yes the cowling will have a deformed area, but it beats cutting the plastic. This method is also not noticeable when the hood is closed.
Not the most elegant method, but it has worked for me on several vehicles.
kelkins is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 01:21 AM #4
rob_dixon's Avatar
rob_dixon's Avatar
Excellent info! Ok, do i need an actual heat gun to melt the plastic or can i use a standard blow dryer? 140 degrees versus 1000! I assume it needs to be very high heat given these things are parked in the sun!
Old 07-09-2019, 01:53 AM #5
Heat gun.
Old 07-09-2019, 09:30 AM #6
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I had to do this on the passenger side when I had the Rago mounts. Sadly I wish I hadn't because I replaced them with the CaliRaised low profile mounts and no longer have the issue. I did the exact same method though, heated the area and then shut the hood a couple times to crease it
Old 07-09-2019, 01:08 PM #7
Same here, just needed the fix on the passenger side. I like the original tall mounts though.
bolt , cbi , line , part , plastic
Ditch Light Bracket Comparison harkco 5th gen T4Rs 37 03-19-2021 02:04 PM
5th Gen BEST DITCH LIGHT BRACKET TRUSTYAXE 5th gen T4Rs 22 10-21-2020 12:00 PM
FS 5th Gen CBI Ditch Light Bracket Pair ksaldibar For Sale: T4R Items 2 12-23-2016 12:39 AM
Ditch bracket light and roof light mounts GX470 GX4SEVEND 4th Gen T4Rs 1 09-11-2015 03:05 PM
CBI Ditch Light Bracket PearlWhite4R 5th gen T4Rs 6 01-06-2015 09:52 PM
