11-10-2019, 05:53 PM
#286
Real Name: Owen
Real Name: Owen
Has anyone order this from RhinoRadio?
It is a lot cheaper.
I just wanted to see how long ship time was for people.
Thanks
Owen
2016 Magnetic Gray SR5 premium 4x4
- Toytec Boss lift, C4Fab LoPro w/ Baja light bar and Smitybilt winch, Baja SpyUtil rack, SwitchPro to control my lights, REDARC Tow Pro elite brake controller, VTX rims, KO2 rubber, T9 head unit, 4.56 gear upgrade
- Turtleback Trailer
https://www.toyota-4runner.org/5th-g...ut-surely.html
11-10-2019, 07:33 PM
#287
Thanks
Owen
I would pay for expedited shipping, I ordered using standard and took a little over a month like they estimated
11-11-2019, 12:02 AM
#288
Originally Posted by ryanbt
gainman... are you using hard wired or wireless for carplay? If wireless, are you using Wi-Fi or Bluetooth? Also what phone/model are you using?
I have android
Sent from my SM-N975U1 using Tapatalk
11-11-2019, 12:09 AM
#289
Originally Posted by gainman
I have android
And when you connect to the head unit are you wireless or hard wired?
CURRENT: '14 Limited Mag Gray, '17 Limited Mag Gray, '19 Mercedes GLC300, '08 Urban Runner | SOLD: '96 4runner SR5, '08 Urban Runner, '14 Limited Blizzard Pearl
11-14-2019, 12:02 PM
#290
AutoKit/USB forcing T9 to reboot update!!!:
I was able to RESOLVE the reboot issue (for me anyway) with a combination of tricks from folks on the T9 Facebook page. Basically the T9 does not supply enough power for the demand of certain USB devices... I bought this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 splitter on Amazon. This splitter has 1 USB that supplies power and 1 USB that supplies power and data. Essentially you take the power from both USB's on the head unit to supply power to the AutoKit. (There is a video on their FB page on how to do this) I've been testing for two days now with not a single reboot. I did have to play around with the USB ports as it was particular about which one to use and I didn't take a picture of which one I used for power only, so you will have to play around with it as well. ALSO, you will have to go into the AutoKit settings on the T9 (without the phone plugged in) and click on advanced and then select 'Weak' on charging mode. Again, so far so good! I've also fixed the whine sound per manufacturer suggestion, bought a sharkfin adaptor and fixed the slight noise I was getting (WiFi antenna was plugged into the wrong port) which also made wireless carplay faster. I opt to still use wired carplay so that the T9 can connect to the hotspot on my iPhone. (When using wireless car play you can not use the hotspot on your phone on the T9, and it's really clunky to flip back and forth from wireless carplay to hotspot). Hopefully this helps others!
11-14-2019, 01:00 PM
#291
Now we need the T10 to come out and fix all the small bugs that the T9 has.
Glad to hear you were able to fix the nuisances though.
The reboot issue you're talking about; is that a reboot while in use or the "reboot" that the device does when the USB is plugged in and the car is powered off? So instead of the head unit sleeping for like 2 hours or whatever it would always need a full boot whenever the car is powered on
11-14-2019, 01:06 PM
#292
Yes. I should have been more specific. This fix resolved the issue of a hard/cold reboot every time the truck was turned off. They have also given me a tip to fix my Wi-Fi signal, a tip to reduce the whine noise and I've ordered a shark fin adaptor for GPS for when I'm not using carplay. I think all of my bugs are resolved! I also had an issue with Google Play store, and I couldn't figure that one out because it's not a Google 'Certified' device so not all of the cache settings, etc are available, but logging out of google and back in resolved my issue. Now if Apple would just leave the hot spot turned on all of the time on the iPhone instead of turning it off after 90 seconds of no devices connected, life would be grand! I may end up adding a SIM card to the back of the T9.
11-14-2019, 01:12 PM
#293
This is what I'm waiting for lol
2012 Shoreline Blue TE
11-14-2019, 02:55 PM
#294
Awesome; that clears up one thing that would have bothered me!
#295
Real Name: Owen
Real Name: Owen
Just ordered my T9
I don’t really want to use a SIM card, just my phone as hot spot.
I don’t really want to do wired CarPlay, so I’m hoping to use phone as hotspot and run Spotify on app of the head unit as well as a Nav app using the units nav system
Those are my biggest hopes.
I would assume the head unit will display when a text comes through without being in CarPlay
11-14-2019, 05:38 PM
#296
Just ordered my T9
You can't use your phone as a hotspot and do wireless CarPlay at the same time. Wireless CarPlay requires your phone's Wi-Fi and bluetooth at the same time, therefore disabling the hotspot. Same problem I ran into, which is why I went hardwired for my CarPlay. Note: Install the driver from the dongle, and then use that CarPlay app (AutoKit) and not the icon that says CarPlay... Also switching from wireless CarPlay back to your hotspot isn't simple. Now that I have the wired CarPlay all sorted out, to me it's the best way to go. I can use my hotspot for the non CarPlay stuff, have CarPlay and my phone charge all at the same time. The wired CarPlay dongle does not come with the unit, you have to add it at the time of purchase or buy your own.
I also ordered a sharkfin adaptor to use the built in GPS antenna instead of the one that came with it. The one that came with it isn't completely accurate (note I have it stuck under the dash at the moment and sometimes it can't find where I am, so I'm removing it tonight and connecting back to factory)
As for texts, no, mine doesn't read texts to me, just through CarPlay.
I REALLY wish Apple would leave the hotspot on all of the time when you've turned it on on your phone. I found out from researching online that if there are no devices connected to your iPhone's hotspot, it disables the hotspot after 90 seconds to save battery. Which, to me, they should then turn the slider off in your settings.
11-15-2019, 12:20 AM
#297
Real Name: Owen
Real Name: Owen
Couple things:
1. the headunit itself does not notify you of text messages if connected to bluetooth??? As every headunit does? Is that correct? You have to be connected to CarPlay?????
2. Can you tell me what sharkfin adaptor you purchased? You are saying you had to get an adaptor to use the OEM Nav antenna?
11-15-2019, 11:32 AM
#298
Couple things:
1. I have not seen a single setting about text messages other than in CarPlay. I prefer CarPlay anyway, because Siri responds pretty well for me.
2. A GPS antenna is included, but if you want to use the OEM Sharkfin you have to purchase the adaptors that Blu42 mentioned earlier in this thread. My adaptor was just delivered last night and I haven't had time to put it in yet.
I wish the USB Y splitter and the Sharkfin adaptors were included in the box as well as an adaptor to use the OEM microphone.
The metra adapter for vehicle sharkfin:
https://www.amazon.com/gp/product/B01K03PORU
Adapts metra cable to head unit:
https://www.amazon.com/gp/product/B06Y631SY1
11-15-2019, 12:46 PM
#299
Have you found an adapter for the oem microphone?
11-15-2019, 12:50 PM
#300
Not yet. I'd like to.
