Old 07-27-2019, 10:29 PM #16
2012sr5's Avatar
2012sr5 2012sr5 is offline
2012sr5 will become famous soon enough 2012sr5 will become famous soon enough
2012sr5's Avatar
Replacing the lift gate weatherstripping is pretty easy. First, I removed the old weatherstripping slowly while cleaning the edge where it's mounted. There was a bit of rust on the bottom edge, so I taped it off to spray a bit of rust reformer on it:
After that set up, I smeared some of the Toyota rubber grease all around the rim and started to install the new weatherstrip. First of all, there is a seam in the strip that goes in the middle of the bottom edge. Center that seam with the lift gate latch. To make sure you have it oriented correctly, there are three orange marks and one white mark on the strip. The three orange marks go in the bottom corners and the top driver side corner. This white mark goes in the top passenger side corner of the lift gate opening:
Use that mark and the seam at the bottom middle to make sure you have it oriented properly. It goes on pretty easily.
NOTE: I did not use any kind of weatherstripping or gasket adhesive. But I'm reading a few more threads and thinking that I should. I'll probably order some from Amazon.
2012 SR5 4WD 3rd Row
Build/Adventure thread
Nitto TG G2 LT265/70R17 review thread
2012sr5 is offline   Reply With QuoteReply With Quote
Old 07-28-2019, 02:30 PM #17
2012sr5's Avatar
2012sr5's Avatar
Bought a little tube of adhesive from Walmart for $2.49. This stuff is immediately tacky and very stringy. Like Venom from Marvel Comics. You gotta work fast. And keep the stringy stuff from getting on your headliner or anywhere else.
factory , kids , rails , running , water
Water running from tailpipe emaxxjunky Classic T4Rs 5 07-16-2014 05:46 AM
Will a tail pipe draw water if it is barely under water on a boat ramp? jow 4th Gen T4Rs 9 05-08-2013 12:53 PM
Pressurized Running Water on Jeep using Stock Bumper as tank iBison General Discussions 2 04-18-2013 06:45 PM
After running AC, water dripping from a plug right onto headers Shawn5800 3rd gen T4Rs 2 06-19-2011 02:24 AM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
