Old 07-10-2019, 08:45 PM #1
2012sr5's Avatar
2012sr5 2012sr5 is offline
2012sr5 will become famous soon enough 2012sr5 will become famous soon enough
2012sr5's Avatar
Question SOLVED: Why is water running down my 3rd row seatbelt?
SOLVED Post #12
I've searched. The threads that I've found on the subject were posted by members who have a sunroof and/or an aftermarket roof rack. I have neither. And yet today while I was at work, my wife was driving the kids back home from Dinosaur World in KY (which is awesome) in the rain, and water was running into my kid's lap. She says the rear window was all the way up. The water is running out of the slot pictured below and down the seatbelt. I think it has been happening for a while because the inside of the 4Runner smells like water was spilled after it rains. I kind of always assumed it was my kids spilling a little bit of their water bottles (we don't go anywhere without full water bottles), but I could never find the spill.
If I have my factory roof rails (never been removed) and no sunroof, what could be the issue?
I will probably start with taking off the factory rails and resealing them, unless there is something else I should check.
2012 SR5 4WD 3rd Row
Build/Adventure thread
Nitto TG G2 LT265/70R17 review thread
2012sr5 is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 10:50 PM #2
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
The only leaks folks have reported that I remember seeing have been the holes where the roof rack (or after market rack) attaches. It would be easy to take off and check as there are instructions on here.
I do recall a couple folks having their sunroof drain channels get blocked and cause a leak. I thought those caused leaks by the sunroof though.
If it’s the 3rd row seatbelt my bet would be the rear roof rack attachment. Once you take it off you will probably know. I had a larger than average gap around one of mine that had to be sealed.
Edit for link that has great pics:
DIY: Roof Rack Delete (w/ pics)
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 01:10 AM #3
2012sr5's Avatar
2012sr5's Avatar
Yeah, that's what I'm thinking, too. I can't imagine what else it could be. But I also thought that leaking only came from removing the factory rack and installing a new one incorrectly.
Thanks!
Old 07-11-2019, 09:37 AM #4
KingTaco's Avatar
KingTaco KingTaco is offline
KingTaco is a jewel in the rough KingTaco is a jewel in the rough KingTaco is a jewel in the rough
KingTaco's Avatar
I think it absolutely has to be water coming in through the roof rack mounting points. I'd bet $100 if you remove the rear crossbar, seal those 4 bolt sleeves with gusto, and reinstall, your problem will go away. The existing seal has probably deteriorated over time. The smell, photo, and description are identical to what I experienced when mine was leaking. Good luck.
Overlanding is car camping
KingTaco is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 09:57 AM #5
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Before you start taking things apart, you may want to look for rust in that area because that may impact how you tackle the issue.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 12:48 AM #6
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Low pressure, high volume water hose to recreate the problem. Verify the leak.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 03:32 AM #7
Beaver_94 Beaver_94 is offline
Beaver_94 is on a distinguished road
New 4-runner owner here. I haven’t looked to see how it’s attached to the roof yet but we had a leak in our minivan through the roof mounted antenna. Just thought I’d throw that out as a place to look as well.
Beaver_94 is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 09:38 AM #8
2012sr5's Avatar
2012sr5's Avatar
I took the passenger side roof rail off yesterday. There was some debris under the mount in the rear and what looked like evidence of water running down into the front bolt’s plastic threads. I added Teflon tape to the bolts front and rear and carefully sealed around the plastic bolt mounts with silicone. I’m giving the silicone a day or two to set up before I run a hose over it because it’s super humid here. Thanks for the help everyone!
Old 07-21-2019, 02:44 PM #9
2012sr5's Avatar
2012sr5's Avatar
Well, problem NOT solved. Drove home from church today in a torrential downpour, the kind where people drive with their hazards on through standing water on the highway. That was fun. Noticed that despite my efforts, water is coming in through the passenger side 3rd row seatbelt. But wait—there’s more! It’s coming through on the driver side 3rd row seatbelt, too!!
I’m just going to order all new parts for all four roof rack mounts, including the plastic thread housing that the bolts screw into. Stay tuned.
Old 07-21-2019, 02:51 PM #10
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
You could take off that square piece that the seatbelt runs through and look in there and maybe see where the water is coming from.
Old 07-21-2019, 03:11 PM #11
Blu42's Avatar
Blu42 Blu42 is offline
Blu42 is on a distinguished road
Blu42's Avatar
If I had water coming from an unknown place like that I'd probably want to drop the headliner (just drop the rear down) and verify where its coming from and the extent of the damage. If there is any kind of damp smell it could be a mildew/mold situation. It should be obvious once you can see in there.
2007 SR5 4WD Driftwood Pearl Totaled 2018
2014 Trail Premium with KDSS - Nautical Blue
Blu42 is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 07:28 PM #12
2012sr5's Avatar
2012sr5's Avatar
Found it
It's the weatherstripping that seals the liftgate when it's shut. This is why it only happens when we're driving and it's raining REALLY hard. Lots of water has to be running on the roof from front to back for it to leak. And even then, it doesn’t leak very much. The weatherstripping leak is in the middle, but the water runs into the channel formed by the edge of the headliner and down into the D pillar like this:
Then the water pools in these areas and runs over down the seatbelt and down into the fuzzy foam on the inside of the bottom of the D pillar panel.
It's interesting that the headliner, where it's molded around the edges, has this hardened material on the inside that seems like a thin layer of dried glue (you can see it in the above pic...it's the part that looks more yellow on the edge of the inside of the headliner). Whatever that stuff is, it kept my headliner dry and made it harder to figure out where my leak was coming from.
If you find water coming down the 3rd row seatbelts or wet spots in the back corners of the cargo area, this might be the culprit. Run a hose over the roof. Pull the headliner down enough to check the roof rack screws. We had the hose going for probably 3-5 minutes before it started leaking the way it does when we're driving through heavy rain.
Old 07-21-2019, 07:31 PM #13
andrew4r andrew4r is offline
Real Name: Andrew
andrew4r will become famous soon enough andrew4r will become famous soon enough
Real Name: Andrew
I recently installed an aftermarket roof rack. When I removed the factory rails, I noticed there was dirt underneath the plastic piece that is bolted to the vehicle. If dirt can get under there, water surely can.
@andyadventuring @samadventuring
'18 TRD Off-Road
andrew4r is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 09:49 PM #14
KingTaco's Avatar
KingTaco's Avatar
I'll be damned. Good find OP. Glad you got it tracked down.
Old 07-22-2019, 12:05 AM #15
2012sr5's Avatar
2012sr5's Avatar
Thanks! What a pain.
Ordered some parts:
OEM lift gate w'strip: 67881-35060
OEM rubber grease: 08887-01206
If I find any rust, I'll shoot it with a little Rust Reformer in black.
factory , kids , rails , running , water
Water running from tailpipe emaxxjunky Classic T4Rs 5 07-16-2014 05:46 AM
Will a tail pipe draw water if it is barely under water on a boat ramp? jow 4th Gen T4Rs 9 05-08-2013 12:53 PM
Pressurized Running Water on Jeep using Stock Bumper as tank iBison General Discussions 2 04-18-2013 06:45 PM
After running AC, water dripping from a plug right onto headers Shawn5800 3rd gen T4Rs 2 06-19-2011 02:24 AM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
