Old 04-13-2020, 12:04 AM #31
4Rums 4Rums is offline
4Rums is on a distinguished road
Originally Posted by Gclark949 View Post
@zcruiser and others,
I installed the 8500NEX but cannot get my Android S9 to properly do the bluetooth pairing thing. It says "paired" but then quickly disconnects. I tried everything including firmware update on the new HU and doing unpair and repair and app permissions and everything else I can think of.
I am wondering if the stupid e-brake green wire thing is wrong and the pairing wont work because I'm not safely parked. What exactly did you guys do with the long green e-brake wire that is supposed to go to the "power" side of the e-brake (as per 8500NEX installation schematic). Its kind of confusing with TO2 harness saying for light/green to connect to HU harness, yet the HU harness has a long wire and says to connect to parking brake.
What is the long green wire supposed to go to when you also have a TO2 harness?
Anyone have any clarity on this ebrake wire?
Are you using or have setup Android Auto? Dont't have that head unit, but I believe if you have setup Android Auto, you may need to forget and set the connections again to use standalone bluetooth. Please see this: https://www.youtube.com/watch?v=h6lYGMGAev4&feature=youtu.be&t=159
4Rums is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 09:26 AM #32
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
I have not been able to fully complete the pairing process. I cant figure out if there is some special procedure, i.e. must do bluetooth then do xy before zz.
Only thing I can try is to unground the light green ebrake wire since that is the only questionable wire connection and maybe that is screwing with the safety must be pulled over before you can perform a phone setup process.
Crutchfield is totally supportive and have offered to exchange the head unit in case of defective or to simply return it. Great customer service.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 02:15 PM #33
If you connect the light green from the Pioneer to the ebrake wire in the T02 harness, I believe it passes the e-brake signal that the OEM head unit used to lock itself when moving. No harm in connecting it and properly putting the ebrake to test it. You can also connect it to vehicle (frame) ground or the harness ground, but I would not leave the light green open wire.
Old 04-15-2020, 01:07 PM #34
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser will become famous soon enough zcruiser will become famous soon enough
zcruiser's Avatar
I wired it up to my T01 harness.
https://www.toyota-4runner.org/3395959-post16.html
E-brake: Lt green to Green
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 103K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 128K
zcruiser is offline   Reply With QuoteReply With Quote
camera , harness , info , kenwood , pioneer
pioneer Avh-p4400bh install on 2003 limited Mbiker_101 Engines / Suspension / Wheels / Tires / Audio / Accessories 32 05-18-2016 09:08 AM
Help-Pioneer 3300BT install Darrin530 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 11-28-2011 04:36 AM
Pioneer Install spongerx 3rd gen T4Rs 18 06-22-2009 02:39 AM
Pioneer Z-1 Install nazt4r2001 Engines / Suspension / Wheels / Tires / Audio / Accessories 10 11-02-2006 06:42 PM
pioneer avic d1 Install toytrukn78 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-20-2005 01:34 AM
