11-23-2019, 11:17 PM
#16
Pioneer NEX install in ‘12 Limited
By request of
@ zonzin
, I updated the T01 harness diagram to include the wire colors on the Pioneer unit and the factory rear camera wire colors.
Illumination: Orange to Orange/white
Reverse: Purple/white to Purple/white
E-brake: Lt green to Green
Speed: Pink to pink
Foot brake: No connection
As for the aux audio: The iDataLink diagram shows a connection from the Maestro to the Pioneer HU. I asked Crutchfield why I needed the analog audio connection from the Maestro to the Pioneer, consuming my aux audio input. Their response:
The audio cable that connects to the MRR module & into the back of the radio retains vehicle sources. For example, in some vehicles it will retain the factory satellite radio source depending on if the factory XM tuner was built into the factory radio or is located elsewhere in the vehicle. So it's not completely necessary if we aren't retaining any vehicle features like that.
If the factory AUX connection is more important or necessary than the vehicle features, I would connect the AUX 3.5mm into that AV-In instead of the MRR audio cable.
I haven’t gone back in to reconnect my center console aux audio back into the HU, but will be doing that soon.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
11-24-2019, 12:50 PM
#17
Thanks for the info zcruiser! I have my 8500NEX installed now and all works well. It wasn't too bad getting the harnesses matched up. I used the factory HU bracket to mount it all and that worked out great. As someone else pointed out I drill a third hole in the bracket to match up with the Pioneer so I could use 3 screws to attach. Also had to grind off the lower "nub" on the brackets to fit flush on the HU.
About the only thing that annoys me is the stupid nanny message that shows on the front camera about reverse image. It would be ok if it went away after a few seconds but no, it is permanent when using the camera. I have been searching for a hack to get rid of it but so far nothing. Amazing a little info there is out there on Pioneer HU hacks, not even a good forum to search.
EDIT: A setting for the FF camera switching it to Video gets rid of the annoying message. Also, with the 8500, using wireless Android Auto on a phone other than a Pixel or other approved phone, you have to set your phone (mine is an Essential PH1) to developer mode and install the latest beta of Google Play Services and then the phone will connect wirelessly. Instructions here.
11-24-2019, 03:35 PM
#18
That 8500 looks awesome!
I did a side-by-side on the 6500 and just couldn’t quite justify the step up, but I really wanted one. Enjoy!
11-24-2019, 10:53 PM
#19
Parking Break Wire?
This post may be too old for the OP to see, but does anyhow have experience with these Pioneer head units and the required parking break wire for entering certain address searches of other features such as screen mirroring? I am wondering if it is an easy thing to bypass. I think it would be cool to be able to screen mirror when using Gaia navigation on 4WD trails and then you wouldnt really need an iPad to see where you are going. The little telephone screen is too small really, and an iPad works great but screen mirror would be nice.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
11-25-2019, 12:31 AM
#20
I’m the OP and I am old.
Just don’t hook up the signal, or fool the system into thinking you have the parking brake on.
Boom.
YouTube
11-25-2019, 09:19 AM
#21
@ zcruiser
, thanks for the reply. I also wonder about the vehicle speed sensor wire. When I read the Crutchfield info it says thinks like "with vehicle stopped and parking brake engaged....".
Has anyone experience with how to bypass these safety features so I can screen mirror while driving?
11-25-2019, 09:29 AM
#22
@ zcruiser
If you don't hook up the speed sensing wire, it would think you are stopped. Not sure what other functions that would mess up, however.
You could put a switch inline with the speed sensor wire. Flip it on (closed) when you want the signal to reach the HU, flip it off (open) when you want to fool the HU into thinking you're stopped.
11-25-2019, 01:15 PM
#23
Well if I understand your question correctly, the bypass is easy. Just ground the parking brake wire out of the HU and you are GTG. Another trick is to override via the HU functions, see : YouTube
I did both just to be sure all functions are unlocked. Also, screen mirroring while driving works like a champ on the 8500.
11-25-2019, 06:12 PM
#24
Wow, that's a pretty sweet trick! Will have to try it on my 6500...
ETA: It works! I did have to press all the way in the lower-left corner vs 1/2" up and 1/2" over. I was disappointed at first until I moved my press all the way into the corner.
11-26-2019, 08:26 AM
#25
Awesome man. Thank you. Now I am pumped to buy the 8500NEX.
02-10-2020, 10:11 PM
#26
[QUOTE=zonzin;3396938]Well if I understand your question correctly, the bypass is easy. Just ground the parking brake wire out of the HU and you are GTG. Another trick is to override via the HU functions, see : YouTube
Great info in this thread. Getting ready to install the 8500nex myself with the help of the info here. To confirm/clarify the brake bypass - will the override trick via the HU functions reference above still work if you still had the green parking brake wire from the t02 harness connected to the HU harness from above wiring diagram (green to green), OR do you still need to ground the green wire from the HU and not connect the green wire from the t02 harness? If you still need to ground the green from the HU, can ground it by attaching that to the black ground lead from the HU, and then to the to2 black ground or do you need to physically ground it to some metal? thanks in advance.
02-11-2020, 10:39 AM
#27
I wired green to green for parking brake and the override works as described.
Otherwise, if you so choose, ground is ground whether you hook to black or some piece of metal that is sufficiently connected to the vehicle chassis.
02-19-2020, 02:51 PM
#28
Here's the metallic silver that I used, may be a touch sparkly but it's not bad....
02-21-2020, 01:35 AM
#29
great info in this thread. was able to do my first ever install with the help here, other threads and youtube. Had to look at the 1000 wires in the harness, wiring diagram about 50 times, but got it. I got the newer maestro rr2, although not sure what future benefits it would provide me - couldn't find much info on how to use/program the three new options, and I didn't use bluetooth to flash. If anyone has further info on the RR2 other than the one youtube video, feel free to share.
I also took out the 12v lighter and replaced it with a USB / HDMI input on the center stack. Might reroute the 12 v socket to the glove box later. I added the siriusxm, although not activated now. Had to change a few things and re-flashed it. I also ran a usb like zcruiser to the glove box to flash. Learned the hard way and figured out you have to take out the radio fuse in order to flash it once installed since there can't be power to the rr in order for the laptop to recognize it. Zcruiser - thanks for the recommendation on the paint. Looks more sparkly in the photos than it really is - i like the color. again, awesome info and thread - when I first saw all the wires when initially researched the install and didn't know too much about maestro and idatalink either - i thought no way....... Had a heck of a time to get the rr2, sirius tuner, and the bundle of wires shoved back in there.
04-12-2020, 10:14 PM
#30
@ zcruiser
and others,
I installed the 8500NEX but cannot get my Android S9 to properly do the bluetooth pairing thing. It says "paired" but then quickly disconnects. I tried everything including firmware update on the new HU and doing unpair and repair and app permissions and everything else I can think of.
I am wondering if the stupid e-brake green wire thing is wrong and the pairing wont work because I'm not safely parked. What exactly did you guys do with the long green e-brake wire that is supposed to go to the "power" side of the e-brake (as per 8500NEX installation schematic). Its kind of confusing with TO2 harness saying for light/green to connect to HU harness, yet the HU harness has a long wire and says to connect to parking brake.
What is the long green wire supposed to go to when you also have a TO2 harness?
Anyone have any clarity on this ebrake wire?
