Originally Posted by Gclark949
I have not been able to fully complete the pairing process. I cant figure out if there is some special procedure, i.e. must do bluetooth then do xy before zz.
Only thing I can try is to unground the light green ebrake wire since that is the only questionable wire connection and maybe that is screwing with the safety must be pulled over before you can perform a phone setup process.
Crutchfield is totally supportive and have offered to exchange the head unit in case of defective or to simply return it. Great customer service.
If you connect the light green from the Pioneer to the ebrake wire in the T02 harness, I believe it passes the e-brake signal that the OEM head unit used to lock itself when moving. No harm in connecting it and properly putting the ebrake to test it. You can also connect it to vehicle (frame) ground or the harness ground, but I would not leave the light green open wire.
